    help with a thread
    37 Posts 3 Posters 1.6k Views 3 Watching
      Dave R @Leggy
      @Leggy said in help with a thread:
      I'm making progress.
      OK. So you don't need the video tutorial I did? Good enough.
        Leggy @Dave R
        @Dave-R where is it?
          Rich O Brien Moderator @Leggy
          watching Rich's video about 8 times I'm making progress
          I did a video?
            Dave R @Leggy
            where is it?
              Leggy
              Aha I got you mixed up, that was the one I watched
                Leggy
                I’m the problem, ha ha
                I need a back to basics tutorial, I always seem to miss a certain point and nothing happens . I can see the way both of you do the threads but I’m missing something
                  Leggy
                  Ok I’ve managed a male and female thread on a 150mm diameter, with a 0.3 offset, . It’s very tight can wind it on for 2 threads , and that’s it. Tomorrow doing another female with an extra 0.3 clearance on all faces, so see how that goes. I think it’s the shrinkage on the printer that’s causing the problem
                  Thanks Guys for all your help
                    Dave R @Leggy
                    That's probably it. You'll have to work that out based on the material.
                      Leggy
                      I finally got it to work , pictures to follow , thanks Guys
                        Leggy
                          Leggy
                          1CB2BC12-596F-4745-BC0F-C832939B95AE.mov
                            Well done @Leggy
                              Leggy
                              Hi guys
                              Again thanks for all your help
                              Is there a chart you use to look up thread dimensions, pitch, tpi , crest etc
                              I was trying a m22 x 2.5 and got a bit confused on the chart I was following, so I asked ChatGPT
                              After 4 hours of me telling it, it was wrong, it finally agreed 🙄
                              I was drawing it in SU then asking it questions on the iPad
                              When I get home I’ll upload my figures and see what you think, the thread looks good on the screen, but that doesn’t mean it will fit
                              Thanks Dean
                              Dave RD 1 Reply Last reply 👍 Reply Quote 1
                                Leggy
                                  Leggy
                                  These are what chat told me
                                    Dave R @Leggy
                                    I would use the following site:
                                    External Metric ISO Thread Table Chart Sizes M20 - M55
                                    Metric external thread size table chart for sizes M20 to M55 Bolts and screws per. ANSI/ASME B1.13M-1995.
                                    (www.engineersedge.com)
                                    I wouldn't bother with the radiused corners because they'd be too small.
                                      Leggy
                                      Ill check it out
                                        Leggy
                                        What about tpi?
                                          Dave R @Leggy
                                          What about tpi?
                                          What do you mean? The thread pitch is given along with the other dimensions for the threads. TPI standas for Threads Per Inch and is not used for metric threads. M22x2.5 indicates the nominal diamter is 22mm and the pitch is 2.5mm. The helix rises 2.5mm for each rotation.
                                            Leggy
                                            Ah ok , I see what you mean, this is where ChatGPT was messing with me
                                            • 2 / 2
