    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 593 Posters 13.7m Views 595 Watching
    • Y
      yde0128 Newcomers
      thanks!
      • fredo6F
        NEW RELEASE: LibFredo6 v15.4c - 01 Aug 25
        LibFredo6 15.4c is a minor release. It includes changes related to:
        • ToolsOnSurface (bug in image textures)
        • Other bug Fixing and technical adjustments
          simulat @fredo6
          @fredo6
          Hi Fredo,
          I was never able to resolve this.. I've resorted to trying to figure out how I can upgrade my sketchup and retain use of the main plugin I use (Twilight Render 2). This company and website no longer exist.
          I found a version of twilight for sketchup 2024 on the way back machine. I can get it installed and working but the licenses I purchased for the Pro features & add ons won't activate, assuming it's tied to my old install of windows.
          Anyway you could help me? Do you have any ideas or a direction you could point me in to help me activate this?
          Thank you 🙏
          ⚠ [Removed image containing private info]
          • fredo6F
            You are in a thread about LibFredo6. I have no relation with Twilight Render.
            • fredo6F
              NEW RELEASE: LibFredo6 v15.4d - 14 Aug 25
              LibFredo6 15.4d is a minor release. It includes changes related to:
              • Future compatibility
              • K
                kngpw
                I'm still having the issue of"ArgumentError (invalid byte sequence in UTF-8)"
                I want to clarify that my Windows computer name has no non-roman characters. At first I thought it was related to the system language being set in both English and Thai . But the problem is still there when I'm using English only system.
                Extension Errors Report
                SketchUp: 24.0.594
                OS: Windows 11
                Ruby: 3.2.2
                Extension: Fredo6 LibFredo6 (15.4d - 14 Aug 25)
                Error: ArgumentError (invalid byte sequence in UTF-8)
                c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in match' c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in block (2 levels) in load_from_config'
                c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in each' c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in block in load_from_config'
                c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in foreach' c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in load_from_config'
                c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins' c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each'
                c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins' c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup'
                C:/Users/pchueathue/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/pchueathue/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                C:/Users/pchueathue/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                • fredo6F
                  I still don't have a rational explanation for this bug which a few users have from time to time.
                  Did you touch or manipulate manually the plugin files, in particular the files with .plugin extension?
                  Can you try with LibFredo6 v15.4e, just released.
                  • K
                    kngpw
                    The new update works now! Thank you!
                      JKDEKO Newcomers
                      Salut, je suis sur Sketchup 2024 (OS X) mais impossible d'installer votre extension. Je n'ai plus la fenĂȘtre "prĂ©fĂ©rences". Avez-vous un conseil pour m'aider svp ? Merci beaucoup.
                      TIGT 1 Reply Last reply
                        TIG Moderator @JKDEKO
                        @JKDEKO
                        If you are using Fredo's extensions you also need to install the SketchUcation Toolset which manages the licensing, and LibFredo.
                        If you have the Toolset install you can browse and auto-install these extension/lib files without having to get an RBZ file etc.
                        To install the Toolset download its RBZ from this link...
                        https://sketchucation.com/pluginstore?pln=SketchUcationTools
                        The use the Extensions > Extension Manager dialog to install it for you. Restart SketchUp to sync everything...
                        Si vous utilisez les extensions Fredo, vous devez également installer SketchUp Toolset, qui gÚre les licences, ainsi que LibFredo.
                        Si vous avez installé SketchUp Toolset, vous pouvez parcourir et installer automatiquement ces fichiers d'extension/librairie sans avoir à télécharger de fichier RBZ, etc.
                        Pour installer SketchUp Toolset, téléchargez son RBZ depuis ce lien :
                        Utilisez la Toolset de dialogue Extensions > Extension Manager [Gestionnaire d'extensions?] pour l'installer. Redémarrez SketchUp pour synchroniser le tout...
                        • F
                          fastrerudy
                          bonjour,
                          j essaie d'intaller fredo scale sur mon sketchup 2024 mais en vain, j ai bien le pushpull etc.. mais impossible d'installer le fredo scale ou tools. j ai eu le fredo scale dans le passé mais maintenant lorsque je l'installe , pas de messages mais apparait bien dans mon gestionnaire d'extensions mais pas dans les icones ou barre de menu, pourriez vous m'aider à ce sujet? merci ! belle journée
                          I'm trying to install Fredo Scale on my SketchUp 2024 but in vain. I have PushPull etc. but I can't install Fredo Scale or Tools. I had Fredo Scale in the past but now when I install it, no messages but it appears in my extension manager but not in the icons or menu bar. Could you help me with this? Thank you! Have a nice day.
                            @fastrerudy Have you installed Libfredo?
                            SketchUp Plugins | PluginStore | SketchUcation
                            SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                            (sketchucation.com)
                            It is required for the extensions you mention.
                            • fredo6F
                              NEW RELEASE: LibFredo6 v15.5a - 08 Oct 25
                              LibFredo6 15.5a is a major release. It includes changes related to:
                              • Full compatibility with SU2026
                              alexpacio2013A 1 Reply Last reply
                              • alexpacio2013A
                                alexpacio2013 @fredo6
                                @fredo6 I installed this new version on sketchup 2025 and everything crashes. How can I go back to the previous version?
                                fredo6F 1 Reply Last reply
                                • fredo6F
                                  fredo6 @alexpacio2013
                                  @alexpacio2013 said in [Plugin Library] LibFredo6 - v15.5a - 08 Oct 25:
                                  I would need more details on this 'eveything crashes'
                                  • alexpacio2013A
                                    @fredo6 In practice, SketchUp closes without any warning or message. If I disable the Fredo library, SketchUp starts normally, but of course, the Fredo plugins — which are essential for me — do not work.
                                    • fredo6F
                                      By the way, Windows or Mac?
                                      • alexpacio2013A
                                        @fredo6 windows 11
                                        • alexpacio2013A
                                          alexpacio2013
                                          I tried deleting all the Fredo plugins and SketchUp starts up normally. If I install only LibFredo, I've tried both the latest version LibFredo6_v15.5a and the previous version LibFredo6_v15.4c and SketchUp crashes on startup.
                                          Until a few days ago everything was working perfectly without problems, I only installed the new Sketchucation and apart from SketchUp 2026 which shouldn't affect my already installed SketchUp 2025 unless it installs something in common with SketchUp 2025 as well
                                          • fredo6F
                                            Do you start Sketchup with the default template or a custom template ?
                                            What happens if you deinstall Sketchucation and just install LibFredo6 ?
                                            • 106
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 115
                                            • 116
                                            • 108 / 116
