    [Plugin] SketchyFFD (mind.sight.studios)
    17 Posts 14 Posters 20.8k Views 14 Watching
    • mindsightstudiosM Offline
      mindsightstudios
      @gd3design said:
      I agree that a gizmo would be very handy to have in FFD. One thing I miss from 3ds max when using sketchyFFD is the ability to select two control points and scale them as a means of moving them equal distances toward or away from each other.
      Thanks the great feedback! Rather than using gizmos, I like to utilize move, rotate and scale in a more 'SketchUp' way. Some people prefer gizmos though - I suppose it might be related to which apps you used prior to discovering SketchUp.
        rv1974
        To scale 2 points in 'Sketchup way' means fail 😄 I hope you won't copy SU behavior fully
          The Gizmo of this incredible new free modeler : MagicaCSG ☀
            mindsightstudios
            haha! don't worry - we've got you covered
              lab971mail
              So I tried downloading this plugin "slicer" or as after downloading it says "sketchyFFD", but for some reason it is not appearing anywhere. But shows "installed" in Extension Manager.
              B 1 Reply Last reply Reply Quote 0
                Its a context-menu entry so you only see it when your selection is correct and you right click.
                  Louis Moens
                  Hey Dale,
                  I've got a little problem using FFD. After selecting the group and choosing one of the three FFD options, the control points do not appear. Any idea of what that might be ? Maybe just a display issue...
                  Thank you in advance,
                  Louis M.
                  C 1 Reply Last reply Reply Quote 0
                  • H Offline
                    Himbeertoni
                    Hello ! by hardware restrictions i have i like to ask if this plug-in exist somewhere in a version for su2016 x86 ?
                    thank you
                      cgmbook @Louis Moens
                      @Louis-Moens Hey, i have the same problem have you found the solution to view the control points ?
                        badvendetta @lab971mail
                        @lab971mail same problem, can you find where is it?
                          CésarCK
                          this plug in does nothing. Is there somewhere where someone can explain to me what it is for?
                            Try visiting the owner's website and follow the instructions carefully.
                            The things you need to select to get the tool to work is a little complicated, but once you understand it it's pretty straightforward...
