    [Plugin] SketchyFFD (mind.sight.studios)
    17 Posts 14 Posters 20.8k Views 14 Watching
    • GD3DesignG Offline
      GD3Design
      Hey Dale,
      That is great news. Very interested to see what you can do to improve FFD. I've posted gizmos from other programs. 3ds max has a different gizmo for each transform - move, rotate & scale. Blender also, but they also have a combined gizmo if you choose to use it. You can easily move, rotate & scale without switching modes/commands. In sketchup, Thom has implemented a gizmo in Vertex tools that is also a combined gizmo for moving vertices.
      I agree that a gizmo would be very handy to have in FFD. One thing I miss from 3ds max when using sketchyFFD is the ability to select two control points and scale them as a means of moving them equal distances toward or away from each other. If you aren't familiar with that or it isn't making sense, I could post a gif.
      Cheers,
      GD
      Blender all-in-one gizmo
      3ds Max gizmos
      Vertex Tools Gizmo
      • mindsightstudiosM Offline
        mindsightstudios
        Thanks the great feedback! Rather than using gizmos, I like to utilize move, rotate and scale in a more 'SketchUp' way. Some people prefer gizmos though - I suppose it might be related to which apps you used prior to discovering SketchUp.
          rv1974
          To scale 2 points in 'Sketchup way' means fail 😄 I hope you won't copy SU behavior fully
            The Gizmo of this incredible new free modeler : MagicaCSG ☀
              mindsightstudios
              haha! don't worry - we've got you covered
                lab971mail
                So I tried downloading this plugin "slicer" or as after downloading it says "sketchyFFD", but for some reason it is not appearing anywhere. But shows "installed" in Extension Manager.
                B 1 Reply Last reply Reply Quote 0
                  Its a context-menu entry so you only see it when your selection is correct and you right click.
                    Louis Moens
                    Hey Dale,
                    I've got a little problem using FFD. After selecting the group and choosing one of the three FFD options, the control points do not appear. Any idea of what that might be ? Maybe just a display issue...
                    Thank you in advance,
                    Louis M.
                    C 1 Reply Last reply Reply Quote 0
                    • H Offline
                      Himbeertoni
                      Hello ! by hardware restrictions i have i like to ask if this plug-in exist somewhere in a version for su2016 x86 ?
                      thank you
                        cgmbook @Louis Moens
                        @Louis-Moens Hey, i have the same problem have you found the solution to view the control points ?
                          badvendetta @lab971mail
                          @lab971mail same problem, can you find where is it?
                            CésarCK
                            this plug in does nothing. Is there somewhere where someone can explain to me what it is for?
                              Try visiting the owner's website and follow the instructions carefully.
                              The things you need to select to get the tool to work is a little complicated, but once you understand it it's pretty straightforward...
