    Toposhaper Problems
    24 Posts 9 Posters 6.9k Views 9 Watching
    • F
      francoisvienne1 Newcomers
      Hello everyone,
      I have a problem using toposhaper with my points cloud . I attached herein the file for reference. A QS has drawn from the study land and profiled the topo points in 3D. When importing in sketchup, they appear thus in 3D. However when launching toposhaper, I have this message (when the whole points cloud is grouped) : Selection does not contain Guide Points ; or an alert icon (when the points cloud is exploded).
      I'd be really grateful if you can help,
      Best regards,
      François
      • fredo6F
        Can you check if the Construction points are themselves enclosed in individual groups, or if there is an intermediate group.
        Also, verify that the Contruction points are real Sketchup Guide Points and not crosses drawn with 2 segments.
        Possibly, you may attach the skp file to your answer.
        F 1 Reply Last reply
        • F
          francoisvienne1 Newcomers @fredo6
          Good afternoon @fredo6,
          Thank you very much for your prompt answer. Please find in the attached the file itself as per your request.
          Best regards,
          François
          for fredo6 check.skp
            Rich O Brien Moderator @francoisvienne1
            @francoisvienne1 Your points are components instanced at the required altitude.
            Edit the component containing the component instances. Explode the guide point components so you have guides point realised into the model space.
            Exit group and then try generating terrain mesh.
            • F
              francoisvienne1 Newcomers @Rich O Brien
              Good morning @Rich-O-Brien,
              Fantastic ! Thank you so much for your help !
              See you on the forum chat,
              Best regards,
              François
              • P
                pitzulea
                Hello Fredo, nice to meet you in the first place I have many addons from you and they are incredible. Regarding toposhaper please help me.. I have a terrain generated starting from an import from dwg. with 3d polylines. The problem is that the curves are not contained in the terrain as if you do it let s say with the native "from contour". In the pictures you can see the curves ( i activated transparency) and then without it you can see that in many areas they are inside the terrain. Can I make a setup in order to have the terrain exactly on the curves? I have tried to divide the curves with Tig's C points at vertex and than to use your trimesh terrain but it s a huge task, i prefere it from curves
                • fredo6F
                  The Quad terrain does not respect extacly the isocontour curves. This is the price to pay to have a nicer quads surface.
                  However, the surface is close enough to the curves.
                  • P
                    pitzulea
                    Indeed, thank you for the answer. Nevertheless I increased the mesh at maximum and now it s veeeeryyyy close, so yes, I m pleased with the result. For users like me...PLEASE LOOK IN ALL THE PARAMETERS and change the grid to where you consider it is sufficient. Again, thank you for your genius addons, I use them a lot, sketchup would be a pain without them.
                    • N
                      naharv000hari Newcomers @BBDesign
                      @BBDesign
                      even i am facing the same issue . I have attached the issue :
                      An error occurred in CLEANSING
                      The operation is fully aborted
                      cannot hide layer that is a part of the active path
                      Ruby File
                      Line
                      Method
                      body_lib6tool.rbe
                      2566
                      visible=
                      body_lib6tool.rbe
                      2566
                      block in switch_to_temp_layer
                      body_lib6tool.rbe
                      2565
                      each
                      body_lib6tool.rbe
                      2565
                      toposhapertool.rbe
                      1393
                      change_view
                      toposhapertool.rbe
                      1360
                      set_preview_working
                      toposhapertool.rbe
                      546
                      cleansing_processing
                      toposhapertool.rbe
                      525
                      after_selection
                      toposhapertool.rbe
                      495
                      notify_edge_picked
                      body_lib6edgepicker.rbe
                      541
                      call
                      541
                      notify_action
                      584
                      terminate_current_selection
                      toposhapertool.rbe
                      660
                      execute_validate
                      toposhapertool.rbe
                      389
                      handle_initial_selection
                      toposhapertool.rbe
                      321
                      activate
                      toposhapertool.rbe
                      133
                      select_tool
                      toposhapertool.rbe
                      133
                      action__mapping
                      data6.rb
                      65
                      call
                      data6.rb
                      65
                      launch_action
                      lib6plugin.rbe
                      244
                      launch_action
                      bootstrap_toposhaper.rbe
                      83
                      launch_action
                      149
                      block in startup
                      lib6plugin.rbe
                      1463
                      command_invoke
                      lib6plugin.rbe
                      1443
                      block (2 levels) in build_config_commands
                      lib6traductor.rbe
                      1532
                      block in add_command
                      • fredo6F
                        Just select the Group from outside and launch TopoShaper.
                          DenizMtly
                          Hi Fredo, I have the same issue. You may find it attached along with the file;
                          Ruby Error - CLEANSING - 10-Oct-25 19_25_11 - SU2025.0 - LibFredo6 - v15.4e.txt
                          Terrain.skp
                          • fredo6F
                            Just do what is mentioned in the post above yours.
                              DenizMtly
                              It just makes me sad that you assume i did not do that!
                                @DenizMtly what is the problem?
                                toposhaper terrain
                                D 1 Reply Last reply
                                  DenizMtly @Rich O Brien
                                  @Rich-O-Brien It seems it's working with you, but not with me. Tried several times before but I'll give it another try.
                                    Make sure your extensions are up to date
                                      @Rich-O-Brien They are all the recent versions. But the model I've sent was copied from another file and pasted in a new one and saved afterwards. The contours group was under another group. Therefore I was trying in that parent group and from outside contours group. After I saw you were successful, I copied it and pasted outside, then tried again, it finally worked. So it does not work if the group is under another parent group. Is that the case?
                                        If your contours are nested, as in grouped in a group, then you will need to select contours after selecting the Parent group.
                                        If your contours are just a single group then Toposhaper treats that as the selection.
                                          @Rich-O-Brien Thanks a lot!
                                          • TommyKT
                                            TommyK
                                            I also get the "cannot hide layer that is a part of the active path" error when trying to Generate Quadmesh from terrain. This error occurs even when selecting the contours that are grouped.
                                            What fixed it for me: move the group of contours to the root context. This error seems to come up if you are working within nested groups. TopoShaper seems to only work in the master context.
                                            Ruby Error - CLEANSING - 24-Feb-26 10:33:43 - SU2025.0 - LibFredo6 - v15.8e.txt
