    2.2k Posts 480 Posters 833.0k Views 485 Watching
      If you view the output above there is no FredoGhost installed.
      Please go to Extensions > Sketchucation > ExtensionStore
      Use Search to find FredoGhost and click Install for version 2.1
      Restart SketchUp
      Go to Tools > Fredo Collection > FredoGhost > Licenses...
      Use your license to Activate FredoGhost
      E 1 Reply Last reply Reply Quote 0
      • E Offline
        epitaph Newcomers @Rich O Brien
        @Rich-O-Brien
        Hello, I have installed FredoGhost. The toolbar and menu can both display FredoGhost normally, but it does not appear in the Fredo6 "Check for Updates" list. I have also tried completely reinstalling SU 2025, but the problem still persists.
          Only thing I could suggest is to go to your Plugins folder...
          Delete the Fredo6_FredoGhost.rb file and Fredo6_FredoGhost folder
          Restart SketchUp
          Install FredoGhost using Sketchucation Tools
          Restart SketchUp to ensure its a complete install
          Run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and validate that FredoGhost is listed.
          Activate the license.
          If its not listed maybe @fredo6 has ideas as to why you are seeing menu entries and toolbars but unable to license?
          Have you done something unconventional in terms of moving extensions to SketchUp 2025?
            Sepso
            Hello,
            FredoScale and FredoSketch stopped working this morning, everything is up-to-date...
            Tried to re-install both. I've purchased license last year and no issues so far.
            License also not visible in SketchUcation but i've got the file on my hard-drive...
            Any suggestions?
            Thx
              Most likely you've got more than 1 account and you purchased using the other account.
              Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                Sepso
                > FredoScale v3.6a
                > FredoSketch v1.6a
                  Signature File: 2025-08-04 12:03:37 +0200
                  That's not the full output. Can you provide the full output?
                    Sepso
                    Fredo6 Plugins Information on 2025-08-04 12:53:38 +0200
                    • Sketchup: 25.0.660
                    • LibFredo6: v15.4c
                    • LibFredo6 Binary loaded
                    • Sketchucation ExtensionStore: 4.4.1
                    • SCFLicense: v6.4a - 74
                    • Fredo6 Plugins
                      FredoScale v3.6a
                      FredoSketch v1.6a
                      Sepso84
                      • LibFredo6: v15.4c
                      • Fredo6 Plugins
                        FredoScale v3.6a
                        FredoSketch v1.6a
                        Sepso84
                        Thanks a lot
                          @Sepso84
                          Can you share error messages when you use your license file to activate?
                          Also having 2 accounts is not helping you. I'd suggest you request to delete the unneeded account.
                          • N Offline
                            NhaQuynh Newcomers
                            I had bought the lisense and this show up
                              @NhaQuynh Please update all extensions.
                              You are using a very old version of Sketchucation Tools which contains the licensing system.
                                rendyinterior Newcomers
                                Hi Sketchucation,
                                I just started using Fredo6 few weeks back. I was using it perfectly fine on my desktop (Windows 10) with a free account. when I try to install it on my new laptop (running Windows 11) it keep showing me it license has been expired.
                                Then I try to install fredo6 on my old laptop and it works. I believe I did the installation correctly but don't know what went wrong. I'm using FredoScale and FredoCorner.
                                Please help. Thanks in advance.
                                R 1 Reply Last reply Reply Quote 1
                                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp on the device with the issue and copy/paste the output into your reply.
                                    rendyinterior Newcomers @rendyinterior
                                    Fredo6 Plugins Information on 2025-08-08 18:26:44 +0800
                                    • Platform: x64-mswin64_140 - Ruby: 2.7.2
                                    • Sketchup: 22.0.316
                                    • LibFredo6: v15.4c
                                    • Fredo6 Plugins
                                      FredoCorner v2.7a
                                      FredoScale v3.6a
                                      Signature File: 2025-08-08 02:27:31 +0800
                                      If you download your license files from https://sketchucation.com/webshop/my-licences.php and use Tools > Fredo Collection > [Plugin Name] > License... to activate.
                                      Are you getting error messages?
                                      R 1 Reply Last reply Reply Quote 0
                                        rendyinterior Newcomers @Rich O Brien
                                        @Rich-O-Brien
                                        I'm using free account. there is nothing in my license page. by the way, I'm installing my sketchup 2022 in drive D:. can that cause the error?
                                        Dave RD 1 Reply Last reply Reply Quote 1
                                          If you haven't bought a license then its normal to see Trial Expired.
                                          To buy licenses please visit https://sketchucation.com/plugin-list.php
                                            Dave R @rendyinterior
                                            @rendyinterior said in SCFLicense: Extension Licensing on Sketchucation:
                                            That could cause other errors with running SketchUp.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 108
                                            • 109
                                            • 22 / 109
