    2.3k Posts 515 Posters 2.3m Views 520 Watching
      Sepso
      Hello,
      FredoScale and FredoSketch stopped working this morning, everything is up-to-date...
      Tried to re-install both. I've purchased license last year and no issues so far.
      License also not visible in SketchUcation but i've got the file on my hard-drive...
      Any suggestions?
      Thx
        Most likely you've got more than 1 account and you purchased using the other account.
        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
          Sepso
          > FredoScale v3.6a
          > FredoSketch v1.6a
            Signature File: 2025-08-04 12:03:37 +0200
            That's not the full output. Can you provide the full output?
              Sepso
              Fredo6 Plugins Information on 2025-08-04 12:53:38 +0200
              • Sketchup: 25.0.660
              • LibFredo6: v15.4c
              • LibFredo6 Binary loaded
              • Sketchucation ExtensionStore: 4.4.1
              • SCFLicense: v6.4a - 74
              • Fredo6 Plugins
                FredoScale v3.6a
                FredoSketch v1.6a
                Sepso84
                • LibFredo6: v15.4c
                • Fredo6 Plugins
                  FredoScale v3.6a
                  FredoSketch v1.6a
                  Sepso84
                  Thanks a lot
                    @Sepso84
                    Can you share error messages when you use your license file to activate?
                    Also having 2 accounts is not helping you. I'd suggest you request to delete the unneeded account.
                    • N Offline
                      NhaQuynh Newcomers
                      I had bought the lisense and this show up
                        @NhaQuynh Please update all extensions.
                        You are using a very old version of Sketchucation Tools which contains the licensing system.
                          rendyinterior Newcomers
                          Hi Sketchucation,
                          I just started using Fredo6 few weeks back. I was using it perfectly fine on my desktop (Windows 10) with a free account. when I try to install it on my new laptop (running Windows 11) it keep showing me it license has been expired.
                          Then I try to install fredo6 on my old laptop and it works. I believe I did the installation correctly but don't know what went wrong. I'm using FredoScale and FredoCorner.
                          Please help. Thanks in advance.
                          R 1 Reply Last reply Reply Quote 1
                            Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp on the device with the issue and copy/paste the output into your reply.
                              rendyinterior Newcomers @rendyinterior
                              Fredo6 Plugins Information on 2025-08-08 18:26:44 +0800
                              • Platform: x64-mswin64_140 - Ruby: 2.7.2
                              • Sketchup: 22.0.316
                              • LibFredo6: v15.4c
                              • Fredo6 Plugins
                                FredoCorner v2.7a
                                FredoScale v3.6a
                                Signature File: 2025-08-08 02:27:31 +0800
                                If you download your license files from https://sketchucation.com/webshop/my-licences.php and use Tools > Fredo Collection > [Plugin Name] > License... to activate.
                                Are you getting error messages?
                                R 1 Reply Last reply Reply Quote 0
                                  rendyinterior Newcomers @Rich O Brien
                                  @Rich-O-Brien
                                  I'm using free account. there is nothing in my license page. by the way, I'm installing my sketchup 2022 in drive D:. can that cause the error?
                                  Dave RD 1 Reply Last reply Reply Quote 1
                                    If you haven't bought a license then its normal to see Trial Expired.
                                    To buy licenses please visit https://sketchucation.com/plugin-list.php
                                      Dave R @rendyinterior
                                      @rendyinterior said in SCFLicense: Extension Licensing on Sketchucation:
                                      That could cause other errors with running SketchUp.
                                        @Rich-O-Brien
                                        I browse through the shop. the duration show unlimited is it means the licenses don't expire? if I get bundle of 8, I will be receiving 8 licenses and can use it on 3 devices?
                                          Rich O Brien Moderator @rendyinterior
                                          @rendyinterior
                                          Yes
                                          Yes
                                            LukasP
                                            Hello, I would like to ask for advice on how to activate the license for the purchased RoundCorner Perpetual License plugin. Unfortunately, I had to reinstall Windows, and when I tried to activate the purchased plugin again, I received the following error message (see screenshot).
                                            Thank you very much for your help.
                                            • 103
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 115
                                            • 116
                                            • 105 / 116
