    [Plugin Library] LibFredo6 - v15.6c - 10 Dec 25
    2.2k Posts 571 Posters 4.0m Views 573 Watching
      simulat
      Here is the plugin information from there. I'm not sure what is happening. I did a clean install and then used the sketchucation store to reinstall your plugins.
      Fredo6 Plugins Information on 2025-06-10 08:26:28 -0700
      • Platform: x64-mingw32 - Ruby: 2.5.5
      • Sketchup: 20.0.363
      • LibFredo6: v15.4a
      • LibFredo6 Binary loaded
      • Sketchucation ExtensionStore: 4.4.1
      • SCFLicense: v6.4a - 74
      • Fredo6 Plugins
        Signature File: 2021-07-26 12:21:00 -0700
        Curviloft: 2022-09-28 16:26:30 -0700
        Curvizard: 2022-09-28 09:28:49 -0700
        FredoCorner: 2021-07-26 13:49:18 -0700
        FredoGhost: 2021-07-26 13:50:07 -0700
        FredoScale: 2025-06-07 12:05:50 -0700
        FredoSpline: 2021-07-26 13:50:45 -0700
        JointPushPull: 2022-11-27 21:10:39 -0800
        RoundCorner: 2025-06-05 11:57:20 -0700
        ThruPaint: 2025-06-05 10:19:08 -0700
        ToolsOnSurface: 2022-11-27 21:21:28 -0800
        Gabriele Pretto Newcomers @sprocket_
        @sprocket_
        Hi same issue.
        LibFredo6
        15.4a
        13 May 25
        Info
        UP TO DATE
        ThruPaint
        2.8d
        14 May 25
        Info
        UP TO DATE
        • fredo6F Offline
          Please describe accurately what does not work. Otherwise, it is difficult to help. Possibly, open the Ruby console before launching the plugin to catch potential errors.
            sharumathiellappan29 Newcomers
            Hi Fredo,
            I need to use an older plugin that requires LibFredo6_v12.9a.rbz.
            Could you please share the download link or re-upload it? Thank you very much!
            • fredo6F Offline
              Which plugin, and for which version of Sketchup.
              In general, the version of LibFredo6 indicated is just the minimum version required. The latest version should also work.
              • fredo6F Offline
                NEW RELEASE: LibFredo6 v15.4b - 21 Jul 25
                LibFredo6 15.4b is a minor release. It includes changes related to:
                • Animator (bug in renaming positioners)
                • Other bug Fixing and technical adjustments
                • Y Offline
                  yde0128 Newcomers
                  thanks!
                  • fredo6F Offline
                    NEW RELEASE: LibFredo6 v15.4c - 01 Aug 25
                    LibFredo6 15.4c is a minor release. It includes changes related to:
                    • ToolsOnSurface (bug in image textures)
                      simulat @fredo6
                      @fredo6
                      Hi Fredo,
                      I was never able to resolve this.. I've resorted to trying to figure out how I can upgrade my sketchup and retain use of the main plugin I use (Twilight Render 2). This company and website no longer exist.
                      I found a version of twilight for sketchup 2024 on the way back machine. I can get it installed and working but the licenses I purchased for the Pro features & add ons won't activate, assuming it's tied to my old install of windows.
                      Anyway you could help me? Do you have any ideas or a direction you could point me in to help me activate this?
                      Thank you 🙏
                      ⚠ [Removed image containing private info]
                      • fredo6F Offline
                        You are in a thread about LibFredo6. I have no relation with Twilight Render.
                        • fredo6F Offline
                          NEW RELEASE: LibFredo6 v15.4d - 14 Aug 25
                          LibFredo6 15.4d is a minor release. It includes changes related to:
                          • Future compatibility
                            kngpw
                            I'm still having the issue of"ArgumentError (invalid byte sequence in UTF-8)"
                            I want to clarify that my Windows computer name has no non-roman characters. At first I thought it was related to the system language being set in both English and Thai . But the problem is still there when I'm using English only system.
                            Extension Errors Report
                            SketchUp: 24.0.594
                            OS: Windows 11
                            Ruby: 3.2.2
                            Extension: Fredo6 LibFredo6 (15.4d - 14 Aug 25)
                            Error: ArgumentError (invalid byte sequence in UTF-8)
                            c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in match' c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in block (2 levels) in load_from_config'
                            c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in each' c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in block in load_from_config'
                            c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in foreach' c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in load_from_config'
                            c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins' c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each'
                            c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins' c:/users/pchueathue/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup'
                            C:/Users/pchueathue/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/pchueathue/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                            C:/Users/pchueathue/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                            • fredo6F Offline
                              I still don't have a rational explanation for this bug which a few users have from time to time.
                              Did you touch or manipulate manually the plugin files, in particular the files with .plugin extension?
                              Can you try with LibFredo6 v15.4e, just released.
                                kngpw
                                The new update works now! Thank you!
                                  JKDEKO Newcomers
                                  Salut, je suis sur Sketchup 2024 (OS X) mais impossible d'installer votre extension. Je n'ai plus la fenêtre "préférences". Avez-vous un conseil pour m'aider svp ? Merci beaucoup.
                                  TIGT 1 Reply Last reply Reply Quote 0
                                    TIG Moderator @JKDEKO
                                    @JKDEKO
                                    If you are using Fredo's extensions you also need to install the SketchUcation Toolset which manages the licensing, and LibFredo.
                                    If you have the Toolset install you can browse and auto-install these extension/lib files without having to get an RBZ file etc.
                                    To install the Toolset download its RBZ from this link...
                                    https://sketchucation.com/pluginstore?pln=SketchUcationTools
                                    The use the Extensions > Extension Manager dialog to install it for you. Restart SketchUp to sync everything...
                                    Si vous utilisez les extensions Fredo, vous devez également installer SketchUp Toolset, qui gère les licences, ainsi que LibFredo.
                                    Si vous avez installé SketchUp Toolset, vous pouvez parcourir et installer automatiquement ces fichiers d'extension/librairie sans avoir à télécharger de fichier RBZ, etc.
                                    Pour installer SketchUp Toolset, téléchargez son RBZ depuis ce lien :
                                    Utilisez la Toolset de dialogue Extensions > Extension Manager [Gestionnaire d'extensions?] pour l'installer. Redémarrez SketchUp pour synchroniser le tout...
                                    • F Offline
                                      fastrerudy
                                      bonjour,
                                      j essaie d'intaller fredo scale sur mon sketchup 2024 mais en vain, j ai bien le pushpull etc.. mais impossible d'installer le fredo scale ou tools. j ai eu le fredo scale dans le passé mais maintenant lorsque je l'installe , pas de messages mais apparait bien dans mon gestionnaire d'extensions mais pas dans les icones ou barre de menu, pourriez vous m'aider à ce sujet? merci ! belle journée
                                      I'm trying to install Fredo Scale on my SketchUp 2024 but in vain. I have PushPull etc. but I can't install Fredo Scale or Tools. I had Fredo Scale in the past but now when I install it, no messages but it appears in my extension manager but not in the icons or menu bar. Could you help me with this? Thank you! Have a nice day.
                                        @fastrerudy Have you installed Libfredo?
                                        SketchUp Plugins | PluginStore | SketchUcation
                                        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                        (sketchucation.com)
                                        It is required for the extensions you mention.
                                        • fredo6F Offline
                                          NEW RELEASE: LibFredo6 v15.5a - 08 Oct 25
                                          LibFredo6 15.5a is a major release. It includes changes related to:
                                          • Full compatibility with SU2026
                                          alexpacio2013A 1 Reply Last reply Reply Quote 0
                                          • alexpacio2013A Offline
                                            alexpacio2013 @fredo6
                                            @fredo6 I installed this new version on sketchup 2025 and everything crashes. How can I go back to the previous version?
                                            fredo6F 1 Reply Last reply Reply Quote 0
                                            • 108
                                            • 109
                                            • 4 / 109
