    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
      MtnArch
      The call-outs for the operable sliding windows should be "XO" when the left panel is operable (as viewed from the outside) and "OX" when the right panel is operable. An "XOX" would have a fixed panel in the middle and each side panel would be operable.
      Highest Regards,
      Alan T. Hendry, RA
      Architect
      • medeekM Offline
        medeek
        Version 3.9.8 - 05.04.2025
        • Added the Connect Corner tool to the Medeek Wall Tools II toolbar.
        • Updated the Opening Copy tool with the left and right hand slider window.
        • Fixed a specific bug related to glulam columns with a vertical offset equal to the wall bottom plate thickness.
        Tutorial 69 - Connect Corner Tool (9:12 min.)
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.9.9 - 05.09.2025
          • Updated the Connect Corner tool to work with non-orthogonal walls.
          • Fixed a bug with the in-wall column tool for gable walls.
          • Enabled Advanced Framing Options within the window module.
          • Added the Advanced Framing Options parameter within the Windows tab of the global settings.
          • Fixed the callout for right handed slider (OX) windows.
          • Enabled zero stool extensions and zero stool projections for all window casing options.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 3.9.9b - 05.09.2025
            • Enabled backward compatibility with existing windows (advanced framing options).
            !!! CRITICAL BUG FIX !!!
            When I rolled this out last night I forgot to add exactly one line of code which would have made sure that all previous windows were backward compatible with the recent inclusion of the advanced framing options. Please update your installation to this latest version if you have recently installed Version 3.9.9. My apologies for this major inconvenience and my somehow missing this with the initial release of this new feature.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 4.0.0 - 05.27.2025
              • Enabled "green" pressure treated lumber in the global settings.
              • Fixed a bug with trimmer studs for trapezoid windows.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 4.0.0b - 05.28.2025
                • Enabled "green" pressure treated lumber within the stair module.
                design.medeek.com
                • gullfoG Offline
                  gullfo
                  what! no yellow board! 🙂 j.k.
                  Glenn
                  http://www.runnel.com
                  • medeekM Offline
                    medeek
                    Version 4.0.1 - 05.29.2025
                    • Added five additional layers to the Layers tab of the Global Settings for stair assemblies.
                    • Added a "Stair Layers" option into the Layers tab of the Global Settings in order to toggle the stair layers "On" or "Off".
                    Tutorial 71 - Layers/Tags for Stairs (4:02 min.)
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 4.0.2 - 06.01.2025
                      • Added a bottom gap parameter to the draw and edit menu of the door module.
                      • Added the bottom gap parameter to the door tab of the global settings.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 4.0.3 - 07.03.2025
                        • Fixed a long standing bug (06/27/2023) with the edit dimension tool for framing dimensions (rectangular walls).
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 4.0.4 - 07.13.2025
                          • Added the following steel post types to the post module: Round (HSS), Pipe (NPS).
                          I'm not sure why I never added a "pipe" option in before, I guess no one ever asked until now.
                          I will need to add more sizes but I now have the most commonly used sizes from 3" to 6" DIA.
                          design.medeek.com
                          • gullfoG Offline
                            gullfo
                            i sorta did a long while back wrt leaving space to allow me to use an i-column or steel post, but not actually requesting one 🙂 thanks!
                            Glenn
                            • medeekM Offline
                              medeek
                              Version 4.0.4b - 07.14.2025
                              • Added springfield plates to the post base and post cap libraries (for 3.5" and 4.0" pipe).
                              • Added the following Simpson post caps to the post module: LLC35_35, LCC35_4, LCC45_35, LCC45_4, LCC525_35, LCC525_4, LCC6_35, LCC6_4, LCC7_35, LCC7_4.
                              If I'm going to add in this new "pipe" post then it stands to reason that I also add some appropriate bases and caps to match.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 4.0.4c - 07.15.2025
                                • Added the following Simpson Strong-Tie holdowns to the wall, column and shearwall modules: HDUE3, HDUE5, HDUE7, HDUE9, HDUE13, HDUE17.
                                Looks like Simpson added this new replacement for the HDU holdown in May of this year. I just noticed this morning so I added them in.
                                Note that these are low poly versions of the holdowns based directly off of the geometry provided on Simpson's website.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 4.0.5 - 07.16.2025
                                  • Fixed a bug with quadruple end wall studs (applies to all wall types).
                                  • Added the following Simpson Strong-Tie pre-assembled anchor bolts to the wall, column and shearwall modules: PAB6-12, PAB6-18, PAB6-24, PAB6-30, PAB6-36, PAB7-12, PAB7-18, PAB7-24, PAB7-30, PAB7-36, PAB8-12, PAB8-18, PAB8-24, PAB8-30, PAB8-36, PAB10-12, PAB10-18, PAB10-24, PAB10-30, PAB10-36.
                                  • Added the HTTH6.5 holdown to the built-in holdown library.
                                  Note, that these anchor bolts come in five different lengths (12, 18, 24, 30 and 36). I did not add in the 1/2 and 5/8 dia. anchor bolts since this option is primarily chosen when a much larger anchor bolt is needed, but do let me know if you would like to see them added in.
                                  Just playing catch up on a number of items after spending three or so weeks on the HVAC plugin. Undoubtedly, I am spread a bit thin these days with six plugins now under active development.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 4.0.6 - 07.17.2025
                                    • Fixed a bug with gable walls.
                                    • Added the following Simpson Strong-Tie pre-assembled anchor bolts to the wall, column and shearwall modules: PAB4-12, PAB4-18, PAB4-24, PAB4-30, PAB4-36, PAB5-12, PAB5-18, PAB5-24, PAB5-30, PAB5-36, PAB9-12, PAB9-18, PAB9-24, PAB9-30, PAB9-36.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 4.0.7 - 07.20.2025
                                      • Enabled the polyline draw mode for all wall justification options: Front, Center, Back, Sheathing.
                                      Tutorial 72 - Wall Justification (7:16 min.)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        mdkBIM Tutorial 6 - Building a Ham Shack
                                        My initial concept of the ultimate Ham Shack (16' x 12') designed in SketchUp using the Medeek extensions.
                                        The model can be found here:
                                        3D Warehouse
                                        (3dwarehouse.sketchup.com)
                                        My call sign is KK7UXO, but I don't get on the radio much, mostly I'm programming. :slight_smile:
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Per customer request I will add in an LSL option for the framing very shortly:
                                          I'm using the updated LSL texture I created for the Floor plugin, but I still feel like it is a bit dull or dark compared to my previous texture (OSB). It could be a bit more vibrant or saturated. I will need to spend some more time on this.
                                          Weyerhaeuser sells their Timberstrand line of LSL framing and studs:
                                          TimberStrand® LSL Wall Framing & Studs
                                          Picks up framing where the code stops
                                          (www.weyerhaeuser.com)
                                          However, I would always worry about water damage. What happens if the LSL gets wet? We all know what happens to OSB, and plywood is a much more robust product in comparison. Standard lumber seems like a much more resilient choice when it comes to potential water damage, but I could be wrong.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Some Youtube viewers of this video reached out and told me that they had more equipment than could reasonably fit within such a small structure. I agree, maybe a 16'x12' space is a bit cramped for anyone, especially if you are also using it for a content creation studio. This is where the parametrics of the extensions come in real handy:
                                            The model(s) can be viewed and downloaded here:
                                            3D Warehouse
                                            design.medeek.com
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 75
                                            • 76
                                            • 56 / 76
