    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • medeekM Offline
      medeek
      Here are a some new renderings of an Inverted Tee landing using the newly upgraded stair module. A huge shout out to @patrick.c.obrien for these amazing images and for all of his efforts in helping me debug this module during the month long process of updates and additions:
      Example 1 Inv-T stair assembly.png Example 2 Inv-T stair assembly.png Example 3 Inv-T stair assembly.png Example 4 Inv-T stair assembly.png
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.9.3 - 03.29.2025
        • Added the following Simpson Strong-Tie holdowns to the wall, column and shearwall modules: DTT1Z, LTTP2, LTTI31.
        • Added the following Simpson Strong-Tie holdowns to the wall, column and shearwall modules: HD3B, HD5B, HD7B, HD9B, HD12, HD19.
        • Updated the wall and column modules so that they include all previous holdowns that were added to the shearwall module.
        This update per customer request.
        I think I now have added every common holdown used for walls and columns that is found in the Simpson Catalog [Wood Construction Connectors 2024-2025] (pg. 51-65).
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.9.4 - 04.04.2025
          • Added the following Simpson Strong-Tie header hangers to the door module: HH4, HH6.
          • Enabled header hangers for all door headers.
          Note that Simpson only manufactures two standard header hanger sizes (HH4 and HH6). However there are quite a few more options for CFS framing. If there is any interest I can add those hangers as well upon request.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 3.9.5 - 04.19.2025
            • Enabled a zero thickness apron for style B window casing.
            • Included additional logic for vertically offset sheathing and cladding.
            Both of these updates per customer request.
            I have been taking care of some miscellaneous items on my todo lists for both the Truss and Wall plugin before I dive back down the rabbit hole that is currently the Floor plugin. Once I jump back into that one I may not emerge again for a couple months so I thought it best that I take care of a few requests first.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 3.9.6 - 04.19.2025
              • Added a "Union Door Gypsum" and "Union Window Gypsum" option into the Sheathing tab of the Global Settings.
              • Enabled "seamless" gypsum for gypsum wrapped windows and doors.
              Note the difference between the two windows below:
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.9.7 - 04.30.2025
                • Added a "Chord Angle" output parameter for arched doors and windows within their respective HTML menus.
                • Added glulam and steel columns into the in-wall column module for all wall types.
                • Enabled a wood grain and an end grain material for glulam columns within the in-wall column module.
                • Added a "right" hand slider window and updated the existing slider name to be a "left" hand slider window.
                design.medeek.com
                  MtnArch
                  The call-outs for the operable sliding windows should be "XO" when the left panel is operable (as viewed from the outside) and "OX" when the right panel is operable. An "XOX" would have a fixed panel in the middle and each side panel would be operable.
                  Highest Regards,
                  Alan T. Hendry, RA
                  Architect
                  • medeekM Offline
                    medeek
                    Version 3.9.8 - 05.04.2025
                    • Added the Connect Corner tool to the Medeek Wall Tools II toolbar.
                    • Updated the Opening Copy tool with the left and right hand slider window.
                    • Fixed a specific bug related to glulam columns with a vertical offset equal to the wall bottom plate thickness.
                    Tutorial 69 - Connect Corner Tool (9:12 min.)
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.9.9 - 05.09.2025
                      • Updated the Connect Corner tool to work with non-orthogonal walls.
                      • Fixed a bug with the in-wall column tool for gable walls.
                      • Enabled Advanced Framing Options within the window module.
                      • Added the Advanced Framing Options parameter within the Windows tab of the global settings.
                      • Fixed the callout for right handed slider (OX) windows.
                      • Enabled zero stool extensions and zero stool projections for all window casing options.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.9.9b - 05.09.2025
                        • Enabled backward compatibility with existing windows (advanced framing options).
                        !!! CRITICAL BUG FIX !!!
                        When I rolled this out last night I forgot to add exactly one line of code which would have made sure that all previous windows were backward compatible with the recent inclusion of the advanced framing options. Please update your installation to this latest version if you have recently installed Version 3.9.9. My apologies for this major inconvenience and my somehow missing this with the initial release of this new feature.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 4.0.0 - 05.27.2025
                          • Enabled "green" pressure treated lumber in the global settings.
                          • Fixed a bug with trimmer studs for trapezoid windows.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 4.0.0b - 05.28.2025
                            • Enabled "green" pressure treated lumber within the stair module.
                            design.medeek.com
                            • gullfoG Offline
                              gullfo
                              what! no yellow board! πŸ™‚ j.k.
                              Glenn
                              http://www.runnel.com
                              • medeekM Offline
                                medeek
                                Version 4.0.1 - 05.29.2025
                                • Added five additional layers to the Layers tab of the Global Settings for stair assemblies.
                                • Added a "Stair Layers" option into the Layers tab of the Global Settings in order to toggle the stair layers "On" or "Off".
                                Tutorial 71 - Layers/Tags for Stairs (4:02 min.)
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 4.0.2 - 06.01.2025
                                  • Added a bottom gap parameter to the draw and edit menu of the door module.
                                  • Added the bottom gap parameter to the door tab of the global settings.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 4.0.3 - 07.03.2025
                                    • Fixed a long standing bug (06/27/2023) with the edit dimension tool for framing dimensions (rectangular walls).
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 4.0.4 - 07.13.2025
                                      • Added the following steel post types to the post module: Round (HSS), Pipe (NPS).
                                      I'm not sure why I never added a "pipe" option in before, I guess no one ever asked until now.
                                      I will need to add more sizes but I now have the most commonly used sizes from 3" to 6" DIA.
                                      design.medeek.com
                                      • gullfoG Offline
                                        gullfo
                                        i sorta did a long while back wrt leaving space to allow me to use an i-column or steel post, but not actually requesting one πŸ™‚ thanks!
                                        Glenn
                                        • medeekM Offline
                                          medeek
                                          Version 4.0.4b - 07.14.2025
                                          • Added springfield plates to the post base and post cap libraries (for 3.5" and 4.0" pipe).
                                          • Added the following Simpson post caps to the post module: LLC35_35, LCC35_4, LCC45_35, LCC45_4, LCC525_35, LCC525_4, LCC6_35, LCC6_4, LCC7_35, LCC7_4.
                                          If I'm going to add in this new "pipe" post then it stands to reason that I also add some appropriate bases and caps to match.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 4.0.4c - 07.15.2025
                                            • Added the following Simpson Strong-Tie holdowns to the wall, column and shearwall modules: HDUE3, HDUE5, HDUE7, HDUE9, HDUE13, HDUE17.
                                            Looks like Simpson added this new replacement for the HDU holdown in May of this year. I just noticed this morning so I added them in.
                                            Note that these are low poly versions of the holdowns based directly off of the geometry provided on Simpson's website.
                                            design.medeek.com
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 79
                                            • 80
                                            • 73 / 80
