    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      Version 4.0.0 - 05.27.2025
      • Enabled "green" pressure treated lumber in the global settings.
      • Fixed a bug with trimmer studs for trapezoid windows.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 4.0.0b - 05.28.2025
        • Enabled "green" pressure treated lumber within the stair module.
        design.medeek.com
        • gullfoG
          gullfo
          what! no yellow board! 🙂 j.k.
          Glenn
          http://www.runnel.com
          • medeekM
            medeek
            Version 4.0.1 - 05.29.2025
            • Added five additional layers to the Layers tab of the Global Settings for stair assemblies.
            • Added a "Stair Layers" option into the Layers tab of the Global Settings in order to toggle the stair layers "On" or "Off".
            Tutorial 71 - Layers/Tags for Stairs (4:02 min.)
            design.medeek.com
            • medeekM
              medeek
              Version 4.0.2 - 06.01.2025
              • Added a bottom gap parameter to the draw and edit menu of the door module.
              • Added the bottom gap parameter to the door tab of the global settings.
              design.medeek.com
              • medeekM
                medeek
                Version 4.0.3 - 07.03.2025
                • Fixed a long standing bug (06/27/2023) with the edit dimension tool for framing dimensions (rectangular walls).
                design.medeek.com
                • medeekM
                  medeek
                  Version 4.0.4 - 07.13.2025
                  • Added the following steel post types to the post module: Round (HSS), Pipe (NPS).
                  I'm not sure why I never added a "pipe" option in before, I guess no one ever asked until now.
                  I will need to add more sizes but I now have the most commonly used sizes from 3" to 6" DIA.
                  design.medeek.com
                  • gullfoG
                    gullfo
                    i sorta did a long while back wrt leaving space to allow me to use an i-column or steel post, but not actually requesting one 🙂 thanks!
                    Glenn
                    • medeekM
                      medeek
                      Version 4.0.4b - 07.14.2025
                      • Added springfield plates to the post base and post cap libraries (for 3.5" and 4.0" pipe).
                      • Added the following Simpson post caps to the post module: LLC35_35, LCC35_4, LCC45_35, LCC45_4, LCC525_35, LCC525_4, LCC6_35, LCC6_4, LCC7_35, LCC7_4.
                      If I'm going to add in this new "pipe" post then it stands to reason that I also add some appropriate bases and caps to match.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 4.0.4c - 07.15.2025
                        • Added the following Simpson Strong-Tie holdowns to the wall, column and shearwall modules: HDUE3, HDUE5, HDUE7, HDUE9, HDUE13, HDUE17.
                        Looks like Simpson added this new replacement for the HDU holdown in May of this year. I just noticed this morning so I added them in.
                        Note that these are low poly versions of the holdowns based directly off of the geometry provided on Simpson's website.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 4.0.5 - 07.16.2025
                          • Fixed a bug with quadruple end wall studs (applies to all wall types).
                          • Added the following Simpson Strong-Tie pre-assembled anchor bolts to the wall, column and shearwall modules: PAB6-12, PAB6-18, PAB6-24, PAB6-30, PAB6-36, PAB7-12, PAB7-18, PAB7-24, PAB7-30, PAB7-36, PAB8-12, PAB8-18, PAB8-24, PAB8-30, PAB8-36, PAB10-12, PAB10-18, PAB10-24, PAB10-30, PAB10-36.
                          • Added the HTTH6.5 holdown to the built-in holdown library.
                          Note, that these anchor bolts come in five different lengths (12, 18, 24, 30 and 36). I did not add in the 1/2 and 5/8 dia. anchor bolts since this option is primarily chosen when a much larger anchor bolt is needed, but do let me know if you would like to see them added in.
                          Just playing catch up on a number of items after spending three or so weeks on the HVAC plugin. Undoubtedly, I am spread a bit thin these days with six plugins now under active development.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 4.0.6 - 07.17.2025
                            • Fixed a bug with gable walls.
                            • Added the following Simpson Strong-Tie pre-assembled anchor bolts to the wall, column and shearwall modules: PAB4-12, PAB4-18, PAB4-24, PAB4-30, PAB4-36, PAB5-12, PAB5-18, PAB5-24, PAB5-30, PAB5-36, PAB9-12, PAB9-18, PAB9-24, PAB9-30, PAB9-36.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 4.0.7 - 07.20.2025
                              • Enabled the polyline draw mode for all wall justification options: Front, Center, Back, Sheathing.
                              Tutorial 72 - Wall Justification (7:16 min.)
                              design.medeek.com
                              • medeekM
                                medeek
                                mdkBIM Tutorial 6 - Building a Ham Shack
                                My initial concept of the ultimate Ham Shack (16' x 12') designed in SketchUp using the Medeek extensions.
                                The model can be found here:
                                3D Warehouse
                                (3dwarehouse.sketchup.com)
                                My call sign is KK7UXO, but I don't get on the radio much, mostly I'm programming. :slight_smile:
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Per customer request I will add in an LSL option for the framing very shortly:
                                  I'm using the updated LSL texture I created for the Floor plugin, but I still feel like it is a bit dull or dark compared to my previous texture (OSB). It could be a bit more vibrant or saturated. I will need to spend some more time on this.
                                  Weyerhaeuser sells their Timberstrand line of LSL framing and studs:
                                  TimberStrand® LSL Wall Framing & Studs
                                  Picks up framing where the code stops
                                  (www.weyerhaeuser.com)
                                  However, I would always worry about water damage. What happens if the LSL gets wet? We all know what happens to OSB, and plywood is a much more robust product in comparison. Standard lumber seems like a much more resilient choice when it comes to potential water damage, but I could be wrong.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Some Youtube viewers of this video reached out and told me that they had more equipment than could reasonably fit within such a small structure. I agree, maybe a 16'x12' space is a bit cramped for anyone, especially if you are also using it for a content creation studio. This is where the parametrics of the extensions come in real handy:
                                    The model(s) can be viewed and downloaded here:
                                    3D Warehouse
                                    design.medeek.com
                                    Reply Quote 2
                                    • gullfoG
                                      gullfo
                                      yeah, definitely depends on the gear a content creator needs. many will simply need a good computer, possible a good music keyboard or two, good video monitors, good audio monitors, and fresh air. many would fit into a 9x11 room but more would be better in a 12.4' W x 15' L due to best ratio for acoustics assuming 8' H ceiling.
                                      Glenn
                                      • medeekM
                                        medeek
                                        Version 4.0.8 - 07.25.2025
                                        • Enabled LSL as a wall framing material.
                                        • Updated the material textures for LSL and PSL.
                                        These don't seem like major updates however there are numerous places within the plugin that required updating and also during the process I was able to further refine and compress the code so it is now more efficient and better organized. Updates were made to the following modules: Walls, Stairs, Columns, Beams, Posts and Shearwalls.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 4.1.0 - 07.28.2025
                                          • Added the following Simpson "Sage" post caps and bases to the post module: SAGE_B66, SAGE_C66, SAGE_T66
                                          • Fixed a critical bug for custom materials within the stair module.
                                          • Updated all of the move tools with upgraded wireframe previews and dimensions.
                                          • Updated the window, door and garage door draw tools with a filled wireframe preview.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 4.1.1 - 08.17.2025
                                            • Added Fixed - Slider (L) and Fixed - Slider (R) windows to the window module.
                                            These two window types added per customer request.
                                            design.medeek.com
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 80
                                            • 81
                                            • 73 / 81
