    šŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    471 Posts 89 Posters 339.6k Views 88 Watching
    • fredo6F Offline
      fredo6 @fredo6
      @fredo6
      Go to the menu Tools > Fredo6 Collection > LordOfTheToolbars.
      Can you try Reset the Vignette Stripe Position, after you moved Sketchup to the other monitor.
      Note that there is no event received by the API when you move Sketchup between monitors. So, you cannot expect that the dialogs would follow.
      M 1 Reply Last reply Reply Quote 0
        Mike Backman @fredo6
        @fredo6
        none of that works,
        I can not get the viett onto the big monitor unless it is the "main display"
        • F Offline
          FlorinAp @fredo6
          @fredo6 This solution doesn't work for palettes. If you previously had a palettes opened on a second monitor (or on the right edge of a monitor with a bigger resolution than the current one - which was my case.!), then that palettes is lost (even with the option "Reset Workspace" from SU Preferences).
          The only way I could bring it back was with Dan Rathbun extension "Dialog Cascader" (and maybe it could also worked with Flex Tools "Lost and Found Windows".
            Kalix360 Newcomers
            In SketchUp2025, for the Menu method, I don't seem to get the commands list populated, I can't search for one and there is nothing to select... does anyone else have this problem or am I doing something wrong? Thank You.
            • fredo6F Offline
              Menu commands are no longer supported on Windows since SU2023 (due to a change in the Sketchup UI framework).
                deadforest Newcomers
                Cleanscreen on vignette stripe, history is gone, is there a way to recover it?
                I want to completely initialize the plug-in because the data is still there even after I delete and reinstall it, how do I do it?
                • fredo6F Offline
                  CleanScreen is no longer supported as of SU2023.
                  You may have a problem of installation if you do not see the History icon in the Vignette Stripe.
                  You can reset all data with the menu Tools > Fredo6 Collection > Lord Of The Toolbars > Reset All...
                  • Z Offline
                    ZeroCZ
                    I’d like to ask for some advice. I have a subscription for SU 2025, but I haven’t fully switched to using it yet because I can’t work in it as efficiently as I can in SU 2024. The reason is that I haven’t been able to get the LordOfTheToolbars plugin to work properly. I can’t import my toolbar settings from the previous version into it. In the window where you’re supposed to select items to import to the new version, there’s no confirmation button visible—it looks like the bottom part of the window is missing. I can’t resize, maximize, or adjust the window in any way to make the confirmation button appear.
                    Additionally, this plugin causes another issue: when I close SU, the positions of my other toolbars aren’t saved, and when I reopen the program, all toolbars are stacked on top of each other. When I uninstall the plugin, this problem no longer occurs.
                    Does anyone know what could be causing this and how to possibly fix it? Thank you very much for your help. Cheers!
                      rv1974
                      @fredo6 Maybe I'm missing something, but I can't preserve any change in Sketchup's UI when LOTT is installed.
                      Example: I install some plugins, then CLOSE their toolbars, restart SU but closed toolbars are still shown. The only workaround is to make the needed changes with toolbars while !!Fredo6_LordOfTheToolbars.rb file is being deleted\renamed in the Plugins folder. This way toolbar visibility is preserved (except pesky LOTT toolbar - it always gets back) But it's kinda barbaric and its not supposed to work this way.
                      Any hints\comments?
                      P.S. Another glitch - SU starts on the wrong display and its impossible to make it start on the proper one. The "cure" is the same - delete LOTT, restart SU on the right display, reinstall LOTT.
                      Update: If I close the LOTT toolbar, immediately afterwards I replace all plugin files in the Plugins folder, then close and restart SU, - only this way I'm able to get rid of this toolbar (and I suppose, all the rest)
                      • H Offline
                        haymaker
                        Hi Fredo
                        I have upgraded to 2025 SU. How do I get the new SU 2025 icons to show up in the Master tool bar manager, they are still showing up as SU2022 icons?
                        Mike
                        • fredo6F Offline
                          For the native tools, I did not change the icons. So you get the old ones. I don't think I will update them.
                            AISmebel
                            Hi Fredo, I installed SketchUp 2026 and I can't click on the import icon to import toolbars. It also didn't work through the menu. Reinstalling the plugin did not help. Is it expected to be compatible with SketchUp 2026?
                            • fredo6F Offline
                              Did you upgrade to LibFredo6 v15.5a.
                                Ramzix
                                Hey I have Sketchup 2026 problem too. I have newest version of Libfredo 15.5a. My LOTT settings are default.
                                1. First button from the left, the one with 9 dots doesn't do anything
                                2. This is an old issue when vignette stripe keeps going back to the same left spot on relaunch.
                                3. Favorites pop out on the left side of the screen, bigger ones stretch beyond the screen.
                                I would be really thankful for any help 😊. I 'd not care that much about LOTT if I had not think this is the extension of them all ;).
                                C 1 Reply Last reply Reply Quote 0
                                  celovito @Ramzix
                                  @Ramzix
                                  Same problem here! Fredo help! šŸ™‚
                                  • fredo6F Offline
                                    Can you move the vignette stripe by Click-Drag?
                                      Ramzix
                                      Hi @fredo6 pardon my late response. Indeed I can freely move the vingette stripe. However right clicking it does not do anything
                                        Ramzix
                                        here the link to see how it behaves on my laptop
                                        alt text
                                        • fredo6F Offline
                                          Do you have several monitors?
                                            CGMen
                                            Hi everyone,
                                            I’ve noticed some odd behavior in SketchUp 2026.
                                            If I delete the folder of any Fredo6 plugin — for example, Fredo6_VisuHole — from the SketchUp Plugins directory in Roaming (only the folder, not the main RB/executable file), SketchUp throws the following error on startup:
                                            ā€œInstallation of Fredo6_VisuHole is probably incorrect. Subfolder is missing.ā€
                                            What’s strange is that LOTT and Vignette still work fine after this. It doesn’t matter which Fredo6 plugin folder I remove — the same thing happens.
                                            When I restore the deleted folder, SketchUp starts normally again, but then the behavior becomes the same as what Ramzix described earlier.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 23 / 24
