    [Plugin] LordOfTheToolbars - v3.0a - 21 Apr 26
    507 Posts 98 Posters 521.7k Views 96 Watching
      rv1974
      @fredo6 Maybe I'm missing something, but I can't preserve any change in Sketchup's UI when LOTT is installed.
      Example: I install some plugins, then CLOSE their toolbars, restart SU but closed toolbars are still shown. The only workaround is to make the needed changes with toolbars while !!Fredo6_LordOfTheToolbars.rb file is being deleted\renamed in the Plugins folder. This way toolbar visibility is preserved (except pesky LOTT toolbar - it always gets back) But it's kinda barbaric and its not supposed to work this way.
      Any hints\comments?
      P.S. Another glitch - SU starts on the wrong display and its impossible to make it start on the proper one. The "cure" is the same - delete LOTT, restart SU on the right display, reinstall LOTT.
      Update: If I close the LOTT toolbar, immediately afterwards I replace all plugin files in the Plugins folder, then close and restart SU, - only this way I'm able to get rid of this toolbar (and I suppose, all the rest)
      • H
        haymaker
        Hi Fredo
        I have upgraded to 2025 SU. How do I get the new SU 2025 icons to show up in the Master tool bar manager, they are still showing up as SU2022 icons?
        Mike
        • fredo6F
          For the native tools, I did not change the icons. So you get the old ones. I don't think I will update them.
            AISmebel
            Hi Fredo, I installed SketchUp 2026 and I can't click on the import icon to import toolbars. It also didn't work through the menu. Reinstalling the plugin did not help. Is it expected to be compatible with SketchUp 2026?
            • fredo6F
              Did you upgrade to LibFredo6 v15.5a.
                Ramzix
                Hey I have Sketchup 2026 problem too. I have newest version of Libfredo 15.5a. My LOTT settings are default.
                1. First button from the left, the one with 9 dots doesn't do anything
                2. This is an old issue when vignette stripe keeps going back to the same left spot on relaunch.
                3. Favorites pop out on the left side of the screen, bigger ones stretch beyond the screen.
                I would be really thankful for any help ๐Ÿ˜Š. I 'd not care that much about LOTT if I had not think this is the extension of them all ;).
                C 1 Reply Last reply
                • C
                  celovito @Ramzix
                  @Ramzix
                  Same problem here! Fredo help! ๐Ÿ™‚
                  • fredo6F
                    Can you move the vignette stripe by Click-Drag?
                      Ramzix
                      Hi @fredo6 pardon my late response. Indeed I can freely move the vingette stripe. However right clicking it does not do anything
                        Ramzix
                        here the link to see how it behaves on my laptop
                        alt text
                        • fredo6F
                          Do you have several monitors?
                          • C
                            CGMen
                            Hi everyone,
                            Iโ€™ve noticed some odd behavior in SketchUp 2026.
                            If I delete the folder of any Fredo6 plugin โ€” for example, Fredo6_VisuHole โ€” from the SketchUp Plugins directory in Roaming (only the folder, not the main RB/executable file), SketchUp throws the following error on startup:
                            โ€œInstallation of Fredo6_VisuHole is probably incorrect. Subfolder is missing.โ€
                            Whatโ€™s strange is that LOTT and Vignette still work fine after this. It doesnโ€™t matter which Fredo6 plugin folder I remove โ€” the same thing happens.
                            When I restore the deleted folder, SketchUp starts normally again, but then the behavior becomes the same as what Ramzix described earlier.
                              Ramzix
                              nope, just a small laptop
                              • F
                                FlorinAp
                                There is a very old bug, the Vignette Stripe doesn't stay where you put it - after SU restart, it will reset its position to the default, whether you lock it or not, it will do the same thing.
                                And another one (but i think this one may not have a solution), i have two Favorites Palettes that i use in compact mode as toolbars (horizontal stripes, permanently open), every time you minimize and maximize the SU window, these Palettes navigate about 1-2 mm to the left, until eventually you have to move them back..., and so on.
                                Also, the same behaviour if they are locked or unlocked.
                                I use mainly SU 2023, in W11.
                                None of this happened in SU 2022 (and SU 2023), before the LOTT update to be fully compatible with SU 2024.
                                • F
                                  FlorinAp
                                  There is no reliable way to set more than 20 columns per palette, fixed (non-scrollable).
                                  F 1 Reply Last reply
                                  • F
                                    FlorinAp @FlorinAp
                                    I ended up using palettes as toolbars, only because regular toolbars created with LOTT, if undocked, all end up vertically when you restart SketchUp.
                                    But then i realized that palettes are nicer and cleaner as toolbars, than regular toolbars...
                                    • O
                                      optimaforever
                                      Is there a reason LOTT stopped loading during startup of SU today?
                                      • fredo6F
                                        Which version do you have?
                                        O 1 Reply Last reply
                                        • O
                                          optimaforever @fredo6
                                          @fredo6 2.9C
                                          • O
                                            optimaforever
                                            Ah I've found the culprit. I forgot I had installed an update for D5 Livesync 1.7.0.0001 There seems to be a problem with this one. I rolled back to D5 1.6 and LOTT is back.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 23 / 26
