    [Plugin] LordOfTheToolbars - v4.0a - 22 Sep 26
    529 Posts 101 Posters 588.5k Views 99 Watching
      Mike Backman @fredo6
      @fredo6 Nothing happens with the Ruby console for moving icons .
      also the bigger problem is needing to make my external monitor the "main" monitor. This really screws up my laptop for when I'm not in my office
      • F
        FlorinAp @Mike Backman
        @Mike-Backman Sorry to say it (this being also a reply for many of your posts), but you don't know how to use your OS, and as such you shouldn't be allowed to use any other app.!
        M 1 Reply Last reply
        Reply Quote -1
          Mike Backman @FlorinAp
          @FlorinAp DUDE BE HELPFULL!!OR DONT SAY ANYTHING!
          Reply Quote -1
          • fredo6F
            For the monitors, do you have the stickiness option activated in the Default Parameters. This forces the vignette stripe to follow the main Sketchup window.
            For the issue when moving icons between palettes, I cannot reproduce it on SU2024, and latest versions of LibFredo6 and LOTT.
            Are you sure you do not get errors in the Ruby console?
            What happens if you move an icon to an empty palette?
            M 2 Replies Last reply
              @fredo6 I do have the stickiness tab checked
              And When I create a new palette No matter what I do I am limited by the amount of plugins I can put into that new palette LOTT Prob.mp4
              fredo6F 1 Reply Last reply
                @fredo6
                I just saw that I had the default for new pallets set to 10 and not higher b5b204cd-1950-406c-9a9e-2810b0c578ed-image.png
                Still fighting with the "make this my main window" in display setting. Still don't know how to adjust the "dots per inch setting" or DPI as referred by the girl in the previous reply.
                • fredo6F
                  fredo6 @Mike Backman
                  @Mike-Backman
                  Can you try with a NEW palette.
                  In the video, you already have icons in the palette. How did you insert them ?
                  M fredo6F 2 Replies Last reply
                    @fredo6 I told you in the previous reply I figures out the Limited Pallet size was because I had the Maximum number of icons for favorites set to 10 for some reason.
                    I'm still struggling with the Monitor connection. I cannot get the vignette strip to jump on my secondary monitor. un less it is made the "main display
                    . Untitled video (2).mp4
                    • fredo6F
                      fredo6 @fredo6
                      @fredo6
                      Go to the menu Tools > Fredo6 Collection > LordOfTheToolbars.
                      Can you try Reset the Vignette Stripe Position, after you moved Sketchup to the other monitor.
                      Note that there is no event received by the API when you move Sketchup between monitors. So, you cannot expect that the dialogs would follow.
                        @fredo6
                        none of that works,
                        I can not get the viett onto the big monitor unless it is the "main display"
                        • F
                          FlorinAp @fredo6
                          @fredo6 This solution doesn't work for palettes. If you previously had a palettes opened on a second monitor (or on the right edge of a monitor with a bigger resolution than the current one - which was my case.!), then that palettes is lost (even with the option "Reset Workspace" from SU Preferences).
                          The only way I could bring it back was with Dan Rathbun extension "Dialog Cascader" (and maybe it could also worked with Flex Tools "Lost and Found Windows".
                          • K
                            Kalix360 Newcomers
                            In SketchUp2025, for the Menu method, I don't seem to get the commands list populated, I can't search for one and there is nothing to select... does anyone else have this problem or am I doing something wrong? Thank You.
                            • fredo6F
                              Menu commands are no longer supported on Windows since SU2023 (due to a change in the Sketchup UI framework).
                                deadforest Newcomers
                                Cleanscreen on vignette stripe, history is gone, is there a way to recover it?
                                I want to completely initialize the plug-in because the data is still there even after I delete and reinstall it, how do I do it?
                                • fredo6F
                                  CleanScreen is no longer supported as of SU2023.
                                  You may have a problem of installation if you do not see the History icon in the Vignette Stripe.
                                  You can reset all data with the menu Tools > Fredo6 Collection > Lord Of The Toolbars > Reset All...
                                  • Z
                                    ZeroCZ
                                    I’d like to ask for some advice. I have a subscription for SU 2025, but I haven’t fully switched to using it yet because I can’t work in it as efficiently as I can in SU 2024. The reason is that I haven’t been able to get the LordOfTheToolbars plugin to work properly. I can’t import my toolbar settings from the previous version into it. In the window where you’re supposed to select items to import to the new version, there’s no confirmation button visible—it looks like the bottom part of the window is missing. I can’t resize, maximize, or adjust the window in any way to make the confirmation button appear.
                                    Additionally, this plugin causes another issue: when I close SU, the positions of my other toolbars aren’t saved, and when I reopen the program, all toolbars are stacked on top of each other. When I uninstall the plugin, this problem no longer occurs.
                                    Does anyone know what could be causing this and how to possibly fix it? Thank you very much for your help. Cheers!
                                      rv1974
                                      @fredo6 Maybe I'm missing something, but I can't preserve any change in Sketchup's UI when LOTT is installed.
                                      Example: I install some plugins, then CLOSE their toolbars, restart SU but closed toolbars are still shown. The only workaround is to make the needed changes with toolbars while !!Fredo6_LordOfTheToolbars.rb file is being deleted\renamed in the Plugins folder. This way toolbar visibility is preserved (except pesky LOTT toolbar - it always gets back) But it's kinda barbaric and its not supposed to work this way.
                                      Any hints\comments?
                                      P.S. Another glitch - SU starts on the wrong display and its impossible to make it start on the proper one. The "cure" is the same - delete LOTT, restart SU on the right display, reinstall LOTT.
                                      Update: If I close the LOTT toolbar, immediately afterwards I replace all plugin files in the Plugins folder, then close and restart SU, - only this way I'm able to get rid of this toolbar (and I suppose, all the rest)
                                      • H
                                        haymaker
                                        Hi Fredo
                                        I have upgraded to 2025 SU. How do I get the new SU 2025 icons to show up in the Master tool bar manager, they are still showing up as SU2022 icons?
                                        Mike
                                        • fredo6F
                                          For the native tools, I did not change the icons. So you get the old ones. I don't think I will update them.
                                            AISmebel
                                            Hi Fredo, I installed SketchUp 2026 and I can't click on the import icon to import toolbars. It also didn't work through the menu. Reinstalling the plugin did not help. Is it expected to be compatible with SketchUp 2026?
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 23 / 27
