    Medeek Floor
    143 Posts 6 Posters 12.1k Views 5 Watching
    • gullfoG Offline
      gullfo
      i think the one double on the right side needs to extend to the next joist. the trimmer is ok where it is to size the opening, but structurally always best to have the joists and headers linked.
      Glenn
      http://www.runnel.com
      • medeekM Offline
        medeek
        Version 1.0.4 - 05.26.2025
        • Enabled joist hangers for openings.
        Tutorial 24 - Joist Hangers and Openings (7:58 min.)
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.0.5 - 05.30.2025
          • Added the ability to stretch opening headers with the "Stretch Floor Header" tool.
          Tutorial 25 - Stretching Opening Headers (7:50 min.)
          design.medeek.com
          • gullfoG Offline
            gullfo
            i think this is a good solution - otherwise you'd have to do all the other computations for where existing parallel joists are located. whereas here, you let the user crate the extensions on the header as needed or desired. cheers!
            Glenn
            • medeekM Offline
              medeek
              Version 1.0.6 - 05.31.2025
              • Added an edit function to the "Stretch Floor Header" tool.
              • Added a "Timber" header type for floor openings.
              • Fixed minor bugs in the floor opening module.
              design.medeek.com
              • medeekM Offline
                medeek
                Tutorial 26 - Editing Opening Headers (5:00 min.)
                design.medeek.com
                • medeekM Offline
                  medeek
                  After a full day of tinkering and refactoring a bunch of the original floor truss code I think I now have the multi-chase algorithm working:
                  Note how the chases all line up even though there are five or six different truss profiles within this assembly. I still need to create the web generator between the central sections of the truss profile, there is quite a bit going on here. I am still a few days out from completing the programming and then another two or three days of testing and further debugging.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Looks like Iโ€™m about 95% there with floor trusses:
                    The only issue appears to be what happens when ribbon boards are enabled and you have an inside corner as shown. I probably need to add in some additional logic to eliminate the slot for the ribbon board in these cases.
                    design.medeek.com
                    • gullfoG Offline
                      gullfo
                      looking good. also - there is some "clumping" of members on the left-hand side of the right-hand chase. likely due to having a second change and the sizing of the middle truss members (maybe instead a long one and clumped one, make two even one as i think this is how they would be manufactured)
                      Glenn
                      • medeekM Offline
                        medeek
                        Version 1.0.7 - 06.06.2025
                        • Enabled MPC Wood Trusses with ribbon boards, multiple chases and gable trusses.
                        • Updated the Move Floor Edge tool so that it also toggles the metal plate connector layer.
                        • Update the SUBTRACT_JOIST feature so that it can adequately handle MPC wood trusses.
                        Tutorial 27 - MPC Wood Trusses (13:25 min.)
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.0.8 - 06.08.2025
                          • Updated the SUBTRACT and SUBTRACT_JOIST features so that they can better handle MPC wood trusses, steel trusses and open web "Redbuilt" trusses.
                          • Updated the Floor Opening module so that it can handle MPC wood trusses, steel trusses and open web "Redbuilt" trusses.
                          • Added a "None" option for the header type in the draw and edit menus for floor openings.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            In many cases when you introduce a stairwell opening into a floor like this it will be along the perimeter of the floor assembly as shown. In these cases it is simpler to create your floor perimeter with the opening in mind:
                            Note, in order to create the additional gable truss (2x6 ply) I first changed my ply width to 5.5" then copied the gable truss at the interior of the stair well, then pasted it in place in the root of the model and then edited the floor assembly back to the typical 3.5" ply width. Alternatively one could simply frame this small pony wall with the Wall plugin (ie. conventional framing) just as easily.
                            I'm not exactly sure how the trusses would work where the LVL beam/header is positioned at the start of the stairwell, obviously we would need some kind of header at that location.
                            Here is a link to the model for those who are interested in examining this floor truss example in more detail:
                            3D Warehouse
                            (3dwarehouse.sketchup.com)
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.0.9 - 06.17.2025
                              • Added the floor truss toolbar with the following two items: Draw Beam Pocket, Delete Beam Pocket.
                              • Enabled beam pockets for MPC wood trusses.
                              • Fixed a bug with short span steel trusses.
                              Tutorial 28 - Beam Pockets with Floor Trusses (8:00 min.)
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.1.0 - 12.11.2025
                                • Updated the file/component loading method for hangers and certain joist types to increase plugin performance.
                                • Fixed multiple bugs with CFS joists.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.1.1 - 12.15.2025
                                  • Added the following face mount Simpson hangers into the built-in library: THA422, THA422_2, THAC422, THAC422_2.
                                  • Added the following top flange Simpson hangers into the built-in library: WP48, WP410, WP412, WP414, WP416, HWP156, HWP356.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.1.2 - 01.02.2026
                                    • Fixed bugs with saving floor presets
                                    Thank-you to all those who are sending in bug reports. Please keep sending those in, they are very helpful and I am able to track down and put out the little fires that much more quickly.
                                    If you think you have encountered a bug, turn on the Ruby Console in SketchUp, then duplicate the behavior and then send me any error codes generated with other pertinent details. I will do my best to remedy all bugs that are detected and reported.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.1.3 - 01.13.2026
                                      • Enabled custom overhangs for sheathing.
                                      • Added a "Remove Overhang" parameter to selectively control the sheathing overhang.
                                      Update per customer request.
                                      This feature is identical to the overhang feature included with steel decks and will allow the user to set an overhang and then selectively assign specific edges which do not have the overhang enabled.
                                      Tutorial #20 explains how this feature works:
                                      design.medeek.com
                                      • 5 / 8
