    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      gkont1983 Newcomers @fredo6
      @fredo6 said in [Plugin Library] LibFredo6 - v15.2a - 12 Mar 25:
      IMPORTANT: from now on, LibFredo6 and all my plugins are ONLY maintained for SU2017 and above. If you run a legacy version of Sketchup (up to SU2016), you can find the frozen legacy versions of LibFredo6 and my plugins here.
      The information on LibFredo6 is maintained on the Plugin Home Page of LibFredo6. This is also where you can download the RBZ file.
      • Sketchup version: SU2017 and above (for Mac M1, SU2021 and above)
      • Usage: Free
      If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video:
      LibFredo6 is a shared plugin library used by most of my plugins. LibFredo6 takes care, among others, of enriching my plugins with a few capabilities such as default parameters, language translation, Check Plugins for Update, Trace logging, etc.
      It is NOT a standalone plugin. It must be installed once and updated as needed when new versions are published.
      LibFredo6 User Manual - English - v5.2.pdf
      I have Sketchup 2025 and the plugin cannot be installed whatever I do.
        @gkont1983
        How have you tried to install Libredo6 ?
        The two ways are:
        Download its RBZ from the PluginStore, then use the Extension manager to Install it. After that restart SketchUp to sync everything.
        Or use the SketchUcation toolset ExtensionStore dialog to find it, click to auto-install it - sidestepping the RBZ download. After that restart SketchUp to sync everything.
        You need the SketchUcation toolset installed for the SCF licensing etc - especially of many of Fredo's extensions.
        So I recommend you download its RBZ from the PluginStore, then use the Extension manager to Install it. After that restart SketchUp to sync everything.
        After that always use the ExtensionStore dialog to install future extensions - it's vital for licensing, but it offers lots of other perks too...
          JDzign Newcomers
          I just downloaded LibFredo6 rbz file then went to extension warehouse in Sketch Up to install and enable it, then restarted Sketch Up, but I don't see the extension in my tools palette where all the other extensions are? What am I doing wrong?
            Libfredo is a library that is used by Fredo's other extensions. On its own it serves no purpose.
            It resides under Window > Libfredo Settings
            J 1 Reply Last reply Reply Quote 0
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v15.3a - 02 Apr 25
              LibFredo6 15.3a is a major release. It includes changes related to:
              • JointPushPull v4.9a
              • Bug Fixing and technical adjustments
                JDzign Newcomers @Rich O Brien
                @Rich-O-Brien So I need to download the entire Fredo library?
                  Libfredo is the engine his other extensions require to function.
                  You can download whatever other of Fredo’s extensions you want.
                  • fredo6F Offline
                    NEW RELEASE: LibFredo6 v15.3c - 17 Apr 25
                    LibFredo6 15.3c is a minor release. It includes changes related to:
                    • ROB Axyz
                      TeKnoel
                      I'm having a problem after a crash. all of a sudden SketchUp keeps crashing when loading my plugins. I've deleted LibFredo6 and it will open. Then ill re install it and it will crash. do you have any advice?
                      T 1 Reply Last reply Reply Quote 0
                        TeKnoel @TeKnoel
                        @TeKnoel I've been working on a fresh install of all my plugins it seems the conflict might be s4u frame and scene exporter. i just deleted that one and it seems to be loading most of my stuff again
                          Mario van Hout Newcomers
                          This is the first time i uploades plug-ins.
                          The download and installation went well (even though normally i have to ask the administrator).
                          I can see the LibFredo6 settings under tab Windows
                          But how do i get the toolbar on my workspace? I don't see it... in the video it shows the LibFredo6 toolbar.
                            LibFredo is a helper library. On its own it does very little and does not need a toolbar.
                            You need to install Fredo extensions that use it.
                            • fredo6F Offline
                              NEW RELEASE: LibFredo6 v15.4a - 13 May 25
                              LibFredo6 15.4a is a minor release. It includes changes related to:
                              • LayOps v1.1 (dual Dimensions in Layout)
                                chaochaiva Newcomers
                                Every time use Roundcorner 3.4a after select conner then press enter ,theSketchup2025 always turn off
                                XXX note i already update to LibFredo 15.4a
                                • fredo6F Offline
                                  Which platform?
                                  Do you get a bugsplat?
                                  Does it happen with any model?
                                    simulat
                                    Hello, I'm running sketchup 2020 and all of your plugins have recently started causing sketchup to crash all the time. I keep getting these errors. I have attempted reinstalling etc but no luck. any thoughts?
                                    Error: #<FrozenError: can't modify frozen String>
                                    c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:299:in upcase' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:299:in store_value'
                                    c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:226:in block in set' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:209:in each'
                                    c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:209:in set' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:199:in []='
                                    c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:71:in <module:Traductor>' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:23:in <main>'
                                    c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:353:in eval' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:353:in require'
                                    c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:353:in require_ruby' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1159:in block (2 levels) in load_full_rubies'
                                    c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1156:in each' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1156:in block in load_full_rubies'
                                    c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1154:in each' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1154:in load_full_rubies'
                                    c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1081:in effective_load_part2' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1040:in effective_load'
                                    c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/loader__libfredo6.rbe:1:in <main>' C:/Users/trask/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:47:in eval'
                                    Error: #<NoMethodError: undefined method +' for nil:NilClass> c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugindialogs.rbe:156:in purge'
                                    !libfredo6/top_libfredo6.rbe:470:in after_startup' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:605:in detect_startup_of_sketchup'
                                    !libfredo6/top_libfredo6.rbe:600:in `block in detect_startup_of_sketchup'
                                    • fredo6F Offline
                                      Did you do something specific so that these errors occur, like reinstall Sketchup? I mean what you say as 'recently'
                                        simulat
                                        No I was getting these errors and sketchup crashing just this week prior to doing anything. I haven't changed anything with my installs. When I opened sketchup this week it asked me to update fredo6 which I did. I was also having issues with thru paint showing up. So I uninstalled that and reinstalled. It then said my trial expired, so I purchased that. Still was getting these errors and sketchup crashing. Every so often it will crash and then when I reload sketchup all of your fredo toolbars are stacked in the middle of my screen not where I had them. I've had to put them back probably 16 times now. In an attempt to fix things, I did a "repair" install on sketchup, but that did not change anything.
                                        Should I attempt a full uninstall reinstall? anything else I could try before that?
                                        Thank you
                                        TIGT 1 Reply Last reply Reply Quote 1
                                          TIG Moderator @simulat
                                          @simulat
                                          When you did the 'Repair' did you 'Run' the SketchUp installer's exe file by double-clicking it, or by selecting it > right-clicking > context-menu > Run as administrator
                                          The second way is correct, the other way is wrong, and it can lead to all kinds of unpredictable permission related issues, such as settings being unsaved etc...
                                            simulat
                                            It was already set to run as administrator, I had to give permission to repair. I was getting these errors and issues before doing that too.
                                            • 11
                                            • 108
                                            • 109
                                            • 9 / 109
