    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Version 3.8.9 - 02.09.2025
      • Added preview thumbnails for handrail fittings to the draw and edit menus of the stair tool.
      • Fixed a bug with adjacent winders/landings for landing treads and covers.
      • Fixed a minor bug with materials for handrail fittings.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.9.0 - 02.11.2025
        • Enabled zero size intermediate posts (balusters) for glass railing.
        • Fixed a bug with floor level winders/landings for landing treads and covers.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.9.0c - 02.12.2025
          • Fixed a bug when the top tread is flush.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 3.9.0d - 02.14.2025
            • Fixed a floating point rounding bug for metric templates.
            • Fixed a bug for balusters when a run of stairs is a single step.
            Still putting out a few little fires. Whenever you make big changes it always seems like you miss something or you add a new feature that adds a whole new level of complexity, and then the plugin gets itself into states that you did not foresee. That is what makes this job fun, you get surprised once in a while.
            Please feel free to send me any additional bug reports or feature requests. I think we've just about wrapped up the stair module for a while.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 3.9.1 - 02.23.2025
              • Added the following (48 - low poly) Simpson post caps to the post module: CC1210, CC718_718, CC718_8, CC718_6, CC718_4, CC514_8, CC514_6, CC514_4, CC462_550, CC462_462, CC462_362, CC314_6, CC314_4, CC128, CC126, CC106, CC98, CC96, CC94, CC88, CC86, CC84, CC78, CC77, CC76, CC74, CC68, CC66, CC64, CC48, CC46, CC44, CC6_718, CCO4, CCO6, CCO7, CCO8, CCO9, CCO10, CCO12, CCO46, CCO314, CCO462, CCO514, CCO718, ECC64, ECC66, ECC68.
              This update per customer request.
              I still need to add in the rest of the ECC series, so there is always more to do.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.9.2 - 03.15.2025
                • Enabled an edge material/texture for built-in gypsum wall materials.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Here are a some new renderings of an Inverted Tee landing using the newly upgraded stair module. A huge shout out to @patrick.c.obrien for these amazing images and for all of his efforts in helping me debug this module during the month long process of updates and additions:
                  Example 1 Inv-T stair assembly.png Example 2 Inv-T stair assembly.png Example 3 Inv-T stair assembly.png Example 4 Inv-T stair assembly.png
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.9.3 - 03.29.2025
                    • Added the following Simpson Strong-Tie holdowns to the wall, column and shearwall modules: DTT1Z, LTTP2, LTTI31.
                    • Added the following Simpson Strong-Tie holdowns to the wall, column and shearwall modules: HD3B, HD5B, HD7B, HD9B, HD12, HD19.
                    • Updated the wall and column modules so that they include all previous holdowns that were added to the shearwall module.
                    I think I now have added every common holdown used for walls and columns that is found in the Simpson Catalog [Wood Construction Connectors 2024-2025] (pg. 51-65).
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.9.4 - 04.04.2025
                      • Added the following Simpson Strong-Tie header hangers to the door module: HH4, HH6.
                      • Enabled header hangers for all door headers.
                      Note that Simpson only manufactures two standard header hanger sizes (HH4 and HH6). However there are quite a few more options for CFS framing. If there is any interest I can add those hangers as well upon request.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.9.5 - 04.19.2025
                        • Enabled a zero thickness apron for style B window casing.
                        • Included additional logic for vertically offset sheathing and cladding.
                        Both of these updates per customer request.
                        I have been taking care of some miscellaneous items on my todo lists for both the Truss and Wall plugin before I dive back down the rabbit hole that is currently the Floor plugin. Once I jump back into that one I may not emerge again for a couple months so I thought it best that I take care of a few requests first.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.9.6 - 04.19.2025
                          • Added a "Union Door Gypsum" and "Union Window Gypsum" option into the Sheathing tab of the Global Settings.
                          • Enabled "seamless" gypsum for gypsum wrapped windows and doors.
                          Note the difference between the two windows below:
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.9.7 - 04.30.2025
                            • Added a "Chord Angle" output parameter for arched doors and windows within their respective HTML menus.
                            • Added glulam and steel columns into the in-wall column module for all wall types.
                            • Enabled a wood grain and an end grain material for glulam columns within the in-wall column module.
                            • Added a "right" hand slider window and updated the existing slider name to be a "left" hand slider window.
                            design.medeek.com
                              MtnArch
                              The call-outs for the operable sliding windows should be "XO" when the left panel is operable (as viewed from the outside) and "OX" when the right panel is operable. An "XOX" would have a fixed panel in the middle and each side panel would be operable.
                              Highest Regards,
                              Alan T. Hendry, RA
                              Architect
                              • medeekM Offline
                                medeek
                                Version 3.9.8 - 05.04.2025
                                • Added the Connect Corner tool to the Medeek Wall Tools II toolbar.
                                • Updated the Opening Copy tool with the left and right hand slider window.
                                • Fixed a specific bug related to glulam columns with a vertical offset equal to the wall bottom plate thickness.
                                Tutorial 69 - Connect Corner Tool (9:12 min.)
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 3.9.9 - 05.09.2025
                                  • Updated the Connect Corner tool to work with non-orthogonal walls.
                                  • Fixed a bug with the in-wall column tool for gable walls.
                                  • Enabled Advanced Framing Options within the window module.
                                  • Added the Advanced Framing Options parameter within the Windows tab of the global settings.
                                  • Fixed the callout for right handed slider (OX) windows.
                                  • Enabled zero stool extensions and zero stool projections for all window casing options.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 3.9.9b - 05.09.2025
                                    • Enabled backward compatibility with existing windows (advanced framing options).
                                    !!! CRITICAL BUG FIX !!!
                                    When I rolled this out last night I forgot to add exactly one line of code which would have made sure that all previous windows were backward compatible with the recent inclusion of the advanced framing options. Please update your installation to this latest version if you have recently installed Version 3.9.9. My apologies for this major inconvenience and my somehow missing this with the initial release of this new feature.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 4.0.0 - 05.27.2025
                                      • Enabled "green" pressure treated lumber in the global settings.
                                      • Fixed a bug with trimmer studs for trapezoid windows.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 4.0.0b - 05.28.2025
                                        • Enabled "green" pressure treated lumber within the stair module.
                                        design.medeek.com
                                        • gullfoG Offline
                                          gullfo
                                          what! no yellow board! πŸ™‚ j.k.
                                          Glenn
                                          http://www.runnel.com
                                          • medeekM Offline
                                            medeek
                                            Version 4.0.1 - 05.29.2025
                                            • Added five additional layers to the Layers tab of the Global Settings for stair assemblies.
                                            • Added a "Stair Layers" option into the Layers tab of the Global Settings in order to toggle the stair layers "On" or "Off".
                                            Tutorial 71 - Layers/Tags for Stairs (4:02 min.)
                                            design.medeek.com
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 75
                                            • 76
                                            • 31 / 76
