    2.2k Posts 487 Posters 932.4k Views 492 Watching
      TIG Moderator @masmoosa
      @masmoosa
      What extension are you referring to ?
      There's insufficient info for us to help you.
      Please give us a clear description of what you are trying to do, and what problems you are experiencing...
        lutzkrammer
        Hi, i bought a bundle from fredo for 50$. All the plug ins work, but curviloft and joint push pull not. I had a free trial for thes two plug ins, and now it shows
        trial period is expired. tried for several times to install and deinstall the versions from the bundle, but dosen´t work.
        Help would be wonderful.
        • fredo6F Offline
          What happens if you click on button Manage License?
          • N Offline
            nanfar
            Hello, I want to remove all Fredo plugins from my computer as if they were never installed before. Is it possible to completely delete everything?
            fredo6F 1 Reply Last reply Reply Quote 0
            • fredo6F Offline
              fredo6 @nanfar
              @nanfar said in SCFLicense: Extension Licensing on Sketchucation:
              Not sure this is useful. What is the problem you have?
              N 1 Reply Last reply Reply Quote -1
              • N Offline
                nanfar @fredo6
                @fredo6 Could you please tell me how to do this?
                • fredo6F Offline
                  Just go to the Extension manager, select the Manage TAB and click Uninstall on the plugins you wish to remove.
                    lomanzo78
                    Hi, i was using Sketchint plugin as free version and was working great. it stopped working and I purchased the license. Now is active but is not working. Is there anything I need to do to make it work?
                      Rich O Brien Moderator @lomanzo78
                      @lomanzo78 said in SCFLicense: Extension Licensing on Sketchucation:
                      SketchIntlicense term is 570 days. Has your term passed?
                        lomanzo78 @fredo6
                        @fredo6 Hi, I did, and still not working andy other advice?
                          Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                            BMBrend
                            I can't release some of the seats on Fredo6 plugins. I think they are stuck on a computer that died. Is there a way to bulk reset all licenses?
                              BMBrend
                                @BMBrend email support@sketchucation.com and we can walk you through it.
                                B 1 Reply Last reply Reply Quote 0
                                  BMBrend @Rich O Brien
                                  @Rich-O-Brien Thank you!
                                  • H Offline
                                    hannusza
                                    Hi there!
                                    When I tried to use ThruPaint, a window appeared saying that I need to purchase a license. I checked all the updates and everything is fine. What can I do?
                                    Thank you for help in advance.
                                      You need a license.
                                      https://sketchucation.com/plugin-list.php
                                      Or use the free version of ThruPaint included in FredoTools
                                        maximus Newcomers
                                        Bonjour Fredo,
                                        Thrupaint n'est pas compris que dans le pack d'extension ( roundcorner, jointpushpull etc...) ?
                                        Je n'y ai plus accès...
                                        Merci d'avance
                                        TIGT 1 Reply Last reply Reply Quote 0
                                          TIG Moderator @maximus
                                          @maximus
                                          You need a license for the full version.
                                          Or use the free version of ThruPaint which is included in the free FredoTools
                                            cjfdyd727
                                            If the account email is different from the email receiving the license, will the license purchase not appear in the account's purchase history?
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 109
                                            • 110
                                            • 49 / 110
