    2.3k Posts 515 Posters 2.3m Views 520 Watching
      miguelbarbosa5 Newcomers
      I press the icons to use them and I can't, this window appears instead of the plug-in working
      TIGT 1 Reply Last reply Reply Quote 0
        TIG Moderator @miguelbarbosa5
        @miguelbarbosa5
        A clearer explanation would help us to help you !
          jchbps Newcomers
          @TIG said in SCFLicense: Extension Licensing on Sketchucation:
          That link works fine for me...
          Landing you at the page where you can chose a Premium Membership [optional - with its associated discounts] ?
            malmond
            I changed my computer name, now five of my licenses don't work. Any advice?
              @malmond
              Delete the signature file at https://sketchucation.com/webshop/my-licences.php
              Restart SketchUp
                masmoosa Newcomers
                hello, i just downloaded this extension and it says i have to activate my subscription even though i fit all the requirements what do i do
                  TIG Moderator @masmoosa
                  @masmoosa
                  What extension are you referring to ?
                  There's insufficient info for us to help you.
                  Please give us a clear description of what you are trying to do, and what problems you are experiencing...
                    lutzkrammer
                    Hi, i bought a bundle from fredo for 50$. All the plug ins work, but curviloft and joint push pull not. I had a free trial for thes two plug ins, and now it shows
                    trial period is expired. tried for several times to install and deinstall the versions from the bundle, but dosen´t work.
                    Help would be wonderful.
                    • fredo6F Offline
                      What happens if you click on button Manage License?
                      • N Offline
                        nanfar
                        Hello, I want to remove all Fredo plugins from my computer as if they were never installed before. Is it possible to completely delete everything?
                        fredo6F 1 Reply Last reply Reply Quote 0
                        • fredo6F Offline
                          fredo6 @nanfar
                          @nanfar said in SCFLicense: Extension Licensing on Sketchucation:
                          Not sure this is useful. What is the problem you have?
                          N 1 Reply Last reply Reply Quote -1
                          • N Offline
                            nanfar @fredo6
                            @fredo6 Could you please tell me how to do this?
                            • fredo6F Offline
                              Just go to the Extension manager, select the Manage TAB and click Uninstall on the plugins you wish to remove.
                                lomanzo78
                                Hi, i was using Sketchint plugin as free version and was working great. it stopped working and I purchased the license. Now is active but is not working. Is there anything I need to do to make it work?
                                  Rich O Brien Moderator @lomanzo78
                                  @lomanzo78 said in SCFLicense: Extension Licensing on Sketchucation:
                                  SketchIntlicense term is 570 days. Has your term passed?
                                    lomanzo78 @fredo6
                                    @fredo6 Hi, I did, and still not working andy other advice?
                                      Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                        BMBrend
                                        I can't release some of the seats on Fredo6 plugins. I think they are stuck on a computer that died. Is there a way to bulk reset all licenses?
                                          BMBrend
                                            @BMBrend email support@sketchucation.com and we can walk you through it.
                                            B 1 Reply Last reply Reply Quote 0
                                            • 99
                                            • 100
                                            • 101
                                            • 102
                                            • 103
                                            • 115
                                            • 116
                                            • 101 / 116
