    2.2k Posts 487 Posters 929.5k Views 492 Watching
      @malmond
      Delete the signature file at https://sketchucation.com/webshop/my-licences.php
      Restart SketchUp
        masmoosa Newcomers
        hello, i just downloaded this extension and it says i have to activate my subscription even though i fit all the requirements what do i do
        TIGT 1 Reply Last reply Reply Quote 0
          TIG Moderator @masmoosa
          @masmoosa
          What extension are you referring to ?
          There's insufficient info for us to help you.
          Please give us a clear description of what you are trying to do, and what problems you are experiencing...
            lutzkrammer
            Hi, i bought a bundle from fredo for 50$. All the plug ins work, but curviloft and joint push pull not. I had a free trial for thes two plug ins, and now it shows
            trial period is expired. tried for several times to install and deinstall the versions from the bundle, but dosen´t work.
            Help would be wonderful.
            • fredo6F Offline
              What happens if you click on button Manage License?
              • N Offline
                nanfar
                Hello, I want to remove all Fredo plugins from my computer as if they were never installed before. Is it possible to completely delete everything?
                fredo6F 1 Reply Last reply Reply Quote 0
                • fredo6F Offline
                  fredo6 @nanfar
                  @nanfar said in SCFLicense: Extension Licensing on Sketchucation:
                  Not sure this is useful. What is the problem you have?
                  N 1 Reply Last reply Reply Quote -1
                  • N Offline
                    nanfar @fredo6
                    @fredo6 Could you please tell me how to do this?
                    • fredo6F Offline
                      Just go to the Extension manager, select the Manage TAB and click Uninstall on the plugins you wish to remove.
                        lomanzo78
                        Hi, i was using Sketchint plugin as free version and was working great. it stopped working and I purchased the license. Now is active but is not working. Is there anything I need to do to make it work?
                          Rich O Brien Moderator @lomanzo78
                          @lomanzo78 said in SCFLicense: Extension Licensing on Sketchucation:
                          SketchIntlicense term is 570 days. Has your term passed?
                            lomanzo78 @fredo6
                            @fredo6 Hi, I did, and still not working andy other advice?
                              Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                BMBrend
                                I can't release some of the seats on Fredo6 plugins. I think they are stuck on a computer that died. Is there a way to bulk reset all licenses?
                                  BMBrend
                                    @BMBrend email support@sketchucation.com and we can walk you through it.
                                    B 1 Reply Last reply Reply Quote 0
                                      BMBrend @Rich O Brien
                                      @Rich-O-Brien Thank you!
                                      • H Offline
                                        hannusza
                                        Hi there!
                                        When I tried to use ThruPaint, a window appeared saying that I need to purchase a license. I checked all the updates and everything is fine. What can I do?
                                        Thank you for help in advance.
                                          You need a license.
                                          https://sketchucation.com/plugin-list.php
                                          Or use the free version of ThruPaint included in FredoTools
                                            maximus Newcomers
                                            Bonjour Fredo,
                                            Thrupaint n'est pas compris que dans le pack d'extension ( roundcorner, jointpushpull etc...) ?
                                            Je n'y ai plus accès...
                                            Merci d'avance
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 109
                                            • 110
                                            • 45 / 110
