    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 343 Posters 2.3m Views 340 Watching
      Mike Backman
      Hello, I have no Idea how to direct message Fredo.
      1st Question: How do I DM Fredo for Help?
      2nd Question: is the new lord of the tool bars update deal with the the fact that I need to set my external monitor as my "main screen" in order to work on in my large SU monitor. this is fine but when I go back to use my laptop on it on it own my desktop icons are a mess.
      3rd Question : thrupaint and LOTT is not showing up on my Sketchucation my licence page.
      • Rich O BrienR Online
        Rich O Brien Moderator @Mike Backman
        @Mike-Backman
        You can use...
        @fredo6
        LOTT doesn't require a license and you have no purchase history for ThruPaint
          Mike Backman
          Forgive me but what is @fredo ? is that instgram or something
            Its exactly the same as @Mike-Backman
            It is what referred to as a mention. If you @ someone they are notified of the mention if they have notifications set.
            You cannot DM members because your reputation level is below the minimum threshold. This is a measure to stop spam accounts creating unwanted content.
            If you want help with LOTT just post your issues here:
            https://community.sketchucation.com/post/1581174
            Fredo will read that and respond if he wishes.
            • V Offline
              VoNn3 Newcomers
              Bonjour, j'ai aujourd'hui essayé l'outil fredoscale et merci beaucoup pour votre incroyable travail.
              J'ai cependant un petit problème. J'ai utilisé "boxtapering" pour modifier un ensemble de composant ce qui a marché à merveille. Néanmoin, une fois les pièces modifiés, leurs taille devient imprecise et les pièces ne sont plus reconnues par le plugin "opencutlist" et donc impossible de générer une liste de débit. Je ne sais pas si c'est un problème solutionnable je pose ici le problème.
              Merci encore !
              Hello, I tried the fredoscale tool today and thank you very much for your incredible work.
              However, I have a small problem. I used "boxtapering" to modify a set of components which worked wonderfully. However, once the parts are modified, their size becomes imprecise and the parts are no longer recognized by the "opencutlist" plugin and therefore impossible to generate a cutting list. I do not know if this is a solvable problem, I am asking the problem here.
              Thanks again!
                Mae50 Newcomers
                Good morning,
                I am a daily user of this plugin.
                I just installed SKP 2024 and FredoScale - v3.6a on my new machine. The license is active but when I click on the tool nothing happens.
                Can you help me?
                Bonjour,
                je suis une utilisatrice quotidienne de ce plugin.
                Je viens d'installer SKP 2024 et FredoScale - v3.6a sur ma nouvelle machine. La licence est active mais quand je clique sur l'outil rien ne se passe.
                Est-ce que vous pouvez m'aider ?
                  @Mae50
                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                    Mae50 Newcomers
                    @Rich-O-Brien
                    Thanks for your support !
                    Fredo6 Plugins Information on 2025-03-04 09:59:17 +0100
                    • Sketchup: 24.0.594
                    • LibFredo6: v15.1a
                    • LibFredo6 Binary loaded
                    • Sketchucation ExtensionStore: 4.4.1
                    • SCFLicense: v6.4a - 74
                    • Fredo6 Plugins
                      FredoScale v3.6a - licensed FULL
                      Signature File: 2025-02-24 16:52:48 +0100
                      FredoScale: 2025-03-04 09:56:38 +0100
                      @Mae50 That looks good.
                      Can you explain in more detail what is happening?
                      If you open the Ruby Console via Extensions > Developer > Ruby Console and click on a toolbar icons you see errors in the console?
                      If your SketchUp install does not have the correct privileges you can repair the SketchUp installation by downloading the installer and right clicking and choosing Run as Admin
                      When prompted choose Repair.
                        Mae50 Newcomers
                        @Rich-O-Brien
                        When I click on a tool Ruby Console says :
                        • LibFredo6: v15.1a
                        • Fredo6 Plugins
                          Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/julie/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                          c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in initialize' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in open'
                          c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in write_to_file' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:150:in store'
                          c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1474:in usage_use' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1462:in command_invoke'
                          c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1443:in block (2 levels) in build_config_commands' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1490:in block in add_command'
                          Yes, that looks like your SketchUp install is missing the correct permissions. Following my instructions to Repair should rectify it.
                          Or go to C:/Users/julie/AppData/Local/LIBFREDO6_DATA_Dir and delete the LibFredo6_all_defaults.dat file and start SketchUp
                          I'd recommend the top option to ensure you don't encounter other issues related to permissions.
                            Mae50 Newcomers
                            Thanks I do the first option, but it's not ok .
                            Console Ruby :
                              Mae50 Newcomers
                              @Rich-O-Brien
                              I just try the second option
                              and it's ok.
                              Thank you very very much for your support
                              • N Offline
                                NetJaro
                                Hi!
                                I think I found bug.
                                Sometimes, when I rotate my element i change dimensons there is a error with area of my component.
                                Look at this video: 2025-03-11 16 06 21.mp4
                                Someone can help me?
                                Marcin.
                                • fredo6F Offline
                                  I would need to have the model to understand, especially because the video is unclear about what exactly you do to the cube with the rotation.
                                  Also, can you turn on 'Show Hidden geometry', just in case there are hidden elements in the group.
                                  N 1 Reply Last reply Reply Quote 0
                                  • F Offline
                                    FlorinAp
                                    Box Stretching options has a bug - it does correctly only the first level of components nesting, starting with the second level, it doesn't make unique on the first run (it messes up all your components in the model.!), and if you hit Ctrl+Z (only ONCE.!) it reverses the modification, and after that they remain unique and you can modify...
                                    Very disturbing.!
                                    Curic Stretch works flawlessly, but it is not so handy and fast to use, so is the last option. I use it only when what I want to modify is much too heavy (loaded with many faces and edges... usually organic shapes, but also cabinets with more then 3 drawers because it freezes calculating) because it can handle much more amount of geometry, in these situations, Fredo Scale does only half the job and you end up seeing that only a few pieces have been modified.
                                    • N Offline
                                      NetJaro @fredo6
                                      [@fredo6 thanks for your answer and thank you for what you do for Sketchup 🙂
                                      I include my model.
                                      One object (on the left) is original, second object (on the right) is after rotate by Sketchup official rotate function.
                                      The bug doesn't show always in first time - try rotate left object, when its good (without bug) - use "undo" and try again.
                                      bug.skp
                                      Thanks for you help!
                                      Regards,
                                      Marcin
                                      • fredo6F Offline
                                        What is the relation with FredoScale then?
                                        Note that I tried to rotate both objects, with Undo and try again. I did not find any issue
                                        • N Offline
                                          NetJaro @fredo6
                                          @fredo6 Hi!
                                          The problem with area of the object is only when I use a FredoScale.
                                          Below I include a longer video with problem.
                                          Image 002.mp4
                                          E 1 Reply Last reply Reply Quote 0
                                          • fredo6F Offline
                                            I cannot reproduce the issue with the Stretch tool followed by a SU Rotate.
                                            Do you have it on any object or just this one ?
                                            By the way, it looks like you component is a Dynamic component, or at least was a dynamic component.
                                            • 56
                                            • 57
                                            • 2 / 57
