    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
      Rich O Brien Moderator @DomV12
      @DomV12 said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
      Can someone give me a hand with this?
      Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
      D 1 Reply Last reply
        DomV12 @Rich O Brien
        @Rich-O-Brien You mean this? :
        Fredo6 Plugins Information on 2024-07-16 09:33:05 -0400
        • Sketchup: 24.0.484
        • LibFredo6: v14.5c
        • LibFredo6 Binary loaded
        • Sketchucation ExtensionStore: 4.4.1
        • SCFLicense: v6.4a - 74
        • Fredo6 Plugins
          Curviloft v2.0a
          FredoScale v3.6a
          FredoTools v4.5c
          Signature File: 2024-07-15 11:59:27 -0400
          @DomV12 Please retrieve your license files from https://sketchucation.com/webshop/my-licences.php
          Follow the guide on how to activate: https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
          Report back with error messages.
          If you are unable to license it may be your SketchUp install does not have full permissions to read/write folders. Please repair your SketchUp install and then re-try steps above.
            ratthakorn33
            Hi! Fredo.
            I have a purchase license bundle of fredo2022 but i can't use plugin please help
              Rich O Brien Moderator @ratthakorn33
              @ratthakorn33 said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
              Hi! Fredo.
              Close SketchUp
              Perform the steps in the dialog and delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt at C:\Users\SomeName\AppData\Local\SCF Licenses
              Start SketchUp and activate license
              R 1 Reply Last reply
                ratthakorn33 @Rich O Brien
                @Rich-O-Brien It actually works. Thankyou
                  RUBIYA KHAN Newcomers @Teezer
                  @Teezer hi i cannot use it after downloading
                  please help me
                    Rich O Brien Moderator @RUBIYA KHAN
                    @RUBIYA-KHAN Can you share more info?
                      Mike Backman
                      Hello, I have no Idea how to direct message Fredo.
                      1st Question: How do I DM Fredo for Help?
                      2nd Question: is the new lord of the tool bars update deal with the the fact that I need to set my external monitor as my "main screen" in order to work on in my large SU monitor. this is fine but when I go back to use my laptop on it on it own my desktop icons are a mess.
                      3rd Question : thrupaint and LOTT is not showing up on my Sketchucation my licence page.
                        Rich O Brien Moderator @Mike Backman
                        @Mike-Backman
                        You can use...
                        @fredo6
                        LOTT doesn't require a license and you have no purchase history for ThruPaint
                          Mike Backman
                          Forgive me but what is @fredo ? is that instgram or something
                            Its exactly the same as @Mike-Backman
                            It is what referred to as a mention. If you @ someone they are notified of the mention if they have notifications set.
                            You cannot DM members because your reputation level is below the minimum threshold. This is a measure to stop spam accounts creating unwanted content.
                            If you want help with LOTT just post your issues here:
                            https://community.sketchucation.com/post/1581174
                            Fredo will read that and respond if he wishes.
                            • V
                              VoNn3 Newcomers
                              Bonjour, j'ai aujourd'hui essayé l'outil fredoscale et merci beaucoup pour votre incroyable travail.
                              J'ai cependant un petit problème. J'ai utilisé "boxtapering" pour modifier un ensemble de composant ce qui a marché à merveille. Néanmoin, une fois les pièces modifiés, leurs taille devient imprecise et les pièces ne sont plus reconnues par le plugin "opencutlist" et donc impossible de générer une liste de débit. Je ne sais pas si c'est un problème solutionnable je pose ici le problème.
                              Merci encore !
                              Hello, I tried the fredoscale tool today and thank you very much for your incredible work.
                              However, I have a small problem. I used "boxtapering" to modify a set of components which worked wonderfully. However, once the parts are modified, their size becomes imprecise and the parts are no longer recognized by the "opencutlist" plugin and therefore impossible to generate a cutting list. I do not know if this is a solvable problem, I am asking the problem here.
                              Thanks again!
                                Mae50 Newcomers
                                Good morning,
                                I am a daily user of this plugin.
                                I just installed SKP 2024 and FredoScale - v3.6a on my new machine. The license is active but when I click on the tool nothing happens.
                                Can you help me?
                                Bonjour,
                                je suis une utilisatrice quotidienne de ce plugin.
                                Je viens d'installer SKP 2024 et FredoScale - v3.6a sur ma nouvelle machine. La licence est active mais quand je clique sur l'outil rien ne se passe.
                                Est-ce que vous pouvez m'aider ?
                                  @Mae50
                                    Mae50 Newcomers
                                    @Rich-O-Brien
                                    Thanks for your support !
                                    Fredo6 Plugins Information on 2025-03-04 09:59:17 +0100
                                    • Sketchup: 24.0.594
                                    • LibFredo6: v15.1a
                                    • Fredo6 Plugins
                                      FredoScale v3.6a - licensed FULL
                                      Signature File: 2025-02-24 16:52:48 +0100
                                      FredoScale: 2025-03-04 09:56:38 +0100
                                      @Mae50 That looks good.
                                      Can you explain in more detail what is happening?
                                      If you open the Ruby Console via Extensions > Developer > Ruby Console and click on a toolbar icons you see errors in the console?
                                      If your SketchUp install does not have the correct privileges you can repair the SketchUp installation by downloading the installer and right clicking and choosing Run as Admin
                                      When prompted choose Repair.
                                        Mae50 Newcomers
                                        @Rich-O-Brien
                                        When I click on a tool Ruby Console says :
                                        • LibFredo6: v15.1a
                                        • Fredo6 Plugins
                                          Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/julie/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                                          c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in initialize' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in open'
                                          c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in write_to_file' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:150:in store'
                                          c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1474:in usage_use' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1462:in command_invoke'
                                          c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1443:in block (2 levels) in build_config_commands' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1490:in block in add_command'
                                          Yes, that looks like your SketchUp install is missing the correct permissions. Following my instructions to Repair should rectify it.
                                          Or go to C:/Users/julie/AppData/Local/LIBFREDO6_DATA_Dir and delete the LibFredo6_all_defaults.dat file and start SketchUp
                                          I'd recommend the top option to ensure you don't encounter other issues related to permissions.
                                            Mae50 Newcomers
                                            Thanks I do the first option, but it's not ok .
                                            Console Ruby :
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 56 / 59
