    Post diagnosis.
    72 Posts 5 Posters 2.2k Views 5 Watching
      Well, after the Next Limit guys checked out the PC, another check render with Rayscaper. Slowly getting to grips with this but much to learn still.
        I 'borrowed the Thea benchmark tool to analise my set up:-
        Date: 2025-01-29T01:03:24
        Username:
        Thea SDK Revision: v3.5.00 build 1975
        OS: Windows 10 Home 64 bit
        CPUs #:1
        GPUs (CUDA) #:1
        OCLs (OpenCL) #:0
        Devices: Caustics | Instancing | MeccanoPlane | SSSGears
        13th Gen Intel(R) Core(TM) i5-13600K (Cores: 20) | 1836 | 92 | 1416 | 744
        NVIDIA GeForce RTX 3080 (Cores: 8704) | 4556 | 159 | 2200 | 1532
        Final Score: 12542
          I get the feeling that the final render score is not that good, no idea if/where bottlenecks are though.
            @Mike-Amos
            Try running Cinebench to get a value you can compare with other devices
            Evaluate your computer's hardware capabilities | Cinebench from Maxon
            Cinebench is a free cross-platform test suite that evaluates your computer's hardware capabilities. Get a more accurate measurement of Cinema 4D's abilityโ€ฆ
            Maxon (www.maxon.net)
              Ta, Rich. I downloaded the Thea render "Detailed Interior" scene to test and frankly the textures vanish once added to a surface. I think I must be on some seriously goo/bad acid drops, probably the green/lime ones.......
                    That error is completely weird because a 3080 has 10GB of VRAM
                    Your machine is the most delicate device I've encountered. I'd never shop wherever you got that again. Unless you like to feel punished?
                    It has enough grunt to render relatively fast. Not blazing fast but definitely not hours and hours for straight forward interior scenes.
                    I don't think the issue is you. I think the device might be suffering from little gremlins or there some software trying mange things when you should just be able work away.
                      The pc shut down just after re running that test. Will not boot at all, shows the chillblast splash screen and freezes.
                      Luckily enough the old pc which also would not boot, did.
                      Ordered asda bits so did A job.
                      No rendering until chillblast get their fingers out.
                        Attached the monitor to the onboard graphics outlet and the pc booted without issues. For me this suyggests a graphic card issue, any other idea's?
                          Tried a Rayscaper render, selected GPU, got this is around 4m 45s. No, I cannot see how the graphics card can do this. Chillblast are, quiet and not returning calls.
                            Another go different view.
                              A little saboutage from the feline, lost a few settings.
                                Mike Amos @Mike Amos
                                Well, I imported this clock from t'internet and I cannot even select anything. All I get is right click and options. Left click does nothing....Cannot select Object.jpg
                                  Exception breakpoint error. Memory or ssd.
                                    Gone through various check, chkdsk etc. Now having to clean install sketchup, again.
                                    It does get a bit tedious.
                                      If I had a dollar for everytime you hit alerting messages I'd have enough to buy you a new PC
                                        This time around the whole disk checking system ran through, took over an hour and a half.
                                        No idea if it found/fixed anything but no doubt going through the reinstall process with stress anything bent already.
                                        I also had a response from someone claiming to be a manager of the 'customer service team'. He was asking me to tell him what the problem with the operators is so I told him no punches pulled, pointing out the issue and where the law requires them to act. Also mention of publicity should changes not be made. No idea where this is going but it's in the air tonight. Perhaps I had too much 'bastard factor' in my tea.
                                        I believe that when these people say they are going to do something they should, rather than buggering off and ignoring the issue.
                                        Oh well, off to collect the latest offering from the cat, she seems spatially challenged and often misses the litter tray. Thanks Moggy.
                                        • Gus RG Offline
                                          Gus R
                                          Shot in the dark but try from a CMD prompt...
                                          sfc /scannow
                                          Let that run through.
                                          Then.
                                          dism /online /cleanup-image /restorehealth
                                          www.instagram.com/gusrobatto/
                                          www.facebook.com/gusrobatto
                                          • Gus RG Offline
                                            Gus R
                                            Or.
                                            Run CMD as admin and...
                                            Dism /Online /Cleanup-Image /CheckHealth
                                            Dism /Online /Cleanup-Image /ScanHealth
                                            Dism /Online /Cleanup-Image /RestoreHealth
                                            sfc /scannow
                                            • 1 / 4
