    To blend or not to blend
    27 Posts 6 Posters 2.1k Views 6 Watching
      Hi all, I see that a few have put blender in your workflow. Is it worth learning. I only use SketchUp for modelling just about all my work is architecture (non organic)
      Penny for your thoughts
        Depends on your comfort levels. If you are happy in your SketchUp box then pull up a chair and get comfy.
        If you want to explore other avenues then poke around.
        I like my SketchUp and Blender combo. I can do some things 10x faster in Blender and vice versa.
        It's worth adding that there's a very high frustration wall you encounter at first with Blender. Especially if you apply the SketchUp philosophy in terms of how 3D should work.
        Blender follows convention whilst SketchUp is about ease of use. In SketchUp you draw whilst in Blender you model.
        You cannot compare the apps because one is a conceptual design tool whilst the other is 3D pipeline.
        I like both.
        I'll be a SketchUp user until I hang my hat. But having a good foundation in Blender means I can tackle more projects that SketchUp just couldn't manage.
          Interesting, I did a blender course (Blender introduction course about 12 hours over 6 weeks) in 2004 I guess I would not be starting from absolute zero, Would you suggest
          BForArtist or full blender?
            Read some reviews and i think B4 is the go for me
              Full Blender is what I learned. I think it was Blender 2.6 I started with which had a horrible UI.
              If you get stuck just holla
                Thanks Rich
                • Gus RG Offline
                  Gus R
                  I almost finished the proverbial doughnut tutorial by Blender Guru. He also runs poliigon for texture thats I used in SU for either Thea Render or D5 Render. Right now I mostly use it for importing models from Blenderkit which about $10/month into D5 Render. Some of them work and others don't. I imagine it's the same with Twinmotion. It's complicated. I also dabbled with Rhino which has a command entry window like Autocad. So far Blender is a sort of utility combining SU, D5 and Blender from time to time.
                  www.instagram.com/gusrobatto/
                  www.facebook.com/gusrobatto
                  • Mike AmosM Online
                    Is there a physical book for Blender? Something I can actually have on the desk and refer to, tried video's and pdf's and frankly they are not my cup of tea.
                    Sorry, I am talking about a book folk can recommend, I am loath to buy stuff blind.
                    • N Offline
                      nickchun
                      I think printed manuals struggle to keep up with the pace of development of Blender. I had an in depth book a few years ago but now is almost redundant. Even video courses go out of date quickly. I find some of the video shorts a good way of learning in small chunks but it doesn't always fit in context. there are often several ways to do things, at the end of the day it's a matter of practice.. and time.
                        There is a book called "blender for idiots" which coincidently is me
                        • Mike AmosM Online
                          Ta, I'll have a good look. The basics will do tbh. The rest later.
                            The first thing you will need to know is when and how select Vertices, face and edge
                            • Mike AmosM Online
                              I have to admit to being spoiled by the Extrusion tools plugin for a lot of my non architectural modeling which is not easily transferable to other software.
                              A royal pain in the throne.
                                Hi Mike I do know Blender is extremely good at organic stuff
                                • Mike AmosM Online
                                  The problem is a lack of flexibility to change. Not giving up.
                                    Try the blender octopus tutorial on youtube
                                    • Mike AmosM Online
                                      Ta but, I do not do videos, not been able to get on with any of those I have tried so, I get books I can have next to me while I try to learn whatever it is I am trying to learn.
                                      I know, inflexible.
                                      tuna1957T 1 Reply Last reply Reply Quote 0
                                      • Gus RG Offline
                                        Gus R
                                        Speaking of Blender videos or tutorials, Some of them talk a mile a minute.
                                        • Mike AmosM Online
                                          I find that folk in video tutorials wave the cursor all over the screen while changing topic left and right, leaving me wondering what language they call home.
                                          I do like my linear progression and a little rehearsal to stay on script.
                                          Not seen it yert.
                                          • tuna1957T Offline
                                            tuna1957 @Mike Amos
                                            @Mike-Amos Mike, you’re not inflexible. We’re both from the generation that did all our learning from books. I have a hard time trying to learn from videos also. Although I have a number of books on learning Blender. I’m hesitant to recommend any by name as they’re for older versions of Blender. My top recommendation is make sure any books you might get are for the version of Blender you have installed.
