    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 631.5k Views 155 Watching
      Rich O Brien Moderator @yahyamsy
      @yahyamsy it is 1 license that has 3 seats/activations to allow a license holder use it on multiple devices.
        Medness @hoverteamph
        @hoverteamph did they help you? How do you free up spaces that are unselected for deletion?
          Rich O Brien Moderator @Medness
          @Medness Update Sketchucation Tools to latest version: https://sketchucation.com/plugin/696-sketchucationtools on all devices to enable online releasing
          If you run into issues email us at support[at]sketchucation.com
            aleman_1940 Newcomers
            I have an error with the JointPushPull pluggin, every time i try the "J" Jointpushpull tool appears this error, i have the libfredo6-v16.a and the JointPushPull-v4.8a
            I Just wanted to make thicker a simple rectangle, i know i can use the other tools, but why do this error keeps appearing me
            What can i do?
            fredo6F 1 Reply Last reply Reply Quote 0
            • fredo6F Offline
              fredo6 @aleman_1940
              @aleman_1940
              I would need to get the model where it is faulty.
              Possibly, you may work on tiny faces....
                jskwonb
                This post is deleted!
                TIGT 1 Reply Last reply Reply Quote 0
                  TIG Moderator @jskwonb
                  @jskwonb
                  Have you tried following the advice in the error-message ?
                  Have you installed the latest versions of the extension, LibFredo6 and the SketchUcation tools [for the licensing], and restarted Sketchup to sync every thing ?
                  Also, this kind of error relating to reading a license file often occurs if your computer has not been named following Microsoft's conventions - e.g. its name should contain only ASCII letters and numbers, and a few other common punctuation characters; it should not contain special characters [I note your image's name contains some Asian characters]. You could try renaming your computer ?? Also your PC's user-name has similar restrictions...
                  • W Offline
                    wkearney99 @whddnjs8474
                    Does 4.8a support doing vector pulls to a plane using SU2017?
                    I'm not seeing the added elements on the toolbar for it.
                    • fredo6F Offline
                      fredo6 @wkearney99
                      @wkearney99
                      Do you mean the option in the Misc section?
                      Normally, there is no difference between Sketchup versions.
                      W 1 Reply Last reply Reply Quote 0
                      • W Offline
                        wkearney99 @fredo6
                        @fredo6 yes, those, I don't see contours and the rest.
                        do they only appear when you're manipulating a certain kind of shapes or something?
                        I created a shape, selected some faces, selected the V tool
                        I ask this because I'm using the trial version and wanted to make sure I wasn't going to purchase something that wasn't going to work. I'm only using SU for 3D printing hobby stuff. I don't mind spending a few bucks to get decent software. I just wanted to make sure it'd work with what I've got.
                        - Sketchup: 17.2.2555
                        - LibFredo6: v14.9a
                        - LibFredo6 Binary loaded
                        - Sketchucation ExtensionStore: 4.4.1
                        - SCFLicense: v6.4a - 74
                        - Fredo6 Plugins
                            > FredoCorner v2.7a
                            > JointPushPull v4.8a
                            > RoundCorner v3.4a
                        - SCFLicense directory present
                            > Signature File: absent
                        Forgive me if I'm not doing something right. I saw the plugin on some videos and have tried to follow their steps and got stymied at not seeing the contour and other buttons.
                        My use-case for this is I've got a surface mesh from an STL that I want to extrude to a flat plane behind it.
                        • W Offline
                          wkearney99 @wkearney99
                          @wkearney99 oh wait, I'm a dope, I didn't know about this button: 9dcfdde9-fc59-4b7b-a672-35ca04849d7e-image.png
                          Which gives me:
                          so, yeah, nevermind...
                          • fredo6F Offline
                            fredo6 @wkearney99
                            @wkearney99
                            Yes, all buttons palettes in JPP have a compact mode, because some users said there was too many options....!
                              Msayed25say
                              so the plugin does not work offline?!
                              • fredo6F Offline
                                NEW RELEASE: JointPushPull Interactive v4.9a - 02 Apr 25
                                JointPushPull Interactive 4.9a is a major release including:
                                • Trimming and Hole Extrusion
                                IMPORTANT: JointPushPull 4.9a requires LibFredo6 15.3 or above
                                See plugin home page of JointPushPull for Download of JointPushPull.
                                Main Post of the JointPushPull thread on this forum
                                • Gus RG Offline
                                  Gus R
                                  I don't know what I changed but I'm suddenly getting like beveled offset when using Joint Push Pull. Just the regular Joint Push Pull.
                                  www.instagram.com/gusrobatto/
                                  www.facebook.com/gusrobatto
                                  • Gus RG Offline
                                    Gus R @Gus R
                                    @Gus-R Never mind.
                                    • F Offline
                                      ferol
                                      I just bought the plugin and am testing it. I thought I could replace the classic push-pull with some of its functions, but I have a problem: when I "push" inside an object, the surface often disappears. I made a short video about it:
                                      The only icons that don't do this are "R" and "F."
                                      Is this a bug?
                                      • F Offline
                                        ferol
                                        Is this a bug?
                                        • 30
                                        • 31
                                        • 3 / 31
