    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 631.5k Views 155 Watching
    • Rich O BrienR Online
      Rich O Brien Moderator @Medness
      @Medness Asking where to email license files is not the same as logging into a separate account and puchasing.
      I can purchase licenses and ask to send them any email address for convenience. But the license files have to be associated to a user account.
      In your instance you have multiple accounts so login to Medness1000 and you'll see JPP there
      Merging is not possible.
      • fredo6F Offline
        fredo6 @Medness
        @Medness
        Actually, the name part of the email address was registered in full lowercase for JointPushPull (versus first letter capitalized for TopoShaper and Curviloft).
        I guess the system should be case insensitive to email adress...
        • H Offline
          hoverteamph Newcomers @Rich O Brien
          @Rich-O-Brien 80eb2409-c9b4-4185-b624-937287b0b518-image.png I have also same issue but the problem is the seats that doesnt have check box for releasing are PC is already been dispose. Is there a way where we can force to release this seats? There's a lot on my licensing that are like this please help. Thank you .
          M 1 Reply Last reply Reply Quote 0
          • Y Offline
            yahyamsy
            Hi, I am just one guy, i don't need 3-seat license. is there a way to get JPP cheaper for one seat only Plz?!!
            thanks
              Rich O Brien Moderator @yahyamsy
              @yahyamsy it is 1 license that has 3 seats/activations to allow a license holder use it on multiple devices.
                Medness @hoverteamph
                @hoverteamph did they help you? How do you free up spaces that are unselected for deletion?
                  @Medness Update Sketchucation Tools to latest version: https://sketchucation.com/plugin/696-sketchucationtools on all devices to enable online releasing
                  If you run into issues email us at support[at]sketchucation.com
                    aleman_1940 Newcomers
                    I have an error with the JointPushPull pluggin, every time i try the "J" Jointpushpull tool appears this error, i have the libfredo6-v16.a and the JointPushPull-v4.8a
                    I Just wanted to make thicker a simple rectangle, i know i can use the other tools, but why do this error keeps appearing me
                    What can i do?
                    fredo6F 1 Reply Last reply Reply Quote 0
                    • fredo6F Offline
                      fredo6 @aleman_1940
                      @aleman_1940
                      I would need to get the model where it is faulty.
                      Possibly, you may work on tiny faces....
                        jskwonb
                        This post is deleted!
                        TIGT 1 Reply Last reply Reply Quote 0
                          TIG Moderator @jskwonb
                          @jskwonb
                          Have you tried following the advice in the error-message ?
                          Have you installed the latest versions of the extension, LibFredo6 and the SketchUcation tools [for the licensing], and restarted Sketchup to sync every thing ?
                          Also, this kind of error relating to reading a license file often occurs if your computer has not been named following Microsoft's conventions - e.g. its name should contain only ASCII letters and numbers, and a few other common punctuation characters; it should not contain special characters [I note your image's name contains some Asian characters]. You could try renaming your computer ?? Also your PC's user-name has similar restrictions...
                          • W Offline
                            wkearney99 @whddnjs8474
                            Does 4.8a support doing vector pulls to a plane using SU2017?
                            I'm not seeing the added elements on the toolbar for it.
                            • fredo6F Offline
                              fredo6 @wkearney99
                              @wkearney99
                              Do you mean the option in the Misc section?
                              Normally, there is no difference between Sketchup versions.
                              W 1 Reply Last reply Reply Quote 0
                              • W Offline
                                wkearney99 @fredo6
                                @fredo6 yes, those, I don't see contours and the rest.
                                do they only appear when you're manipulating a certain kind of shapes or something?
                                I created a shape, selected some faces, selected the V tool
                                I ask this because I'm using the trial version and wanted to make sure I wasn't going to purchase something that wasn't going to work. I'm only using SU for 3D printing hobby stuff. I don't mind spending a few bucks to get decent software. I just wanted to make sure it'd work with what I've got.
                                - Sketchup: 17.2.2555
                                - LibFredo6: v14.9a
                                - LibFredo6 Binary loaded
                                - Sketchucation ExtensionStore: 4.4.1
                                - SCFLicense: v6.4a - 74
                                - Fredo6 Plugins
                                    > FredoCorner v2.7a
                                    > JointPushPull v4.8a
                                    > RoundCorner v3.4a
                                - SCFLicense directory present
                                    > Signature File: absent
                                Forgive me if I'm not doing something right. I saw the plugin on some videos and have tried to follow their steps and got stymied at not seeing the contour and other buttons.
                                My use-case for this is I've got a surface mesh from an STL that I want to extrude to a flat plane behind it.
                                • W Offline
                                  wkearney99 @wkearney99
                                  @wkearney99 oh wait, I'm a dope, I didn't know about this button: 9dcfdde9-fc59-4b7b-a672-35ca04849d7e-image.png
                                  Which gives me:
                                  so, yeah, nevermind...
                                  • fredo6F Offline
                                    fredo6 @wkearney99
                                    @wkearney99
                                    Yes, all buttons palettes in JPP have a compact mode, because some users said there was too many options....!
                                      Msayed25say
                                      so the plugin does not work offline?!
                                      • fredo6F Offline
                                        NEW RELEASE: JointPushPull Interactive v4.9a - 02 Apr 25
                                        JointPushPull Interactive 4.9a is a major release including:
                                        • Trimming and Hole Extrusion
                                        IMPORTANT: JointPushPull 4.9a requires LibFredo6 15.3 or above
                                        See plugin home page of JointPushPull for Download of JointPushPull.
                                        Main Post of the JointPushPull thread on this forum
                                        • Gus RG Offline
                                          Gus R
                                          I don't know what I changed but I'm suddenly getting like beveled offset when using Joint Push Pull. Just the regular Joint Push Pull.
                                          www.instagram.com/gusrobatto/
                                          www.facebook.com/gusrobatto
                                          • Gus RG Offline
                                            Gus R @Gus R
                                            @Gus-R Never mind.
                                            • 30
                                            • 31
                                            • 8 / 31
