    V-Ray scripting in ruby?
    renderpluginsextensions
    14 Posts 6 Posters 6.6k Views 6 Watching
    • TedVitale_CGT
      TedVitale_CG
      Send me a PM and Ill email over a short example from one of the Developers.
      Ted Vitale
      Owner | Creative Director
      http://www.voxl.vision
        mcekk
        Thanks Ted.
        Manuel Eguia
        Associate Professor
        University of Quilmes
        • dkendigD
          dkendig
          no, that file gets overridden when you kick off a render. There are some helper functions we use to manipulate the xml that we store in the attribute dictionaries of the scene, but none of it is very obvious or easy to use for your own purposes. We are also going to be modifying the way a lot of our stuff works over the next couple versions, so if you were to tap in to our xml and play with it, it might not have a very long lifespan.
          Devin Kendig
          Developer
            mcekk
            Thanks for the answer, Devin. Is there another V-Ray implementation where I can animate the illumination? Or I have to wait that this feature comes to SU? I also work with Blender. Thanks in advance.
            Manuel Eguia
            Associate Professor
            • dkendigD
              dkendig
              we currently don't support animated parameters in any portion of V-Ray for SketchUp
              Devin Kendig
              Developer
                mcekk
                I was able to do some short progress modifying the skp files from each light separately and reloading through the ruby script. The only thing that it is still missing is the possibility to render the scene from the script. It is possible to do this from the SU API or from the system? Thanks in advance.
                Manuel Eguia
                Associate Professor
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  Yes, you can call
                  VRayForSketchUp.launch_vray_render
                  VRayForSketchUp.launch_vray_rt_render
                  VRayForSketchUp.launch_vray_batch_render
                    mcekk
                    Many Thanks Jiminy. !
                    Manuel Eguia
                    Associate Professor
                    • T
                      tuanminhtq
                      How to call this to run Vray in ruby, please help, thanks alot
                      V 1 Reply Last reply
                      • V
                        Vizan @tuanminhtq
                        @tuanminhtq said in V-Ray scripting in ruby?:
                        Have you found a solution?
