    V-Ray scripting in ruby?
    renderpluginsextensions
    14 Posts 6 Posters 6.6k Views 6 Watching
    • jiminy-billy-bobJ
      jiminy-billy-bob
      As far as I know, there is no API for VfS.
      But the data is stored as XML in the object's attribute. So you can modify it to change the light's properties.
        mcekk
        Thanks, Ted and Jiminy for the quick response.
        Can I safely edit the file current_skp.xml (located at ASGVIS/VfS), that apparently stores the current global parameters?
        Still can't find the light parameters.
        Manuel Eguia
        Associate Professor
        University of Quilmes
        • TedVitale_CGT
          TedVitale_CG
          Send me a PM and Ill email over a short example from one of the Developers.
          Ted Vitale
          Owner | Creative Director
          http://www.voxl.vision
            mcekk
            Thanks Ted.
            Manuel Eguia
            Associate Professor
            • dkendigD
              dkendig
              no, that file gets overridden when you kick off a render. There are some helper functions we use to manipulate the xml that we store in the attribute dictionaries of the scene, but none of it is very obvious or easy to use for your own purposes. We are also going to be modifying the way a lot of our stuff works over the next couple versions, so if you were to tap in to our xml and play with it, it might not have a very long lifespan.
              Devin Kendig
              Developer
                mcekk
                Thanks for the answer, Devin. Is there another V-Ray implementation where I can animate the illumination? Or I have to wait that this feature comes to SU? I also work with Blender. Thanks in advance.
                Manuel Eguia
                Associate Professor
                • dkendigD
                  dkendig
                  we currently don't support animated parameters in any portion of V-Ray for SketchUp
                  Devin Kendig
                  Developer
                    mcekk
                    I was able to do some short progress modifying the skp files from each light separately and reloading through the ruby script. The only thing that it is still missing is the possibility to render the scene from the script. It is possible to do this from the SU API or from the system? Thanks in advance.
                    Manuel Eguia
                    Associate Professor
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      Yes, you can call
                      VRayForSketchUp.launch_vray_render
                      VRayForSketchUp.launch_vray_rt_render
                      VRayForSketchUp.launch_vray_batch_render
                        mcekk
                        Many Thanks Jiminy. !
                        Manuel Eguia
                        Associate Professor
                        • T
                          tuanminhtq
                          How to call this to run Vray in ruby, please help, thanks alot
                          V 1 Reply Last reply
                          • V
                            Vizan @tuanminhtq
                            @tuanminhtq said in V-Ray scripting in ruby?:
                            Have you found a solution?
