    V-Ray scripting in ruby?
    renderpluginsextensions
    14 Posts 6 Posters 6.6k Views 6 Watching
      mcekk
      Hi everyone,
      Is it possible to access methods and/or classes for V-Ray objects through the SU API?
      I want to edit the lights, materials and rendering options in an automated way.
      So far, I was able to apply geometric transformations to the lights using the following method:
      1. I created a separated .skp file for each of the light objects (rectangle, spot, omni) with fixed parameters. These objects are saved as groups.
      2. I loaded these files as component definitions and created instances as needed.
      3. I applied geom transformations (translations rotations and scaling) to those components to set up the scene.
      However I also want to change some parameters of the lighting and the materials from the script. Where is this information stored? Is there a xml file somewhere?
      Thanks in advance
      SU 2014 + VR2.0
      Manuel Eguia
      Associate Professor
      University of Quilmes
      • TedVitale_CGT
        TedVitale_CG
        Ill forward your question to the developers and get back to you when I have an answer.
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
        • jiminy-billy-bobJ
          jiminy-billy-bob
          As far as I know, there is no API for VfS.
          But the data is stored as XML in the object's attribute. So you can modify it to change the light's properties.
            mcekk
            Thanks, Ted and Jiminy for the quick response.
            Can I safely edit the file current_skp.xml (located at ASGVIS/VfS), that apparently stores the current global parameters?
            Still can't find the light parameters.
            Manuel Eguia
            Associate Professor
            • TedVitale_CGT
              TedVitale_CG
              Send me a PM and Ill email over a short example from one of the Developers.
              Ted Vitale
                mcekk
                Thanks Ted.
                Manuel Eguia
                Associate Professor
                • dkendigD
                  dkendig
                  no, that file gets overridden when you kick off a render. There are some helper functions we use to manipulate the xml that we store in the attribute dictionaries of the scene, but none of it is very obvious or easy to use for your own purposes. We are also going to be modifying the way a lot of our stuff works over the next couple versions, so if you were to tap in to our xml and play with it, it might not have a very long lifespan.
                  Devin Kendig
                  Developer
                    mcekk
                    Thanks for the answer, Devin. Is there another V-Ray implementation where I can animate the illumination? Or I have to wait that this feature comes to SU? I also work with Blender. Thanks in advance.
                    Manuel Eguia
                    Associate Professor
                    • dkendigD
                      dkendig
                      we currently don't support animated parameters in any portion of V-Ray for SketchUp
                      Devin Kendig
                      Developer
                        mcekk
                        I was able to do some short progress modifying the skp files from each light separately and reloading through the ruby script. The only thing that it is still missing is the possibility to render the scene from the script. It is possible to do this from the SU API or from the system? Thanks in advance.
                        Manuel Eguia
                        Associate Professor
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          Yes, you can call
                          VRayForSketchUp.launch_vray_render
                          VRayForSketchUp.launch_vray_rt_render
                          VRayForSketchUp.launch_vray_batch_render
                            mcekk
                            Many Thanks Jiminy. !
                            Manuel Eguia
                            Associate Professor
                            • T
                              tuanminhtq
                              How to call this to run Vray in ruby, please help, thanks alot
                              V 1 Reply Last reply
                              • V
                                Vizan @tuanminhtq
                                @tuanminhtq said in V-Ray scripting in ruby?:
                                Have you found a solution?
