    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 29.1k Views 7 Watching
      Mike Amos @Mike Amos
      I feel like I am re-learning this dark art. new perspectives on things I suppose.
      Health wise stuff is loud. Certain sensations etc which are dementia alike bring a feeling of not really being in charge of the mental process, forgetting stuff for example.
      I believe this older pc is just outclassed by Rayscaper so while I try to lay out this flat, post window replacement I will be limiting myself to Twilight and Maxwell for rendering.
      For those of you who also have little niggling doubts about 'stuff', you CAN get through whatever the issue is. Noli Illegitemi Carbonundrum.
      I apologise for asking questions which probably should be simple to 'know', I'm going to do what I can. This place remains important to me for the joy we share on building and rendering whatever the hell it is we make.
      Keep on keeping on, never let crap get in the way of trying to be the best you can be 'today'.
      Tomorrow is merely smoke and mirrors.
      • Rich O BrienR Online
        @Mike-Amos said in Rayscaper, My trip down the road to adjumacation.:
        There's no need to apologize for what you consider simple questions. Path tracing render engines are complex beasts.
        I encourage to stay on your journey. Learning new apps and techniques is good for the mind.
        You can still achieve a lot with the hardware you have.
          Mike Amos @Rich O Brien
          @Rich-O-Brien
          Another little 'lesson' todays crash provided some ino at least.
          Crash #298860
          It looks like there might be an issue with Microsoft Visual Studio. The Microsoft Visual Studio C++ Redistributables are required for SketchUp to run and may need to be reloaded. Please try the following:
          Check to make sure your graphics drivers are up to date: https://help.sketchup.com/en/sketchup/how-can-i-update-my-computers-graphics-driver
          Quit SketchUp (and LayOut)
          Go to Add/Remove Programs and uninstall the Microsoft Visual Studio C++ 2015 and above Redistributables (there may be a 32-bit and 64-bit version)
          Uninstall SketchUp from Add/Remove Programs
          Re-run the SketchUp installer. You can download it here if you need it: https://www.sketchup.com/offline-download
          Restart your computer
          If you continue to experience issues please reach out to our support staff at: https://help.sketchup.com/en/contact-support/technical-question/form
            Hey Mike,
            I hope you are doing alright!
            Your specs should be good for rendering with Rayscaper. CPU rendering, in particular, should require nothing beefier than what's needed for Twilight Render.
            Echoing Rich's statement, there is no need to apologize! It's indeed a complex matter, and you have already produced great results. Having you as a user definitely makes Rayscaper better. You have the patience to tolerate beta software and have helped me squash a lot of bugs so far.
            Cheers,
            Thomas
              Mike Amos @pixelcruncher
              @pixelcruncher
              I'm doing OK, Thomas.
              Certainly finding there are system wide issues, no matter how small they are, reduces my "I am so stoopid" sensation a fair bit and I am looking in to ways to understand and work round this.
              The disk issue and the visual studio ussues point out there being life in the old pc yet.
              I am talking to various people around hardware and software issues and hope to get a solution within a few days.
              All jokes aside and despite 'issues'. I am still a lucky barkeep.
                @Mike-Amos
                2024/Tools/extensions.rb:197:in `eval'
                C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in `require'
                C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in `load'
                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rayscaper.rb:18:in `register_extension'
                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rayscaper.rb:18:in `<module:Rayscaper>'
                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rayscaper.rb:6:in `<top (required)>'
                  @Mike-Amos Sorry to hear that you are running into this.
                  Which version did you try to reinstall? Can you provide me with the filename of the *.rbz file? Could it be that you tried to install one of the older versions that is not SU2024 compatible? Nevermind this, I think the ones downloaded from SketchUcation are all named Rayscaper.rbz.
                  Can you try to reinstall Rayscaper using this guide: https://rayscaper.com/getting-started/installation-guide/#download-and-install-via-the-sketchup-extension-manager?
                  It's not a licensing issue like you mentioned in your email; I think the installation is broken.
                  Cheers,
                  Thomas
                    @pixelcruncher
                    Extension Errors Report
                    SketchUp: 24.0.594
                    OS: Windows 10
                    Ruby: 3.2.2
                    Extension: Rayscaper (0.9.30 Beta)
                    Error: LoadError (126: The specified module could not be found. - c:/users/user/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/rayscaper/installed/Windows/3.2.2/0.9.30 Beta/resources/SUEX_Rayscaper.so)
                    <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                    c:/users/user/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/rayscaper/main.rbe:97:in <module:Rayscaper>' c:/users/user/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/rayscaper/main.rbe:5:in <main>'
                    C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require'
                    C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rayscaper.rb:18:in register_extension'
                    C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rayscaper.rb:18:in <module:Rayscaper>' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rayscaper.rb:6:in <top (required)>'
                    James at Seeit3d believes the Sketchucation store is broken.
                    Numerous reinstals and various different plugins fail each time I go through the uninstall plugin folder and reinstall.
                    P Rich O BrienR 2 Replies Last reply Reply Quote 0
                      pixelcruncher Extension Creator @Mike Amos
                      @Mike-Amos
                      Do you mind trying a direct install? You can download the RBZ file from here: link. This should download the RBZ file directly from my Google drive.
                      And then install it in SketchUp directly via the extension manager: Menu > Extensions > Extension Manager:
                      Restart SketchUp after a successful installation.
                      That should exclude SketchUcation.
                      Thanks,
                      Thomas
                        Fake news
                          @Rich-O-Brien
                          C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/DM_artisan2.rb:21:in `register_extension'
                          C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/DM_artisan2.rb:21:in `<module:Artisan2>'
                          C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/DM_artisan2.rb:8:in `<module:DM>'
                          C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/DM_artisan2.rb:7:in `<top (required)>'
                          All sorts of errors with plugins, weird but the samsung disk scan suggested recovery for the drive which has failed due to an unknown error.
                            @Mike-Amos
                            Greyed out, nothing doing anywhere.
                              As I explained in our chat room. Greyed out is not representative of 'not working'.
                              Greyed out = Installed outside of SketchUp's ecosystem
                              I think your issues are bigger than 3rd party extensions.
                              If you run Windows own Disk Check what is the report?
                              So right click your drive, choose Properties, Tools tab and click Check
                                @Rich-O-Brien
                                Weird, this suggests an error on the E drive which the other scanning programs report as healthy.
                                    A little stability at the moment. Not sorted yet but moving forwards.
                                      @Mike-Amos
                                      I think a less ;busy' tile texture will work better on this machine and there is no artificial lighting in that render.
                                      Native Sketchup lighting only.
                                        I think the tile choice HAS mad a difference. Not a true comparison seeing as this render went to 1000 samples and used the GPU for rendering.
                                        Still no artificial light but the lighter tile bounces rays more effectively.
                                          An exterior view of this small home in a hdri.
                                            @Mike-Amos very nice, I like the concept.
                                            • 7 / 9
