    Rayscaper Sample Model Download
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    rayscaper
    22 Posts 4 Posters 887 Views 4 Watching
    • ntxdaveN Offline
      ntxdave
      I have installed Rayscaper to try to learn how to use it. Β When I go to the Quick Start guide there is a link to download the sample model (rs_shader_ball-scene[v2020].skp) but when I click on it, it goes to the SketchUcation site. How do you find/download the sample file to use for the tutorial?
      Press F1...thank me later
      • Rich O BrienR Rich O Brien marked this topic as a question on
        pixelcruncher Extension Creator @ntxdave
        @ntxdave
        Welcome to the club! It looks indeed like the link is broken; thanks for reporting. Must have been the forum upgrade?
        Here is the file: https://community.sketchucation.com/uploads/imported_attachments/RziO_rs_shader_ball-scenev2020.skp
        And here is the original post from @Rich-O-Brien where he shares the file: https://community.sketchucation.com/post/1603104
        Cheers,
        Thomas
        • ntxdaveN Offline
          ntxdave @ntxdave
          @ntxdave How do you upload a file/skp model?
          P massimoM 2 Replies Last reply Reply Quote 0
            @ntxdave
            Cheers,
            Thomas
            • massimoM Offline
              massimo Moderator @ntxdave
              @ntxdave said in Rayscaper Sample Model Download:
              You mean here on the forum? If so, this doesn't work for you?
              You can also drag & drop the file in the blank area where you write the reply I guess.
              • ntxdaveN Offline
                ntxdave @pixelcruncher
                @pixelcruncher Thanks for posting a link to the file. I want to use it to try to understand a couple of things in your tutorial.
                I did not see Rich's link. The link in your documentation takes you to a page where the model is not available.
                • ntxdaveN Offline
                  ntxdave @massimo
                  @massimo I do not see the Upload file link on my reply page.
                  I tried to drag a file into the empty space and I got an error message that said I did not have enough privileges. So there is no way I can upload a file.
                  I have never seen this problem before.
                  massimoM 1 Reply Last reply Reply Quote 0
                  • massimoM Offline
                    This is definitely strange since you have a reputation even higher than mine... Perhaps Rich or Gabor may chime in with an explanation.
                      @ntxdave I think the original links got broken with the forum upgrade. I also updated the link now on my website. Thanks, for reporting!
                      • ntxdaveN Offline
                        @pixelcruncher I am having a problem trying to get started. Here is what I am seeing when I click on the Rayscaper icon in SU 2024.
                        According to the video, I thought I was using the correct file. I am using RziO_rs_shader_ball-scenev2020
                        What is going on/am I doing wrong?
                          Rich O Brien Moderator @ntxdave
                          @ntxdave Looks like you've no lights or environment to cast light.
                          Please bear in mind that older Rayscaper builds and files that worked on those builds may not work as expected on newer Rayscaper builds.
                          For info on how to add environmental light or light components I suggest seeing if it is covered in the docs.
                          • ntxdaveN Offline
                            ntxdave
                            I was using the file from the tutorial and just clicked on the RayScaper icon and that is what showed up. I thought this was a file you created. I thought I did exactly what was shown in the tutorial. To me, this isnot solved.
                              @ntxdave
                              Try this one but it is in your own interest to troubleshoot so you can get a firm grasp of the software.
                              ROBR_rs_shader_ball-scene.skp
                              As I mentioned, older files were tailored to earlier builds. Expect unwanted results. Rayscaper is not a finished product.
                              • ntxdaveN Offline
                                ntxdave @Rich O Brien
                                @Rich-O-Brien Thanks Rich. This file worked MUCH better. It is not exactly like the one in the in the video but it is close enough that I can now get the hang of things.
                                I will now have to try some stuff with one of my own models.
                                I appreciate your feedback/support so I can begin to try Rayscaper and hopefully start moving forward.
                                  @Rich-O-Brien Thanks for fixing.
                                  Recently, the range of exposure values changed, bringing this scene to an exposure of -10, rendering everything dark. Setting it to zero would have fixed this.
                                  Like Rich said, it's still beta software, so there might be quirks.
                                  • ntxdaveN Offline
                                    @pixelcruncher Well, after playing around and trying a lot of settings, here is my first render. The metal frame is not quite as shinny as I would like it but, again, this is my first render. Also, the background is darker that I would like.
                                    • ntxdaveN Offline
                                      ntxdave @ntxdave
                                      @ntxdave OK, now I have a silly question. Is there a way to save the settings I used in the above render?
                                        Hey @ntxdave ,
                                        It's great to see you are already getting results with Rayscaper!
                                        As a first check, make sure you are using the global illumination render method. It's slower than approximate GI, but approximate GI is not photorealistic and doesn't render materials correctly, always favoring speed.
                                        What material are you using for the metal surfaces? The metal material or the Disney material? The roughness slider allows you to control the shininess of either material. The below renders show a chrome ball with three different roughness settings (0, 0.20, and 0.50).
                                        You can control that via the environment settings. Either adjust the color (or use an image) or adjust the power.
                                        You can also drag & drop one of the HDRIs to get more realistic lighting:
                                        Does that help?
                                        Cheers,
                                        Thomas
                                        • ntxdaveN Offline
                                          @pixelcruncher Thank you sir. I will give these a try. πŸ‘
                                          This is all part of the learning process. πŸ™‚
                                          • ntxdaveN Offline
                                            ntxdave
                                            Well, progress, I think. But still a LOT to learn about how to use the tool.
                                            Oh No, the background in the render is not what I was seeing during the render.
                                            BTW: Here is the settings I used for the frame which is still not exactly as shinny as I was wanting.
                                              Can you clarify shininess πŸ™‚ From looking at the gray frame, it seems like a perfect mirror.
