    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      alt text
      alt text
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        The original 3D cladding tutorial showed the following four materials:
        • Board and Batten
        • Shiplap
        • Log
        • Lap
        The three additional ones added since this video are:
        • Metal
        • Shiplap (Vertical)
        • Dutchlap
        There are now seven different types of 3D cladding materials one can configure within the Custom Material Library.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.6.1 - 05.13.2024
          Added Symbol 2 Layer specfically for 2D door swing symbols (Layer tab of the global settings).
          http://design.medeek.com/resources/wallplugin/images7/wall_su763_800.jpg
          design.medeek.com
          • medeekM Offline
            medeek
            I will be running a Memorial Day promotion beginning May 22th until Jun. 5th with 35% off of the regular mdkBIM bundle price (permanent license) using the coupon code MEMORIAL24.
            This will reduce the bundle price from $280.00 USD to $182.00 USD. This promo code does not apply to any of the extensions purchased separately. As part of this promotion a permanent license for the electrical plugin will be included upon request at no additional cost. The offer ends on Jun. 5th and no rain checks will issued thereafter.
            alt text
            design.medeek.com
            design.medeek.com
            • medeekM Offline
              medeek
              Double sliders are kind of interesting windows.
              [img]https://global.discourse-cdn.com/sketchup/original/3X/6/4/64053bedf882932aab501290cdb0080fb93e8c0e.gif[/img]
              Sometimes I forget how cool it is to be able to create something like this in SketchUp and have it animate like it does. Can I say I love my job?
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.6.3 - 06.06.2024
                • Enabled elevation swing/opening lines for doors and windows.
                • Added elevation swing line annotation settings to the Door tab of the Global Settings.
                • Added elevation swing line annotation settings to the Window tab of the Global Settings.
                • Enabled opening and closing for all double hung type windows.
                http://design.medeek.com/resources/wallplugin/images7/wall_su771_800.jpg
                http://design.medeek.com/resources/wallplugin/images7/wall_su772_800.jpg
                design.medeek.com
                • medeekM Offline
                  medeek
                  Tutorial 48 - Elevation Swing Lines (8:31 min.)
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.6.4 - 06.08.2024
                    • Added the following additional Wide Flange (W) beams to the beam module: W10X49, W10X54, W10X60, W10X68, W10X77, W10X88, W10X100, W10X112, W12X45, W12X50, W12X53, W12X58, W12X65, W12X72, W12X79, W12X87, W12X96, W12X106, W12X120, W12X136, W12X152, W12X170, W12X190, W30X90, W30X99, W30X108.
                    • Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS2.75/10, HGUS2.75/12, HGUS2.75/14, HGUS3.25/10, HGUS3.25/12, HGUS412, HGUS5.25/10, HGUS5.25/12, HGUS5.5/8, HGUS5.5/10, HGUS5.5/12, HGUS5.5/14, HGUS7.25/8, HGUS7.25/10, HGUS7.25/12, HGUS7.25/14.
                    • Allowed the use of a period "." in custom beam hanger library names.
                    http://design.medeek.com/resources/wallplugin/images7/wall_su776_800.jpg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.6.5 - 06.12.2024
                      • Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS5.62/10, HGUS5.62/12, HGUS5.62/14, HGUS6.88/10, HGUS6.88/12, HGUS6.88/14, HGUS7.37/10, HGUS7.37/12, HGUS7.37/14, HGUS26, HGUS26-2, HGUS26-3, HGUS26-4, HGUS28, HGUS28-2, HGUS28-3, HGUS28-4, HGUS210, HGUS210-2, HGUS210-3, HGUS210-4, HGUS212-3, HGUS212-4, HGUS214-3, HGUS214-4, HGUS5.25/10, HGUS46, HGUS48, HGUS410, HGUS412.
                      design.medeek.com
                      medeekM 1 Reply Last reply Reply Quote 1
                      • medeekM Offline
                        medeek @medeek
                        Tutorial 49 - Component Libraries (13:05 min.)
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.6.6 - 06.24.2024
                          • Added hardware (caps and bases) options to the post module.
                          • Updated the material/color parameter for (exterior) wall trim to include custom materials.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Tutorial 50 - Post Hardware (8:45 min.)
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.6.6b - 06.24.2024 thru 06.25.2024
                              • Fixed a minor bug with the post cap positioning algorithm.
                              • Added the following Simpson post cap: APL6
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 3.6.7 - 06.27.2024
                                • Updated the post module to include multi-part installations for Simpson heavy angles (post cap).
                                • Added the following Simpson heavy angles to the post module: HL33, HL35, HL35G, HL37, HL37G, HL43, HL46, HL46G, HL49, HL49G, HL53,HL55, HL55G, HL57, HL57G, HL73, HL76, HL76G, HL79, HL79G
                                404 - File or directory not found.
                                (design.medeek.com)
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 3.6.8 - 06.28.2024
                                  • Added the following built-in ICF (block) materials: Nudura, Fox Blocks.
                                  • Added the following Simpson column bases to the post module: CPT44Z, CPT66Z, CPT88Z
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 3.6.9 - 07.23.2024
                                    • Enabled "Remove Cladding Lines" for 3D cladding materials.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 3.7.0 - 07.25.2024
                                      • Added a duplicate wall check to the regen module for all wall types.
                                      Tutorial 51 - Duplicating Walls (6:15 min.)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 3.7.1 - 09.17.2024
                                        • Added a vertical offset parameter for in-wall column king studs.
                                        In the case where you have a beam pocket and king studs over top of a door or window this update is critical. Previously the king studs would simply project to the bottom plate in the wall passing through the opening. Now you can utilize this extra parameter to vertically offset these king studs the same way the column itself is offset. Note that the offset can be both positive or negative or zero (default)
                                        design.medeek.com
                                        gullfoG 1 Reply Last reply Reply Quote 1
                                        • gullfoG Offline
                                          gullfo @medeek
                                          honestly though, if i was putting in a beam support over the opening, i've have either an additional jack stud under the header/lintel, or a X x X sized column on either side, and likely as well as a glulam etc type header/lintel. unless the beam was only supporting some deadweight and not a live area above. just me probably...
                                          Glenn
                                          http://www.runnel.com
                                          • medeekM Offline
                                            medeek
                                            I wasn't paying attention to a realistic header with trimmers, just focusing on the king stud offset, I agree, a few things would need to be beefed up to handle this type of beam configuration. I've only actually engineered one job with this type of beam over window(s).
                                            design.medeek.com
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 75
                                            • 76
                                            • 57 / 76
