    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 3.6.3 - 06.06.2024
      • Enabled elevation swing/opening lines for doors and windows.
      • Added elevation swing line annotation settings to the Door tab of the Global Settings.
      • Added elevation swing line annotation settings to the Window tab of the Global Settings.
      • Enabled opening and closing for all double hung type windows.
      http://design.medeek.com/resources/wallplugin/images7/wall_su771_800.jpg
      http://design.medeek.com/resources/wallplugin/images7/wall_su772_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Tutorial 48 - Elevation Swing Lines (8:31 min.)
        design.medeek.com
        • medeekM
          medeek
          Version 3.6.4 - 06.08.2024
          • Added the following additional Wide Flange (W) beams to the beam module: W10X49, W10X54, W10X60, W10X68, W10X77, W10X88, W10X100, W10X112, W12X45, W12X50, W12X53, W12X58, W12X65, W12X72, W12X79, W12X87, W12X96, W12X106, W12X120, W12X136, W12X152, W12X170, W12X190, W30X90, W30X99, W30X108.
          • Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS2.75/10, HGUS2.75/12, HGUS2.75/14, HGUS3.25/10, HGUS3.25/12, HGUS412, HGUS5.25/10, HGUS5.25/12, HGUS5.5/8, HGUS5.5/10, HGUS5.5/12, HGUS5.5/14, HGUS7.25/8, HGUS7.25/10, HGUS7.25/12, HGUS7.25/14.
          • Allowed the use of a period "." in custom beam hanger library names.
          http://design.medeek.com/resources/wallplugin/images7/wall_su776_800.jpg
          design.medeek.com
          • medeekM
            medeek
            Version 3.6.5 - 06.12.2024
            • Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS5.62/10, HGUS5.62/12, HGUS5.62/14, HGUS6.88/10, HGUS6.88/12, HGUS6.88/14, HGUS7.37/10, HGUS7.37/12, HGUS7.37/14, HGUS26, HGUS26-2, HGUS26-3, HGUS26-4, HGUS28, HGUS28-2, HGUS28-3, HGUS28-4, HGUS210, HGUS210-2, HGUS210-3, HGUS210-4, HGUS212-3, HGUS212-4, HGUS214-3, HGUS214-4, HGUS5.25/10, HGUS46, HGUS48, HGUS410, HGUS412.
            design.medeek.com
            medeekM 1 Reply Last reply
            • medeekM
              medeek @medeek
              Tutorial 49 - Component Libraries (13:05 min.)
              design.medeek.com
              • medeekM
                medeek
                Version 3.6.6 - 06.24.2024
                • Added hardware (caps and bases) options to the post module.
                • Updated the material/color parameter for (exterior) wall trim to include custom materials.
                design.medeek.com
                • medeekM
                  medeek
                  Tutorial 50 - Post Hardware (8:45 min.)
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 3.6.6b - 06.24.2024 thru 06.25.2024
                    • Fixed a minor bug with the post cap positioning algorithm.
                    • Added the following Simpson post cap: APL6
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 3.6.7 - 06.27.2024
                      • Updated the post module to include multi-part installations for Simpson heavy angles (post cap).
                      • Added the following Simpson heavy angles to the post module: HL33, HL35, HL35G, HL37, HL37G, HL43, HL46, HL46G, HL49, HL49G, HL53,HL55, HL55G, HL57, HL57G, HL73, HL76, HL76G, HL79, HL79G
                      404 - File or directory not found.
                      (design.medeek.com)
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 3.6.8 - 06.28.2024
                        • Added the following built-in ICF (block) materials: Nudura, Fox Blocks.
                        • Added the following Simpson column bases to the post module: CPT44Z, CPT66Z, CPT88Z
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 3.6.9 - 07.23.2024
                          • Enabled "Remove Cladding Lines" for 3D cladding materials.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 3.7.0 - 07.25.2024
                            • Added a duplicate wall check to the regen module for all wall types.
                            Tutorial 51 - Duplicating Walls (6:15 min.)
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 3.7.1 - 09.17.2024
                              • Added a vertical offset parameter for in-wall column king studs.
                              In the case where you have a beam pocket and king studs over top of a door or window this update is critical. Previously the king studs would simply project to the bottom plate in the wall passing through the opening. Now you can utilize this extra parameter to vertically offset these king studs the same way the column itself is offset. Note that the offset can be both positive or negative or zero (default)
                              design.medeek.com
                              gullfoG 1 Reply Last reply
                              • gullfoG
                                gullfo @medeek
                                honestly though, if i was putting in a beam support over the opening, i've have either an additional jack stud under the header/lintel, or a X x X sized column on either side, and likely as well as a glulam etc type header/lintel. unless the beam was only supporting some deadweight and not a live area above. just me probably...
                                Glenn
                                http://www.runnel.com
                                • medeekM
                                  medeek
                                  I wasn't paying attention to a realistic header with trimmers, just focusing on the king stud offset, I agree, a few things would need to be beefed up to handle this type of beam configuration. I've only actually engineered one job with this type of beam over window(s).
                                  design.medeek.com
                                  • gullfoG
                                    gullfo @medeek
                                    i don't have to do it often but a couple of recent projects have beams over doors to address the extended span of a room with the door the best option - in those cases we used steel i-beams as posts and header as well as the new beam in order to get the load supported needed with lower profile than wood products. so it's rarely needed but a useful option when you can get around to it. maybe even just leaving the space so manually someone could insert the members / assemblies would work.
                                    Glenn
                                    • medeekM
                                      medeek @gullfo
                                      @gullfo
                                      Post a screenshot or send me some via email (nathan@medeek.com) so I can get a better idea what this looks like. I will give it some consideration.
                                      design.medeek.com
                                      • gullfoG
                                        gullfo @medeek
                                        @medeek I'm away until Thurs I'll send some then
                                        Glenn
                                        • medeekM
                                          medeek
                                          design.medeek.com
                                          • gullfoG
                                            gullfo
                                            wall structure using additional support for beam over door or window.![example steel framing for beam over door. you would adda stud on each edge of the steel column to support the top plates. but this is the idea. today when this arises, i just manually remove the members and add the needed assemblies.
                                            Glenn
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 80
                                            • 81
                                            • 69 / 81
