    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.2m Views 26 Watching
    • medeekM Offline
      medeek
      Version 3.5.7 - 04.17.2024
      • Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.5.8 - 04.25.2024
        • Fixed a bug with cripple studs over windows and doors.
        • Fixed a bug with the copy wall tool.
        alt text
        design.medeek.com
        • medeekM Offline
          medeek
          [b]Version 3.5.9[/b] - 05.01.2024
          • Added a rainscreen option for gable walls (vertical, horizontal, 45 and 135 degree).
          • Added a rainscreen option for shed walls (vertical, horizontal, 45 and 135 degree).
          • Added a rainscreen option for hip walls (vertical, horizontal, 45 and 135 degree).
          • Updated the license verification system with a more secure and improved algorithm.
          design.medeek.com
          • medeekM Offline
            medeek
            [b]Version 3.6.0[/b] - 05.04.2024
            • Added the ability to create custom "Vertical Shiplap" wall cladding materials within the Material Library.
            • Enabled "3D" Vertical Shiplap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
            • Added the ability to create custom Dutchlap" wall cladding materials within the Material Library.
            • Enabled "3D" Dutchlap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
            alt text
            alt text
            This update per customer request.
            design.medeek.com
            • medeekM Offline
              medeek
              alt text
              alt text
              design.medeek.com
              • medeekM Offline
                medeek
                The original 3D cladding tutorial showed the following four materials:
                • Board and Batten
                • Shiplap
                • Log
                • Lap
                The three additional ones added since this video are:
                • Metal
                • Shiplap (Vertical)
                • Dutchlap
                There are now seven different types of 3D cladding materials one can configure within the Custom Material Library.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.6.1 - 05.13.2024
                  Added Symbol 2 Layer specfically for 2D door swing symbols (Layer tab of the global settings).
                  http://design.medeek.com/resources/wallplugin/images7/wall_su763_800.jpg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    I will be running a Memorial Day promotion beginning May 22th until Jun. 5th with 35% off of the regular mdkBIM bundle price (permanent license) using the coupon code MEMORIAL24.
                    This will reduce the bundle price from $280.00 USD to $182.00 USD. This promo code does not apply to any of the extensions purchased separately. As part of this promotion a permanent license for the electrical plugin will be included upon request at no additional cost. The offer ends on Jun. 5th and no rain checks will issued thereafter.
                    alt text
                    design.medeek.com
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Double sliders are kind of interesting windows.
                      [img]https://global.discourse-cdn.com/sketchup/original/3X/6/4/64053bedf882932aab501290cdb0080fb93e8c0e.gif[/img]
                      Sometimes I forget how cool it is to be able to create something like this in SketchUp and have it animate like it does. Can I say I love my job?
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.6.3 - 06.06.2024
                        • Enabled elevation swing/opening lines for doors and windows.
                        • Added elevation swing line annotation settings to the Door tab of the Global Settings.
                        • Added elevation swing line annotation settings to the Window tab of the Global Settings.
                        • Enabled opening and closing for all double hung type windows.
                        http://design.medeek.com/resources/wallplugin/images7/wall_su771_800.jpg
                        http://design.medeek.com/resources/wallplugin/images7/wall_su772_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Tutorial 48 - Elevation Swing Lines (8:31 min.)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.6.4 - 06.08.2024
                            • Added the following additional Wide Flange (W) beams to the beam module: W10X49, W10X54, W10X60, W10X68, W10X77, W10X88, W10X100, W10X112, W12X45, W12X50, W12X53, W12X58, W12X65, W12X72, W12X79, W12X87, W12X96, W12X106, W12X120, W12X136, W12X152, W12X170, W12X190, W30X90, W30X99, W30X108.
                            • Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS2.75/10, HGUS2.75/12, HGUS2.75/14, HGUS3.25/10, HGUS3.25/12, HGUS412, HGUS5.25/10, HGUS5.25/12, HGUS5.5/8, HGUS5.5/10, HGUS5.5/12, HGUS5.5/14, HGUS7.25/8, HGUS7.25/10, HGUS7.25/12, HGUS7.25/14.
                            • Allowed the use of a period "." in custom beam hanger library names.
                            http://design.medeek.com/resources/wallplugin/images7/wall_su776_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.6.5 - 06.12.2024
                              • Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS5.62/10, HGUS5.62/12, HGUS5.62/14, HGUS6.88/10, HGUS6.88/12, HGUS6.88/14, HGUS7.37/10, HGUS7.37/12, HGUS7.37/14, HGUS26, HGUS26-2, HGUS26-3, HGUS26-4, HGUS28, HGUS28-2, HGUS28-3, HGUS28-4, HGUS210, HGUS210-2, HGUS210-3, HGUS210-4, HGUS212-3, HGUS212-4, HGUS214-3, HGUS214-4, HGUS5.25/10, HGUS46, HGUS48, HGUS410, HGUS412.
                              design.medeek.com
                              medeekM 1 Reply Last reply Reply Quote 1
                              • medeekM Offline
                                medeek @medeek
                                Tutorial 49 - Component Libraries (13:05 min.)
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 3.6.6 - 06.24.2024
                                  • Added hardware (caps and bases) options to the post module.
                                  • Updated the material/color parameter for (exterior) wall trim to include custom materials.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Tutorial 50 - Post Hardware (8:45 min.)
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 3.6.6b - 06.24.2024 thru 06.25.2024
                                      • Fixed a minor bug with the post cap positioning algorithm.
                                      • Added the following Simpson post cap: APL6
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 3.6.7 - 06.27.2024
                                        • Updated the post module to include multi-part installations for Simpson heavy angles (post cap).
                                        • Added the following Simpson heavy angles to the post module: HL33, HL35, HL35G, HL37, HL37G, HL43, HL46, HL46G, HL49, HL49G, HL53,HL55, HL55G, HL57, HL57G, HL73, HL76, HL76G, HL79, HL79G
                                        404 - File or directory not found.
                                        (design.medeek.com)
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 3.6.8 - 06.28.2024
                                          • Added the following built-in ICF (block) materials: Nudura, Fox Blocks.
                                          • Added the following Simpson column bases to the post module: CPT44Z, CPT66Z, CPT88Z
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 3.6.9 - 07.23.2024
                                            • Enabled "Remove Cladding Lines" for 3D cladding materials.
                                            design.medeek.com
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 76
                                            • 77
                                            • 69 / 77
