    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 3.5.6 - 03.21.2024
      • Added built-in "Taped" and "Green Taped" gypsum materials for all wall types.
      • Updated and added additional tool tips within the Global Settings.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      gullfoG 1 Reply Last reply
      • gullfoG
        gullfo @medeek
        is that a level 4 or level 5 finish? πŸ˜‰
        Glenn
        http://www.runnel.com
        • medeekM
          medeek
          Version 3.5.7 - 04.17.2024
          • Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
          design.medeek.com
          • medeekM
            medeek
            Version 3.5.8 - 04.25.2024
            • Fixed a bug with cripple studs over windows and doors.
            • Fixed a bug with the copy wall tool.
            alt text
            design.medeek.com
            • medeekM
              medeek
              [b]Version 3.5.9[/b] - 05.01.2024
              • Added a rainscreen option for gable walls (vertical, horizontal, 45 and 135 degree).
              • Added a rainscreen option for shed walls (vertical, horizontal, 45 and 135 degree).
              • Added a rainscreen option for hip walls (vertical, horizontal, 45 and 135 degree).
              • Updated the license verification system with a more secure and improved algorithm.
              404 - File or directory not found.
              (design.medeek.com)
              (design.medeek.com)
              (design.medeek.com)
              design.medeek.com
              • medeekM
                medeek
                [b]Version 3.6.0[/b] - 05.04.2024
                • Added the ability to create custom "Vertical Shiplap" wall cladding materials within the Material Library.
                • Enabled "3D" Vertical Shiplap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                • Added the ability to create custom Dutchlap" wall cladding materials within the Material Library.
                • Enabled "3D" Dutchlap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                alt text
                alt text
                This update per customer request.
                design.medeek.com
                • medeekM
                  medeek
                  alt text
                  alt text
                  design.medeek.com
                  • medeekM
                    medeek
                    The original 3D cladding tutorial showed the following four materials:
                    • Board and Batten
                    • Shiplap
                    • Log
                    • Lap
                    The three additional ones added since this video are:
                    • Metal
                    • Shiplap (Vertical)
                    • Dutchlap
                    There are now seven different types of 3D cladding materials one can configure within the Custom Material Library.
                    design.medeek.com
                    Reply Quote 2
                    • medeekM
                      medeek
                      Version 3.6.1 - 05.13.2024
                      Added Symbol 2 Layer specfically for 2D door swing symbols (Layer tab of the global settings).
                      http://design.medeek.com/resources/wallplugin/images7/wall_su763_800.jpg
                      design.medeek.com
                      • medeekM
                        medeek
                        I will be running a Memorial Day promotion beginning May 22th until Jun. 5th with 35% off of the regular mdkBIM bundle price (permanent license) using the coupon code MEMORIAL24.
                        This will reduce the bundle price from $280.00 USD to $182.00 USD. This promo code does not apply to any of the extensions purchased separately. As part of this promotion a permanent license for the electrical plugin will be included upon request at no additional cost. The offer ends on Jun. 5th and no rain checks will issued thereafter.
                        alt text
                        design.medeek.com
                        design.medeek.com
                        • medeekM
                          medeek
                          Double sliders are kind of interesting windows.
                          [img]https://global.discourse-cdn.com/sketchup/original/3X/6/4/64053bedf882932aab501290cdb0080fb93e8c0e.gif[/img]
                          Sometimes I forget how cool it is to be able to create something like this in SketchUp and have it animate like it does. Can I say I love my job?
                          design.medeek.com
                          Reply Quote 2
                          • medeekM
                            medeek
                            Version 3.6.3 - 06.06.2024
                            • Enabled elevation swing/opening lines for doors and windows.
                            • Added elevation swing line annotation settings to the Door tab of the Global Settings.
                            • Added elevation swing line annotation settings to the Window tab of the Global Settings.
                            • Enabled opening and closing for all double hung type windows.
                            http://design.medeek.com/resources/wallplugin/images7/wall_su771_800.jpg
                            http://design.medeek.com/resources/wallplugin/images7/wall_su772_800.jpg
                            design.medeek.com
                            • medeekM
                              medeek
                              Tutorial 48 - Elevation Swing Lines (8:31 min.)
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 3.6.4 - 06.08.2024
                                • Added the following additional Wide Flange (W) beams to the beam module: W10X49, W10X54, W10X60, W10X68, W10X77, W10X88, W10X100, W10X112, W12X45, W12X50, W12X53, W12X58, W12X65, W12X72, W12X79, W12X87, W12X96, W12X106, W12X120, W12X136, W12X152, W12X170, W12X190, W30X90, W30X99, W30X108.
                                • Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS2.75/10, HGUS2.75/12, HGUS2.75/14, HGUS3.25/10, HGUS3.25/12, HGUS412, HGUS5.25/10, HGUS5.25/12, HGUS5.5/8, HGUS5.5/10, HGUS5.5/12, HGUS5.5/14, HGUS7.25/8, HGUS7.25/10, HGUS7.25/12, HGUS7.25/14.
                                • Allowed the use of a period "." in custom beam hanger library names.
                                http://design.medeek.com/resources/wallplugin/images7/wall_su776_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 3.6.5 - 06.12.2024
                                  • Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS5.62/10, HGUS5.62/12, HGUS5.62/14, HGUS6.88/10, HGUS6.88/12, HGUS6.88/14, HGUS7.37/10, HGUS7.37/12, HGUS7.37/14, HGUS26, HGUS26-2, HGUS26-3, HGUS26-4, HGUS28, HGUS28-2, HGUS28-3, HGUS28-4, HGUS210, HGUS210-2, HGUS210-3, HGUS210-4, HGUS212-3, HGUS212-4, HGUS214-3, HGUS214-4, HGUS5.25/10, HGUS46, HGUS48, HGUS410, HGUS412.
                                  design.medeek.com
                                  medeekM 1 Reply Last reply
                                  • medeekM
                                    medeek @medeek
                                    Tutorial 49 - Component Libraries (13:05 min.)
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 3.6.6 - 06.24.2024
                                      • Added hardware (caps and bases) options to the post module.
                                      • Updated the material/color parameter for (exterior) wall trim to include custom materials.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Tutorial 50 - Post Hardware (8:45 min.)
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 3.6.6b - 06.24.2024 thru 06.25.2024
                                          • Fixed a minor bug with the post cap positioning algorithm.
                                          • Added the following Simpson post cap: APL6
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.6.7 - 06.27.2024
                                            • Updated the post module to include multi-part installations for Simpson heavy angles (post cap).
                                            • Added the following Simpson heavy angles to the post module: HL33, HL35, HL35G, HL37, HL37G, HL43, HL46, HL46G, HL49, HL49G, HL53,HL55, HL55G, HL57, HL57G, HL73, HL76, HL76G, HL79, HL79G
                                            (design.medeek.com)
                                            design.medeek.com
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 80
                                            • 81
                                            • 69 / 81
