    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek @medeek
      Tutorial 49 - Component Libraries (13:05 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 3.6.6 - 06.24.2024
        • Added hardware (caps and bases) options to the post module.
        • Updated the material/color parameter for (exterior) wall trim to include custom materials.
        design.medeek.com
        • medeekM
          medeek
          Tutorial 50 - Post Hardware (8:45 min.)
          design.medeek.com
          • medeekM
            medeek
            Version 3.6.6b - 06.24.2024 thru 06.25.2024
            • Fixed a minor bug with the post cap positioning algorithm.
            • Added the following Simpson post cap: APL6
            design.medeek.com
            • medeekM
              medeek
              Version 3.6.7 - 06.27.2024
              • Updated the post module to include multi-part installations for Simpson heavy angles (post cap).
              • Added the following Simpson heavy angles to the post module: HL33, HL35, HL35G, HL37, HL37G, HL43, HL46, HL46G, HL49, HL49G, HL53,HL55, HL55G, HL57, HL57G, HL73, HL76, HL76G, HL79, HL79G
              404 - File or directory not found.
              (design.medeek.com)
              design.medeek.com
              • medeekM
                medeek
                Version 3.6.8 - 06.28.2024
                • Added the following built-in ICF (block) materials: Nudura, Fox Blocks.
                • Added the following Simpson column bases to the post module: CPT44Z, CPT66Z, CPT88Z
                design.medeek.com
                • medeekM
                  medeek
                  Version 3.6.9 - 07.23.2024
                  • Enabled "Remove Cladding Lines" for 3D cladding materials.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 3.7.0 - 07.25.2024
                    • Added a duplicate wall check to the regen module for all wall types.
                    Tutorial 51 - Duplicating Walls (6:15 min.)
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 3.7.1 - 09.17.2024
                      • Added a vertical offset parameter for in-wall column king studs.
                      In the case where you have a beam pocket and king studs over top of a door or window this update is critical. Previously the king studs would simply project to the bottom plate in the wall passing through the opening. Now you can utilize this extra parameter to vertically offset these king studs the same way the column itself is offset. Note that the offset can be both positive or negative or zero (default)
                      design.medeek.com
                      gullfoG 1 Reply Last reply
                      • gullfoG
                        gullfo @medeek
                        honestly though, if i was putting in a beam support over the opening, i've have either an additional jack stud under the header/lintel, or a X x X sized column on either side, and likely as well as a glulam etc type header/lintel. unless the beam was only supporting some deadweight and not a live area above. just me probably...
                        Glenn
                        http://www.runnel.com
                        • medeekM
                          medeek
                          I wasn't paying attention to a realistic header with trimmers, just focusing on the king stud offset, I agree, a few things would need to be beefed up to handle this type of beam configuration. I've only actually engineered one job with this type of beam over window(s).
                          design.medeek.com
                          • gullfoG
                            gullfo @medeek
                            i don't have to do it often but a couple of recent projects have beams over doors to address the extended span of a room with the door the best option - in those cases we used steel i-beams as posts and header as well as the new beam in order to get the load supported needed with lower profile than wood products. so it's rarely needed but a useful option when you can get around to it. maybe even just leaving the space so manually someone could insert the members / assemblies would work.
                            Glenn
                            medeekM 1 Reply Last reply
                            • medeekM
                              medeek @gullfo
                              @gullfo
                              Post a screenshot or send me some via email (nathan@medeek.com) so I can get a better idea what this looks like. I will give it some consideration.
                              design.medeek.com
                              • gullfoG
                                gullfo @medeek
                                @medeek I'm away until Thurs I'll send some then
                                Glenn
                                • medeekM
                                  medeek
                                  design.medeek.com
                                  • gullfoG
                                    gullfo
                                    wall structure using additional support for beam over door or window.![example steel framing for beam over door. you would adda stud on each edge of the steel column to support the top plates. but this is the idea. today when this arises, i just manually remove the members and add the needed assemblies.
                                    Glenn
                                    • medeekM
                                      medeek
                                      Very interesting. Let me see what I can do.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 3.7.2 - 10.13.2024
                                        • Fixed a critical bug with the in-wall column module.
                                        • Added the following additional Wide Flange (W14) beams to the beam module: W14X38, W14X43, W14X48, W14X53, W14X61, W14X68, W14X74, W14X82, W14X90, W14X99
                                        • Added the following additional Wide Flange (W16) beams to the beam module: W16X45, W16X50, W16X57, W16X67, W16X77, W16X89, W16X100
                                        • Enabled a wood grain and an end grain material for glulam beams within the beam module.
                                        • Enable additional built-in materials for "Custom" in-wall columns.
                                        • Added the following (27 - low poly) Simpson column bases to the post module: CB7_6, CB1212, CB1012, CB1010, CB812, CB810, CB718_7, CB718_6, CB718_4, CB612, CB610, CB88, CB86, CB68, CB64, CB48, CB46, CB9_105, CB9_75, CB9_9, CB9_6, CB7_105, CB7_75, CB7_9, CB6_7, CB5_45, CB5_6
                                        • Added the following (6 - low poly) Simpson column caps to the post module: CCQ84, CCQ86, CCQ94, CCQ96, CCQ98, CCQ106
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 3.7.2b - 10.14.2024
                                          • Added in the remainder of the commonly available wide flange beams (W4 thru W44).
                                          I think it comes to just a little over 250 different W flange beam profiles. However I'm sure there are some profiles I am missing or that are not as standard, if so let me know and I will add them in.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.7.3 - 10.14.2024
                                            • Added a duplicate post check to the regen module for post assemblies.
                                            • Added a duplicate beam check to the regen module for beam assemblies.
                                            • Added a duplicate stair check to the regen module for stair assemblies.
                                            • Added in the remainder of the commonly available wide flange beams (W4 thru W44) to the post module.
                                            design.medeek.com
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 80
                                            • 81
                                            • 69 / 81
