    Fredo6 extensions (none of them) not loading SU 2024
    24 Posts 5 Posters 1.4k Views 5 Watching
    • fredo6F Offline
      fredo6 @pipinek
      @pipinek
      It would be good to have the list of files and folders in your Plugins folder.
      Also, you said that it has happened 'suddenly'. Did you remember if you did something just before?
        pipinek @fredo6
        @fredo6
        Greetings,
        Unfortunately, I cannot pinpoint any key moment when the Fredo6 extension stopped loading.
        On a couple of occasions when I opened the SU for no (usual) reason, a list of extensions appeared on the screen which should have been unblocked by Sketchucation Tools.
        I simply closed the toolbars that appeared.
        And then at one point Fred6 just didn't appear on the screen, didn't load.
        Is this about the list of files and folders in the SU 2024 Plugins folder?
        Thanks for taking a look.
        fredo6F 1 Reply Last reply Reply Quote 0
        • fredo6F Offline
          fredo6 @pipinek
          @pipinek said in Fredo6 extensions (none of them) not loading SU 2024:
          Yes. Do you have a list or a screenshot?
            TIG Moderator @pipinek
            @pipinek
            Have you any ideas how your installed extensions ended up in that 'gems' folder subfolder ?
            Can you open your SketchUcation's ExtensionStore³ dialog and click Setting, then Paths and report the path that's chosen.
            If it's not your default Plugins folder something is adrift !
            It really doesn't need to be this complicated...
              pipinek @fredo6
              @fredo6
              Here they are:
              P_01.png P_02.png P_03.png P_04.png P_05.png P_06.png P_07.png P_08.png P_09.png P_10.png
              • fredo6F Offline
                fredo6 @pipinek
                @pipinek
                The files and folders seems to be present.
                So, there is something messing up the load of plugins.
                I have never seen this message:
                Fredo6_!LibFredo6.rb can not be loaded because an extension loader file with the same name was previously loaded.
                What is exactly the role of this gem of the Sketchup Extension Manager?
                Could it be that some pieces of my extensions are also present in another directory?. Can you check what you see in:
                • C:/ProgramData/SketchUp/SketchUp 2024/SketchUp/Plugins
                • C:/Program Files/SketchUp/SketchUp 2024/Tools
                With all the plugins you have, it's going difficult to troubleshoot the loading of extensions.
                P TIGT 2 Replies Last reply Reply Quote 0
                  pipinek @fredo6
                  @fredo6
                  I attach the contents of the two folders mentioned.
                  The third folder contained a whole series of Fredo6 files and folders created there after the installation of extensions via Sketchucation Tools.
                  When installing the Fredo6 extensions Sketchucation Tools did not create any folder or file in the SU 2024 Plugins folder.
                  Only in the lib folder.
                  When I removed them all from the lib folder and copied the files and folders from the Fredo6 backap to SU 2024 Plugin all Fredo6 extensions appeared loaded.
                  PS
                  I have no idea what role the gem folder plays. Apparently not the best.![alt text](1.png 2.png 3.png image url)
                  • fredo6F Offline
                    fredo6 @pipinek
                    @pipinek
                    What is the path of this 'third folder'.
                      TIG Moderator @fredo6
                      @fredo6
                      I agree with Fredo.
                      If you have somethings loading that then interfere with Fredo's extensions/lib, then it suggests they are loading earlier than the Plugins folder's RB files...
                      So somethings have either been put into Tools, or Tools../gems./... or maybe ../ProgramData/.../Plugins
                      Please check these locations...
                      Your posts cross with mine...
                      Your ProgramData Plugins seems OK, though I don't see why some extensions other than vfs are in there.
                      The Tools folder looks OK.
                      The Tools... gems...lib folder should only contain the rexml stuff, why the Helix stuff is there is a mystery...
                      What is this 'third-folder' ??
                        pipinek @fredo6
                        @fredo6
                        C:\Program Files\SketchUp\SketchUp 2024\Tools\gems\3.2.0\gems\rexml-3.2.5\lib
                        The very same plugins I have installed in SU 2023 on the same machine/laptop without any issues.
                        Two mentioned by Fredo6 folders:
                        Third one as on the first line here.
                        • F Offline
                          FlawinneF
                          Hello,
                          I think I have already encountered this problem, when you have plugins in ProgramData in the plugin Sketucation presents a repository destination list for the plugin installation and I mistakenly messed it up in ProgramData, but by default it is has no write rights in, which causes an error loading the plugin which wants to write in its directory, I uninstalled the plugin which was causing the problem and reinstalled the plugin in the repository which is in directory roaming and the plugin worked correctly.
                          For the one with the name 3Dx.SketchUp, I think it's for 3d space mice, it doesn't seem like an error to me that it's there, since it's more linked to system (Machine) than user
                            @pipinek
                            I think Gábor and I have devised a 'trap' to avoid this happening again.
                            The potential paths are already 'culled' to just a few possibilities.
                            Things like Tools and Gems etc are omitted Ruby side.
                            Your ../gems/.../lib one slipped through, as it didn't end in ../gems
                            We are also forcing the default path more robustly, as yours sneaked into the top of the list.
                            When Gábor has tweaked the js side listing we'll report back...
                            I still don't know where your ../gems/.../lib folder came to be in your $LOAD_PATH in the first place...
                            Is it added by some other extension ?
                              Gábor
                              We have implemented the changes TIG described in his previous post.
                              I'd like to ask those who had problems with their plugins being installed to the wrong folders to restart their SketchUcation Tools Extension Store and check the Settings / Path tab to see if the faulty folders are now excluded from the list of possible install folders.
                              The Extension store on restart might throw an error about the default installation folder not existing. After the error message please go to the Settings / Path tab and make sure the correct installation folder is selected there.
                              P 1 Reply Last reply Reply Quote 1
                                pipinek @Gábor
                                @Gábor
                                Thank you
