    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    446 Posts 109 Posters 456.0k Views 109 Watching
    • PixeroP Offline
      Pixero
      About adding support for quads.
      Couldn't you ask Thomthom if he would be willing to share the code he uses in his Quadface tools?
      • samuel_tS Offline
        samuel_t
        I think it's not possible because import feature is based on external programs not written in Ruby.
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          @panixia said:
          @einstein said:
          Then we wouldn't probably need Transmutr, which is an expensive tool.
          I don't know how expensive this tool is, but as far as I saw, this doesn't supports quads from other modeling pakages.
          If it does, I would pay for it no problem at all. Now. The "shut up and take my moneys!" style.
          It is planned for a future Transmutr version ๐Ÿ˜‰
          It's a bit tricky to do, but I believe it's possible.
          I don't have an ETA, though. For now we are focused on Skatter v2.
            pinoy
            Thank you so much!
            • panixiaP Offline
              panixia
              That would be really valuable for me, I'm more on the VR/game engine side of the fence right now, so no need for scatters/proxyes, but good topology is on top of the needs. ๐Ÿ˜„
              • 8 Offline
                8 perf1
                This seems like a fantastic plugin!
                I too am having issues with 1.1.5 on Mac OS 10.12.6. with Sketchup 2017 Make.
                A poster back on page 6 had the same issue I am having. I dont know if I can post images here or not as I dont frequent the site enough. His earlier post had this...
                https://sketchucation.com/forums/viewtopic.php?f=323&t=71951&start=120#p656540
                Im getting the same and was wondering if its an OS issue. I downloaded the most recent version of ASSIMP thinking I might need that. Do I? Couldn't figure out how to install it anyway. ๐Ÿ˜„
                Would love to get this sorted to be able to play around with this and put it through its paces. Thanks for any insight.
                • samuel_tS Offline
                  samuel_t
                  Unfortunately, I think plugin is not compatible with macOS 10.12.x, you need macOS 10.13 or greater.
                  • 8 Offline
                    8 perf1
                    Thanks samuel. Maybe after a long needed upgrade Ill try it again.
                      colorfulman
                      Hi sir:
                      Thank you so much for you write this power plugin.
                      When I use Universal Importer import any .stp file,Showned below erro,Can you help me?
                      you can try import any .stp file to test this bug,This website is not allow me upload .stp file
                      SketchUp 2019
                      Universal Importer Error: Command failed: "C:/Users/Colorfulman/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universal_importer/Assimp/Win/assimp.exe" info "C:\ProgramData/Universal Importer/tmp/import.stp" > "C:\ProgramData/Universal Importer/tmp/assimp.nfo"
                      Launching asset import ... OK
                      Validating postprocessing flags ... OK
                      ERROR: Failed to load file: Validation failed: A node of the scenegraph is NULL
                      assimp info: Unable to load input file C:\ProgramData/Universal Importer/tmp/import.stp
                      C:/Users/Colorfulman/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universal_importer/assimp.rb:166:in `get_texture_refs'
                      Universal Importer Version: 1.1.5
                      ็กฎๅฎš
                        treddigaetano
                        hi, can to import also mtl texture file of .obj ?
                        • samuel_tS Offline
                          samuel_t
                          @colorfulman said:
                          Hi sir:
                          SketchUp 2019
                          ็กฎๅฎš
                          Thank you for your report. Unfortunately I can't fix that issue. ๐Ÿ˜•
                          • samuel_tS Offline
                            samuel_t
                            Hi, don't worry: MTL texture file of OBJ is automatically loaded. ๐Ÿ˜‰
                              kd8qlo
                              Hello!
                              I keep getting this same error?
                              any ideas?
                              • samuel_tS Offline
                                samuel_t
                                @kd8qlo said:
                                https://sketchucation.com/forums/download/file.php?id=158823
                                Hello!
                                any ideas?
                                Hello! Reinstall Microsoft Visual C++ runtime then try to import a model with Universal Importer...
                                  christopheforet
                                  Hi all!
                                  I get errors when importing different file types...
                                  On Mac OS, Sketchup 2017, plugin v1.1.5.
                                  Any ideas on how to fix this?
                                    On Mac OS
                                    What version of Mac OS? As Samuel indicated a few posts up, "...plugin is not compatible with macOS 10.12.x, you need macOS 10.13 or greater."
                                    • I Offline
                                      ibex
                                      Thanks for providing this plugin.
                                      I have installed it on Sketchup 2017 and also reinstalled the Windows C+ library. The plugin appears in my options and the toolbar is in place.
                                      Each time I run it I get this error message trying to install an .stp file which I downloaded from here https://www.linak.com/products/linear-actuators/la22/#/2d3d
                                      • samuel_tS Offline
                                        samuel_t
                                          lema
                                          Textures are not imported correctly.
                                          The leaf is imported upside down.
                                          This can be understood if you open the model in other applications.
                                          https://drive.google.com/file/d/1-aTDHwlIvZhZY7RVeTcOy5WcILBdpfy1/view?usp=sharing
                                          • samuel_tS Offline
                                            samuel_t
                                            @lema said:
                                            Hi, thank you for your report. Unfortunately I can't fix that issue. ๐Ÿ˜•
                                            • 11
                                            • 12
                                            • 22
                                            • 23
                                            • 10 / 23
