    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    471 Posts 89 Posters 341.0k Views 88 Watching
      menmsis
      @dave r said:
      @menmsis said:
      I only have a problem...
      What version of SketchUp are you using? That may have an impact. Please complete your profile.
      Hi Dave.
      I am using 2022.
      I already update my profile
      • fredo6F Offline
        I think this is an issue with one extension which uses diacritic characters in the menu item label.
        Maybe Universal Importer by samuel_t, or one of his other plugins.
        Best is to check in the submenu of the Extensions menu.
          menmsis
          Fredo, thank you for your help and all your wonderful plugins.
          I unistall the universal importer and all worked fine.
          Best Regards.
          • alexpacio2013A Offline
            alexpacio2013
            Hi I have updated the LortdOfTheToolbars Plugins and from that moment every time I open Sketchup and my menu bars do not go out. To do this I have to launch Master toolbar Manager and they automatically open What can I do?
              @alexpacio2013 said:
              Hi I have updated the LortdOfTheToolbars Plugins...
              What version of SketchUp are you using? Your profile says "pre-2013". Is that correct?
                rv1974
                @Dave you should make "What version of SketchUp are you using?" your signature πŸ˜„
                Could it be written in CNC landuage?
                  alexpacio2013
                  After the update of LordOfTheToolbars - v2.2a - 28 Jun 22, now every time I open Sketchup, the menu bars of LordOfTheToolbars are not opened. However, if I open Master Toolbars Manager, the toolbars magically open, see image. What happened?
                  1659777819.050634;top_libfredo6.rbe:171: in `open'
                  DATE / TIME: 2022-08-06 11:23:39 +0200
                  SKETCHUP VERSION: 22.0.354
                  RUBY_PLATFORM: x64-mswin64_140
                  LOG FILE: LibFredo6Trace_22_1659777819048.txt
                  1659777819.0502865;top_libfredo6.rbe:171: in `open'
                  LibFredo6: Starting up Fredo6_!LibFredo6.rb
                  1659777819.0514805;top_libfredo6.rbe:171: in `open'
                  LibFredo6 Root top directory: C:/Users/robo/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins
                  1659777819.0598936;top_libfredo6.rbe:171: in `open'
                  APPDATA Sketchup directory: C:/Users/robo/AppData/Local
                  1659777819.0603428;top_libfredo6.rbe:171: in `open'
                  Temp Files directory: C:/Users/robo/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles
                  1659777819.062464;top_libfredo6.rbe:171: in `open'
                  LibFredo6 Data directory folder: C:/Users/robo/AppData/Local/LIBFREDO6_DATA_Dir
                  1659777819.0628412;top_libfredo6.rbe:171: in `open'
                  Default Parameters folder: C:/Users/robo/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters
                  1659777819.063465;top_libfredo6.rbe:171: in `open'
                  LibFredo6: Beginning of loading Cycle***+
                  1659777819.0766423;top_libfredo6.rbe:171: in `open'
                  LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core successfully loaded
                  1659777819.106217;top_libfredo6.rbe:171: in `open'
                  LibFredo6 12.9a: Effective Load - #0
                  1659777819.297847;top_libfredo6.rbe:171: in `open'
                  LibFredo6 12.9a: Ruby files loaded [189 ms]
                  1659777819.3327165;top_libfredo6.rbe:171: in `open'
                  add Command Seleziona Lingua preferita...
                  1659777819.333846;top_libfredo6.rbe:171: in `open'
                  add Command Controlla aggiornamenti Plugins...
                  1659777819.3347752;top_libfredo6.rbe:171: in `open'
                  add Command Purge Obsolete files...
                  1659777819.3356633;top_libfredo6.rbe:171: in `open'
                  add Command Performances...
                  1659777819.3365421;top_libfredo6.rbe:171: in `open'
                  add Command View Trace log files...
                  1659777819.3375835;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni LibFredo6 v12.9a...
                  1659777819.3420873;top_libfredo6.rbe:171: in `open'
                  add Command Informazione Plugin [Sketchucation]...
                  1659777819.3435683;top_libfredo6.rbe:171: in `open'
                  add Command Modifica parametri di Default...
                  1659777819.3444655;top_libfredo6.rbe:171: in `open'
                  add Command Traduzione Lingue...
                  1659777819.345387;top_libfredo6.rbe:171: in `open'
                  LibFredo6 12.9a: Startup (creating menus and icons) [46 ms]
                  1659777819.35002;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: LordOfTheToolbars
                  1659777819.3885655;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: Animator
                  1659777819.3910367;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: Curviloft
                  1659777819.3933218;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: Curvizard
                  1659777819.3955631;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: FredoCorner
                  1659777819.3977685;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: FredoGuides
                  1659777819.4000278;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: FredoScale
                  1659777819.402219;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: FredoSpline
                  1659777819.404525;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: FredoTools
                  1659777819.4067292;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: HoverSelect
                  1659777819.4090075;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: JointPushPull
                  1659777819.4111617;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: MoveAlignMe
                  1659777819.4133294;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: MrHide
                  1659777819.415562;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: ToolsOnSurface
                  1659777819.4176936;top_libfredo6.rbe:171: in `open'
                  Found valid plugin: VisuHole
                  1659777819.6108224;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [0]: ["LordOfTheToolbars", "!!Fredo6_LordOfTheToolbars"]
                  1659777819.61143;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [1]: ["Animator", "Fredo6_Animator"]
                  1659777819.6119018;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [2]: ["Curviloft", "Fredo6_Curviloft"]
                  1659777819.6123133;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [3]: ["Curvizard", "Fredo6_Curvizard"]
                  1659777819.6127267;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [4]: ["FredoCorner", "Fredo6_FredoCorner"]
                  1659777819.6131077;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [5]: ["FredoGuides", "Fredo6_FredoGuides"]
                  1659777819.613492;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [6]: ["FredoScale", "Fredo6_FredoScale"]
                  1659777819.6138604;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [7]: ["FredoSpline", "Fredo6_FredoSpline"]
                  1659777819.6142204;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [8]: ["FredoTools", "Fredo6_FredoTools"]
                  1659777819.6145978;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [9]: ["HoverSelect", "Fredo6_HoverSelect"]
                  1659777819.6149728;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [10]: ["JointPushPull", "Fredo6_JointPushPull"]
                  1659777819.6153467;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [11]: ["MoveAlignMe", "Fredo6_MoveAlignMe"]
                  1659777819.6157293;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [12]: ["MrHide", "Fredo6_MrHide"]
                  1659777819.6160994;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [13]: ["ToolsOnSurface", "Fredo6_ToolsOnSurface"]
                  1659777819.6164649;top_libfredo6.rbe:171: in `open'
                  Plugin to Load [14]: ["VisuHole", "Fredo6_VisuHole"]
                  1659777819.8602266;top_libfredo6.rbe:171: in `open'
                  LordOfTheToolbars 2.2a: Effective Load - #1
                  1659777819.8711247;top_libfredo6.rbe:171: in `open'
                  LordOfTheToolbars: Seed file created
                  1659777819.87369;top_libfredo6.rbe:171: in `open'
                  LordOfTheToolbars: COPIED SEED C:/ProgramData/SketchUp/SketchUp 2022/SketchUp/Plugins/!LordOfTheToolbars_seed.rb exist = true
                  1659777819.874354;top_libfredo6.rbe:171: in `open'
                  LordOfTheToolbars 2.2a: Bootstrap Ruby files loaded [13 ms]
                  1659777819.8949528;top_libfredo6.rbe:171: in `open'
                  add Command Master Toolbar Manager
                  1659777819.897017;top_libfredo6.rbe:171: in `open'
                  add Command Favorite Manager
                  1659777819.8990428;top_libfredo6.rbe:171: in `open'
                  add Command History Palette
                  1659777819.9010985;top_libfredo6.rbe:171: in `open'
                  add Command Navigate History
                  1659777819.9030466;top_libfredo6.rbe:171: in `open'
                  add Command Last command
                  1659777819.9049275;top_libfredo6.rbe:171: in `open'
                  add Command Toggle visibility of the Vignette stripe
                  1659777819.9073923;top_libfredo6.rbe:171: in `open'
                  add Command Reset the Vignette Stripe position
                  1659777819.909998;top_libfredo6.rbe:171: in `open'
                  add Command Pop up the Vignette Stripe
                  1659777819.912691;top_libfredo6.rbe:171: in `open'
                  add Command Cycle through Palettes
                  1659777819.9152055;top_libfredo6.rbe:171: in `open'
                  add Command Quick Command Finder
                  1659777819.9175193;top_libfredo6.rbe:171: in `open'
                  add Command Backup LOTT Config
                  1659777819.9199433;top_libfredo6.rbe:171: in `open'
                  add Command Import LOTT Config
                  1659777819.9222531;top_libfredo6.rbe:171: in `open'
                  add Command Export LOTT Config
                  1659777819.9246366;top_libfredo6.rbe:171: in `open'
                  add Command Reset All
                  1659777819.9270604;top_libfredo6.rbe:171: in `open'
                  add Command Reset History
                  1659777819.9294598;top_libfredo6.rbe:171: in `open'
                  add Command Toggle CleanScreen mode
                  1659777819.9318085;top_libfredo6.rbe:171: in `open'
                  add Command CleanScreen Configuration
                  1659777819.9341626;top_libfredo6.rbe:171: in `open'
                  add Command List of all shortuts
                  1659777819.9364662;top_libfredo6.rbe:171: in `open'
                  add Command Exclude VRay
                  1659777819.9388504;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni LordOfTheToolbars v2.2a...
                  1659777819.9445026;top_libfredo6.rbe:171: in `open'
                  1659777819.945423;top_libfredo6.rbe:171: in `open'
                  1659777819.9468265;top_libfredo6.rbe:171: in `open'
                  1659777819.9477277;top_libfredo6.rbe:171: in `open'
                  1659777819.9810462;top_libfredo6.rbe:171: in `open'
                  LordOfTheToolbars 2.2a: Startup (creating menus and icons) [106 ms]
                  1659777820.384493;top_libfredo6.rbe:171: in `open'
                  Animator 3.7a: Effective Load - #2
                  1659777820.3904972;top_libfredo6.rbe:171: in `open'
                  Animator 3.7a: Bootstrap Ruby files loaded [5 ms]
                  1659777820.3949382;top_libfredo6.rbe:171: in `open'
                  Lib6Theme: Loading body code from body_Lib6Theme [3 ms]
                  1659777820.4038517;top_libfredo6.rbe:171: in `open'
                  add Command Clip Editor
                  1659777820.405462;top_libfredo6.rbe:171: in `open'
                  add Command Clip Player
                  1659777820.4067729;top_libfredo6.rbe:171: in `open'
                  add Command Visit Controller
                  1659777820.4081466;top_libfredo6.rbe:171: in `open'
                  add Command Positioner
                  1659777820.4096053;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni Animator v3.7a...
                  1659777820.4207933;top_libfredo6.rbe:171: in `open'
                  1659777820.4217577;top_libfredo6.rbe:171: in `open'
                  1659777820.4231699;top_libfredo6.rbe:171: in `open'
                  1659777820.4240642;top_libfredo6.rbe:171: in `open'
                  1659777820.4625092;top_libfredo6.rbe:171: in `open'
                  Animator 3.7a: Startup (creating menus and icons) [71 ms]
                  1659777820.471187;top_libfredo6.rbe:171: in `open'
                  Curviloft 1.9a: Effective Load - #3
                  1659777820.4753973;top_libfredo6.rbe:171: in `open'
                  Curviloft 1.9a: Bootstrap Ruby files loaded [3 ms]
                  1659777820.4819002;top_libfredo6.rbe:171: in `open'
                  add Command Loft by Spline
                  1659777820.4835315;top_libfredo6.rbe:171: in `open'
                  add Command Loft along path
                  1659777820.4849508;top_libfredo6.rbe:171: in `open'
                  add Command Skin Contours
                  1659777820.486353;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni Curviloft v1.9a...
                  1659777820.487222;top_libfredo6.rbe:171: in `open'
                  add Command License...
                  1659777820.4880924;top_libfredo6.rbe:171: in `open'
                  add Command Trial Period Expiration...
                  1659777820.4938774;top_libfredo6.rbe:171: in `open'
                  1659777820.494852;top_libfredo6.rbe:171: in `open'
                  1659777820.4963236;top_libfredo6.rbe:171: in `open'
                  1659777820.4973097;top_libfredo6.rbe:171: in `open'
                  1659777820.5164933;top_libfredo6.rbe:171: in `open'
                  Curviloft 1.9a: Startup (creating menus and icons) [40 ms]
                  1659777820.5256727;top_libfredo6.rbe:171: in `open'
                  Curvizard 2.4b: Effective Load - #4
                  1659777820.5323317;top_libfredo6.rbe:171: in `open'
                  Curvizard 2.4b: Bootstrap Ruby files loaded [5 ms]
                  1659777820.541005;top_libfredo6.rbe:171: in `open'
                  add Command Quick Launcher...
                  1659777820.5426147;top_libfredo6.rbe:171: in `open'
                  add Command Make Curves (weld)
                  1659777820.5440307;top_libfredo6.rbe:171: in `open'
                  add Command Explode Curves
                  1659777820.545435;top_libfredo6.rbe:171: in `open'
                  add Command Cleanup Contours
                  1659777820.5468512;top_libfredo6.rbe:171: in `open'
                  add Command Simplify Contours
                  1659777820.5482337;top_libfredo6.rbe:171: in `open'
                  add Command Smooth Contours
                  1659777820.5496497;top_libfredo6.rbe:171: in `open'
                  add Command Edge Properties
                  1659777820.5510848;top_libfredo6.rbe:171: in `open'
                  add Command Convert Edges to Guides
                  1659777820.5525348;top_libfredo6.rbe:171: in `open'
                  add Command Convert to Arc / Circle
                  1659777820.553985;top_libfredo6.rbe:171: in `open'
                  add Command Convert to Polygon
                  1659777820.555427;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni Curvizard v2.4b...
                  1659777820.5563304;top_libfredo6.rbe:171: in `open'
                  1659777820.5576882;top_libfredo6.rbe:171: in `open'
                  1659777820.563914;top_libfredo6.rbe:171: in `open'
                  1659777820.5650506;top_libfredo6.rbe:171: in `open'
                  1659777820.5668058;top_libfredo6.rbe:171: in `open'
                  1659777820.5678856;top_libfredo6.rbe:171: in `open'
                  1659777820.6217778;top_libfredo6.rbe:171: in `open'
                  Curvizard 2.4b: Startup (creating menus and icons) [88 ms]
                  1659777820.6301749;top_libfredo6.rbe:171: in `open'
                  FredoCorner 2.5a: Effective Load - #5
                  1659777820.6354005;top_libfredo6.rbe:171: in `open'
                  FredoCorner 2.5a: Bootstrap Ruby files loaded [4 ms]
                  1659777820.6419108;top_libfredo6.rbe:171: in `open'
                  add Command Round
                  1659777820.6434898;top_libfredo6.rbe:171: in `open'
                  add Command Bevel
                  1659777820.6449006;top_libfredo6.rbe:171: in `open'
                  add Command SubDivision
                  1659777820.6463234;top_libfredo6.rbe:171: in `open'
                  add Command Chop Corner
                  1659777820.6476603;top_libfredo6.rbe:171: in `open'
                  add Command Repair
                  1659777820.64898;top_libfredo6.rbe:171: in `open'
                  add Command Purge all data
                  1659777820.6499054;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni Fredo Corner v2.5a...
                  1659777820.650826;top_libfredo6.rbe:171: in `open'
                  1659777820.6517062;top_libfredo6.rbe:171: in `open'
                  1659777820.6563776;top_libfredo6.rbe:171: in `open'
                  1659777820.6572852;top_libfredo6.rbe:171: in `open'
                  1659777820.6587155;top_libfredo6.rbe:171: in `open'
                  1659777820.6596198;top_libfredo6.rbe:171: in `open'
                  1659777820.6959202;top_libfredo6.rbe:171: in `open'
                  FredoCorner 2.5a: Startup (creating menus and icons) [60 ms]
                  1659777820.7102923;top_libfredo6.rbe:171: in `open'
                  FredoScale 3.5a: Effective Load - #6
                  1659777820.717813;top_libfredo6.rbe:171: in `open'
                  FredoScale 3.5a: Bootstrap Ruby files loaded [6 ms]
                  1659777820.7442555;top_libfredo6.rbe:171: in `open'
                  1659777820.7465575;top_libfredo6.rbe:171: in `open'
                  add Command Box Scalatura
                  1659777820.7489302;top_libfredo6.rbe:171: in `open'
                  add Command Box Scalatura verso Destinazione
                  1659777820.7512124;top_libfredo6.rbe:171: in `open'
                  add Command Box Inclinatura
                  1659777820.753441;top_libfredo6.rbe:171: in `open'
                  add Command Box Inclinatura verso Destinazione
                  1659777820.7556183;top_libfredo6.rbe:171: in `open'
                  add Command Box Shearing Planare
                  1659777820.757817;top_libfredo6.rbe:171: in `open'
                  add Command Box Shearing Planare verso Destinazione
                  1659777820.7599664;top_libfredo6.rbe:171: in `open'
                  add Command Shearing Planare (Libero)
                  1659777820.7621584;top_libfredo6.rbe:171: in `open'
                  add Command Box Stretching
                  1659777820.764318;top_libfredo6.rbe:171: in `open'
                  add Command Box Stretching verso Destinazione
                  1659777820.7677734;top_libfredo6.rbe:171: in `open'
                  add Command Box Twisting
                  1659777820.7698052;top_libfredo6.rbe:171: in `open'
                  add Command Box Rotazione
                  1659777820.7717674;top_libfredo6.rbe:171: in `open'
                  add Command Rotazione (Libero)
                  1659777820.7737472;top_libfredo6.rbe:171: in `open'
                  add Command Bending Radiale (Libero)
                  1659777820.7757032;top_libfredo6.rbe:171: in `open'
                  add Command Rendi Unico
                  1659777820.778194;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni FredoScale v3.5a...
                  1659777820.7792869;top_libfredo6.rbe:171: in `open'
                  1659777820.780257;top_libfredo6.rbe:171: in `open'
                  1659777820.7861962;top_libfredo6.rbe:171: in `open'
                  1659777820.7871573;top_libfredo6.rbe:171: in `open'
                  1659777820.788678;top_libfredo6.rbe:171: in `open'
                  1659777820.7896168;top_libfredo6.rbe:171: in `open'
                  1659777820.8383808;top_libfredo6.rbe:171: in `open'
                  FredoScale 3.5a: Startup (creating menus and icons) [120 ms]
                  1659777820.8477514;top_libfredo6.rbe:171: in `open'
                  FredoSpline 2.3a: Effective Load - #7
                  1659777820.8552005;top_libfredo6.rbe:171: in `open'
                  FredoSpline 2.3a: Bootstrap Ruby files loaded [6 ms]
                  1659777820.8683937;top_libfredo6.rbe:171: in `open'
                  1659777820.8703284;top_libfredo6.rbe:171: in `open'
                  add Command Create Curves
                  1659777820.8719673;top_libfredo6.rbe:171: in `open'
                  add Command Edit Curves
                  1659777820.8735292;top_libfredo6.rbe:171: in `open'
                  add Command Swap Curves
                  1659777820.875027;top_libfredo6.rbe:171: in `open'
                  add Command Convert Curves
                  1659777820.8765285;top_libfredo6.rbe:171: in `open'
                  add Command Purge data
                  1659777820.8779967;top_libfredo6.rbe:171: in `open'
                  add Command Purge All data
                  1659777820.8795464;top_libfredo6.rbe:171: in `open'
                  add Command Bezier Classic
                  1659777820.8810525;top_libfredo6.rbe:171: in `open'
                  add Command Bezier Nurbs
                  1659777820.882643;top_libfredo6.rbe:171: in `open'
                  add Command Local Fit Spline
                  1659777820.8841708;top_libfredo6.rbe:171: in `open'
                  add Command Global Fit Spline
                  1659777820.8857195;top_libfredo6.rbe:171: in `open'
                  add Command Polyline
                  1659777820.88723;top_libfredo6.rbe:171: in `open'
                  add Command Polyline Divider
                  1659777820.8888128;top_libfredo6.rbe:171: in `open'
                  add Command Polyline Segmentor
                  1659777820.8903725;top_libfredo6.rbe:171: in `open'
                  add Command Polycorner Generic
                  1659777820.8918214;top_libfredo6.rbe:171: in `open'
                  add Command Polycorner Arc
                  1659777820.8934803;top_libfredo6.rbe:171: in `open'
                  add Command Polycorner Squircle
                  1659777820.894999;top_libfredo6.rbe:171: in `open'
                  add Command Polycorner Bezier
                  1659777820.8965273;top_libfredo6.rbe:171: in `open'
                  add Command Polycorner Chamfer
                  1659777820.898061;top_libfredo6.rbe:171: in `open'
                  add Command Polycorner Dog-Bone
                  1659777820.8996205;top_libfredo6.rbe:171: in `open'
                  add Command Polycorner T-Bone
                  1659777820.9011447;top_libfredo6.rbe:171: in `open'
                  add Command Courbette
                  1659777820.9026604;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni FredoSpline v2.3a...
                  1659777820.9036179;top_libfredo6.rbe:171: in `open'
                  1659777820.9045167;top_libfredo6.rbe:171: in `open'
                  1659777820.908837;top_libfredo6.rbe:171: in `open'
                  1659777820.909901;top_libfredo6.rbe:171: in `open'
                  1659777820.9114738;top_libfredo6.rbe:171: in `open'
                  1659777820.9123995;top_libfredo6.rbe:171: in `open'
                  1659777820.9920552;top_libfredo6.rbe:171: in `open'
                  FredoSpline 2.3a: Startup (creating menus and icons) [136 ms]
                  1659777821.0018177;top_libfredo6.rbe:171: in `open'
                  FredoTools 4.3a: Effective Load - #8
                  1659777821.0720754;top_libfredo6.rbe:171: in `open'
                  FredoTools 4.3a: Ruby files loaded [68 ms]
                  1659777821.0804183;top_libfredo6.rbe:171: in `open'
                  Lib6Material: Loading body code from body_Lib6Material [4 ms]
                  1659777821.1087255;top_libfredo6.rbe:171: in `open'
                  add Command >> FredoTools Launcher...
                  1659777821.1106596;top_libfredo6.rbe:171: in `open'
                  add Command Angle Inspector
                  1659777821.1128163;top_libfredo6.rbe:171: in `open'
                  add Command AutoReverseFaces
                  1659777821.1148922;top_libfredo6.rbe:171: in `open'
                  add Command Color by Altitude
                  1659777821.1164553;top_libfredo6.rbe:171: in `open'
                  add Command Color by Slope
                  1659777821.1181555;top_libfredo6.rbe:171: in `open'
                  add Command Color Flat Mode
                  1659777821.119647;top_libfredo6.rbe:171: in `open'
                  add Command Color Paint
                  1659777821.1212366;top_libfredo6.rbe:171: in `open'
                  add Command Construct Face Normals
                  1659777821.1233282;top_libfredo6.rbe:171: in `open'
                  add Command Convexify
                  1659777821.1256363;top_libfredo6.rbe:171: in `open'
                  add Command Count Faces by Sides
                  1659777821.1277225;top_libfredo6.rbe:171: in `open'
                  add Command CurviShear
                  1659777821.12977;top_libfredo6.rbe:171: in `open'
                  add Command Divide Edges
                  1659777821.1318834;top_libfredo6.rbe:171: in `open'
                  add Command Draw Along
                  1659777821.1340015;top_libfredo6.rbe:171: in `open'
                  add Command Edge Inspector
                  1659777821.1360934;top_libfredo6.rbe:171: in `open'
                  add Command Element Stats
                  1659777821.138192;top_libfredo6.rbe:171: in `open'
                  add Command FaceTriangulator
                  1659777821.1404064;top_libfredo6.rbe:171: in `open'
                  add Command Mark Vertices
                  1659777821.1425476;top_libfredo6.rbe:171: in `open'
                  add Command Move Along
                  1659777821.1447155;top_libfredo6.rbe:171: in `open'
                  add Command Remove Lonely Vertices
                  1659777821.1468349;top_libfredo6.rbe:171: in `open'
                  add Command Report on Areas
                  1659777821.1483846;top_libfredo6.rbe:171: in `open'
                  add Command Label with Areas
                  1659777821.1504822;top_libfredo6.rbe:171: in `open'
                  add Command ReverseOrientFaces
                  1659777821.1522555;top_libfredo6.rbe:171: in `open'
                  add Command Revert Curves
                  1659777821.1544452;top_libfredo6.rbe:171: in `open'
                  add Command Solid Volume
                  1659777821.1567695;top_libfredo6.rbe:171: in `open'
                  add Command ThruPaint
                  1659777821.1585371;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni Fredo Tools v4.3a...
                  1659777821.1728668;top_libfredo6.rbe:171: in `open'
                  1659777821.1740627;top_libfredo6.rbe:171: in `open'
                  1659777821.1757603;top_libfredo6.rbe:171: in `open'
                  1659777821.1768177;top_libfredo6.rbe:171: in `open'
                  1659777821.263448;top_libfredo6.rbe:171: in `open'
                  FredoTools 4.3a: Startup (creating menus and icons) [190 ms]
                  1659777821.2722695;top_libfredo6.rbe:171: in `open'
                  HoverSelect 1.5a: Effective Load - #9
                  1659777821.2924924;top_libfredo6.rbe:171: in `open'
                  HoverSelect 1.5a: Ruby files loaded [18 ms]
                  1659777821.297239;top_libfredo6.rbe:171: in `open'
                  add Command Hover Select Edges
                  1659777821.2992785;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni HoverSelect v1.5a...
                  1659777821.3032396;top_libfredo6.rbe:171: in `open'
                  1659777821.3041375;top_libfredo6.rbe:171: in `open'
                  1659777821.3055997;top_libfredo6.rbe:171: in `open'
                  1659777821.3064806;top_libfredo6.rbe:171: in `open'
                  1659777821.3119593;top_libfredo6.rbe:171: in `open'
                  HoverSelect 1.5a: Startup (creating menus and icons) [18 ms]
                  1659777821.3206584;top_libfredo6.rbe:171: in `open'
                  JointPushPull 4.4e: Effective Load - #10
                  1659777821.3262935;top_libfredo6.rbe:171: in `open'
                  JointPushPull 4.4e: Bootstrap Ruby files loaded [4 ms]
                  1659777821.335673;top_libfredo6.rbe:171: in `open'
                  1659777821.3376372;top_libfredo6.rbe:171: in `open'
                  add Command Thickener
                  1659777821.3393734;top_libfredo6.rbe:171: in `open'
                  add Command Joint Push Pull
                  1659777821.341129;top_libfredo6.rbe:171: in `open'
                  add Command Round Push Pull
                  1659777821.342861;top_libfredo6.rbe:171: in `open'
                  add Command Vector Push Pull
                  1659777821.344577;top_libfredo6.rbe:171: in `open'
                  add Command Normal Push Pull
                  1659777821.3462873;top_libfredo6.rbe:171: in `open'
                  add Command Extrude Push Pull
                  1659777821.3480852;top_libfredo6.rbe:171: in `open'
                  add Command Follow Push Pull
                  1659777821.3498316;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni JointPushPull v4.4e...
                  1659777821.3507373;top_libfredo6.rbe:171: in `open'
                  1659777821.3516152;top_libfredo6.rbe:171: in `open'
                  1659777821.357344;top_libfredo6.rbe:171: in `open'
                  1659777821.3597226;top_libfredo6.rbe:171: in `open'
                  1659777821.3611848;top_libfredo6.rbe:171: in `open'
                  1659777821.362069;top_libfredo6.rbe:171: in `open'
                  1659777821.413224;top_libfredo6.rbe:171: in `open'
                  JointPushPull 4.4e: Startup (creating menus and icons) [86 ms]
                  1659777821.421949;top_libfredo6.rbe:171: in `open'
                  MoveAlignMe 1.2a: Effective Load - #11
                  1659777821.426346;top_libfredo6.rbe:171: in `open'
                  MoveAlignMe 1.2a: Bootstrap Ruby files loaded [3 ms]
                  1659777821.4303312;top_libfredo6.rbe:171: in `open'
                  add Command Move - Pivot - Straighten
                  1659777821.432269;top_libfredo6.rbe:171: in `open'
                  add Command Move and Glue
                  1659777821.4339776;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni MoveAlignMe v1.2a...
                  1659777821.4389012;top_libfredo6.rbe:171: in `open'
                  1659777821.439845;top_libfredo6.rbe:171: in `open'
                  1659777821.4413064;top_libfredo6.rbe:171: in `open'
                  1659777821.4421935;top_libfredo6.rbe:171: in `open'
                  1659777821.4644544;top_libfredo6.rbe:171: in `open'
                  MoveAlignMe 1.2a: Startup (creating menus and icons) [37 ms]
                  1659777821.4756064;top_libfredo6.rbe:171: in `open'
                  MrHide 1.6a: Effective Load - #12
                  1659777821.4834373;top_libfredo6.rbe:171: in `open'
                  MrHide 1.6a: Bootstrap Ruby files loaded [7 ms]
                  1659777821.4958718;top_libfredo6.rbe:171: in `open'
                  1659777821.4974673;top_libfredo6.rbe:171: in `open'
                  add Command View Hidden Geometry
                  1659777821.4989045;top_libfredo6.rbe:171: in `open'
                  add Command View Hidden Objects
                  1659777821.500291;top_libfredo6.rbe:171: in `open'
                  add Command Draw Back Edges
                  1659777821.501683;top_libfredo6.rbe:171: in `open'
                  add Command View Axes
                  1659777821.5035517;top_libfredo6.rbe:171: in `open'
                  add Command View Component Axes
                  1659777821.5050678;top_libfredo6.rbe:171: in `open'
                  add Command View Guides
                  1659777821.506527;top_libfredo6.rbe:171: in `open'
                  add Command View Dimensions
                  1659777821.5080168;top_libfredo6.rbe:171: in `open'
                  add Command View Text Labels
                  1659777821.5095255;top_libfredo6.rbe:171: in `open'
                  add Command Display Shadows
                  1659777821.5110574;top_libfredo6.rbe:171: in `open'
                  add Command Display Sun shading
                  1659777821.5125182;top_libfredo6.rbe:171: in `open'
                  add Command View Fog
                  1659777821.5139978;top_libfredo6.rbe:171: in `open'
                  add Command View Ground
                  1659777821.5154166;top_libfredo6.rbe:171: in `open'
                  add Command View Sky
                  1659777821.5169723;top_libfredo6.rbe:171: in `open'
                  add Command Color by Tag
                  1659777821.5185745;top_libfredo6.rbe:171: in `open'
                  add Command Edge Visibility
                  1659777821.5200028;top_libfredo6.rbe:171: in `open'
                  add Command Edge Profiles
                  1659777821.521416;top_libfredo6.rbe:171: in `open'
                  add Command Draw Endpoints
                  1659777821.522842;top_libfredo6.rbe:171: in `open'
                  add Command Edge Color By Material
                  1659777821.524244;top_libfredo6.rbe:171: in `open'
                  add Command Edge Color By Axis
                  1659777821.5256379;top_libfredo6.rbe:171: in `open'
                  add Command Hide similar instances
                  1659777821.5270412;top_libfredo6.rbe:171: in `open'
                  add Command Hide Rest of the model
                  1659777821.528457;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni MrHide v1.6a...
                  1659777821.5332236;top_libfredo6.rbe:171: in `open'
                  1659777821.5342171;top_libfredo6.rbe:171: in `open'
                  1659777821.5356562;top_libfredo6.rbe:171: in `open'
                  1659777821.5366085;top_libfredo6.rbe:171: in `open'
                  1659777821.652451;top_libfredo6.rbe:171: in `open'
                  MrHide 1.6a: Startup (creating menus and icons) [168 ms]
                  1659777821.6611593;top_libfredo6.rbe:171: in `open'
                  ToolsOnSurface 2.5a: Effective Load - #13
                  1659777821.6690829;top_libfredo6.rbe:171: in `open'
                  ToolsOnSurface 2.5a: Bootstrap Ruby files loaded [7 ms]
                  1659777821.6850967;top_libfredo6.rbe:171: in `open'
                  1659777821.687485;top_libfredo6.rbe:171: in `open'
                  add Command Generic Tools on Surface
                  1659777821.6888132;top_libfredo6.rbe:171: in `open'
                  add Command Line on Surface
                  1659777821.6902533;top_libfredo6.rbe:171: in `open'
                  add Command Rectangle
                  1659777821.6918726;top_libfredo6.rbe:171: in `open'
                  add Command Circle
                  1659777821.6935656;top_libfredo6.rbe:171: in `open'
                  add Command Polygon
                  1659777821.6957371;top_libfredo6.rbe:171: in `open'
                  add Command Ellipse
                  1659777821.6975596;top_libfredo6.rbe:171: in `open'
                  add Command Parallelogram
                  1659777821.6994553;top_libfredo6.rbe:171: in `open'
                  add Command Arc
                  1659777821.7012951;top_libfredo6.rbe:171: in `open'
                  add Command Circle (3 Points)
                  1659777821.7031078;top_libfredo6.rbe:171: in `open'
                  add Command Sector (Pie)
                  1659777821.7049463;top_libfredo6.rbe:171: in `open'
                  add Command Offset on Surface
                  1659777821.7067401;top_libfredo6.rbe:171: in `open'
                  add Command Free Hand on Surface
                  1659777821.7086666;top_libfredo6.rbe:171: in `open'
                  add Command Edit Contours on Surface
                  1659777821.7103713;top_libfredo6.rbe:171: in `open'
                  add Command Eraser on Surface
                  1659777821.7118523;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni Tools on Surface v2.5a...
                  1659777821.712737;top_libfredo6.rbe:171: in `open'
                  1659777821.7136042;top_libfredo6.rbe:171: in `open'
                  1659777821.7186472;top_libfredo6.rbe:171: in `open'
                  1659777821.7195928;top_libfredo6.rbe:171: in `open'
                  1659777821.721014;top_libfredo6.rbe:171: in `open'
                  1659777821.7218785;top_libfredo6.rbe:171: in `open'
                  1659777821.8156009;top_libfredo6.rbe:171: in `open'
                  ToolsOnSurface 2.5a: Startup (creating menus and icons) [146 ms]
                  1659777821.8244748;top_libfredo6.rbe:171: in `open'
                  VisuHole 1.4b: Effective Load - #14
                  1659777821.8285341;top_libfredo6.rbe:171: in `open'
                  VisuHole 1.4b: Bootstrap Ruby files loaded [3 ms]
                  1659777821.8331802;top_libfredo6.rbe:171: in `open'
                  add Command VisuHole: Stencil
                  1659777821.8352547;top_libfredo6.rbe:171: in `open'
                  add Command Informazioni VisuHole v1.4b...
                  1659777821.836168;top_libfredo6.rbe:171: in `open'
                  1659777821.8370469;top_libfredo6.rbe:171: in `open'
                  1659777821.8414953;top_libfredo6.rbe:171: in `open'
                  1659777821.8425024;top_libfredo6.rbe:171: in `open'
                  1659777821.8439815;top_libfredo6.rbe:171: in `open'
                  1659777821.8448694;top_libfredo6.rbe:171: in `open'
                  1659777821.856961;top_libfredo6.rbe:171: in `open'
                  VisuHole 1.4b: Startup (creating menus and icons) [27 ms]
                  1659777848.5419104;top_libfredo6.rbe:171: in `open'
                  LibFredo6: End of loading Cycle***-
                  1659777848.655718;top_libfredo6.rbe:171: in `open'
                  Lib6ColorSpecDialog: Loading body code from body_Lib6ColorSpecDialog [8 ms] status = true
                  1659777848.6649866;top_libfredo6.rbe:171: in `open'
                  Lib6Onglets: Loading body code from body_Lib6Onglets [8 ms] status = true
                  1659777848.666665;top_libfredo6.rbe:171: in `open'
                  Lib6ColorScale: Loading body code from body_Lib6ColorScale [29 ms] status = true
                  1659777848.7103868;top_libfredo6.rbe:171: in `open'
                  LordOfTheToolbars 2.2a: Ruby files loaded [165 ms]
                  1659777848.7280338;top_libfredo6.rbe:171: in `open'
                  Lib6_txtmsg: Loading body code from body_Lib6_txtmsg [16 ms] status = true
                  1659777848.7825856;top_libfredo6.rbe:171: in `open'
                  Lib6G6: Loading body code from body_Lib6G6 [53 ms] status = true
                  1659777848.7919383;top_libfredo6.rbe:171: in `open'
                  LibFredo6: Loaded Binary C:/Users/robo/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU22/bin_body_Lib6G6.so
                  1659777848.8168008;top_libfredo6.rbe:171: in `open'
                  Lib6Tool: Loading body code from body_Lib6Tool [16 ms] status = true
                  1659777848.8180127;top_libfredo6.rbe:171: in `open'
                  Lib6Translate: Loading body code from body_Lib6Translate [25 ms] status = true
                  1659777848.8472762;top_libfredo6.rbe:171: in `open'
                  Lib6RoundingProfiler: Loading body code from body_Lib6RoundingProfiler [15 ms] status = true
                  1659777848.8485556;top_libfredo6.rbe:171: in `open'
                  Lib6Spline: Loading body code from body_Lib6Spline [29 ms] status = true
                  1659777848.859474;top_libfredo6.rbe:171: in `open'
                  Lib6WebHtml: Loading body code from body_Lib6WebHtml [10 ms] status = true
                  1659777848.8691103;top_libfredo6.rbe:171: in `open'
                  Lib6Algo: Loading body code from body_Lib6Algo [8 ms] status = true
                  1659777848.8792436;top_libfredo6.rbe:171: in `open'
                  Lib6Contour: Loading body code from body_Lib6Contour [9 ms] status = true
                  1659777848.8860703;top_libfredo6.rbe:171: in `open'
                  Lib6Offset3d: Loading body code from body_Lib6Offset3d [5 ms] status = true
                  1659777848.8964381;top_libfredo6.rbe:171: in `open'
                  Lib6Transform: Loading body code from body_Lib6Transform [9 ms] status = true
                  1659777848.9045694;top_libfredo6.rbe:171: in `open'
                  Lib6Mark: Loading body code from body_Lib6Mark [7 ms] status = true
                  1659777848.9104576;top_libfredo6.rbe:171: in `open'
                  Lib6Vault: Loading body code from body_Lib6Vault [5 ms]
                  1659777848.916615;top_libfredo6.rbe:171: in `open'
                  Lib6Marshall: Loading body code from body_Lib6Marshall [5 ms]
                  1659777848.9322221;top_libfredo6.rbe:171: in `open'
                  Lib6CompManager: Loading body code from body_Lib6CompManager [15 ms]
                  1659777848.9460337;top_libfredo6.rbe:171: in `open'
                  Lib6PathManager: Loading body code from body_Lib6PathManager [13 ms]
                  1659777848.9552493;top_libfredo6.rbe:171: in `open'
                  Lib6Shortcuts: Loading body code from body_Lib6Shortcuts [7 ms]
                  1659777848.9626634;top_libfredo6.rbe:171: in `open'
                  Lib6MonoFactory: Loading body code from body_Lib6MonoFactory [6 ms]
                  1659777850.701963;top_libfredo6.rbe:171: in `open'
                  Lib6NativeManager: Loading body code from body_Lib6NativeManager [13 ms]
                  1659777916.0953088;top_libfredo6.rbe:171: in `open'
                  Lib6ChromiumJS: Loading body code from body_Lib6ChromiumJS [4 ms]
                  1659777916.1139123;top_libfredo6.rbe:171: in `open'
                  Lib6ChromiumWdlg: Loading body code from body_Lib6ChromiumWdlg [17 ms]
                  1659779297.9428368;top_libfredo6.rbe:171: in `open'
                  Lib6Variator: Loading body code from body_Lib6Variator [6 ms] status = true
                  1659779298.0459197;top_libfredo6.rbe:171: in `open'
                  FredoSpline 2.3a: Ruby files loaded [120 ms]
                  1659779348.9734035;top_libfredo6.rbe:171: in `open'
                  Lib6PluginDialogs: Loading body code from body_Lib6PluginDialogs [10 ms]
                  1659779348.9823189;top_libfredo6.rbe:171: in `open'
                  Lib6WebXTable: Loading body code from body_Lib6WebXTable [7 ms]
                  • fredo6F Offline
                    By chance, do you have Universal Importer installed or any other plugins by samuel_t?
                    If so, there is an incompatibility with LOTT, I am afraid, until Samuel updates his plugins.
                      alexpacio2013
                      Thanks, I solved it by uninstalling Universal Importer. Always punctual and precise. Without Fredo6 I would not be able to use Sketchup. 🀣
                      • samuel_tS Offline
                        samuel_t
                        Hello there, Universal Importer plugin v1.1.8 is compatible with Lord Of The Toolbars plugin v2.2a πŸ˜‰
                          lionk
                          Hello fredo. Found an issue. If I set a palette shortcut to c, for example, when some plugins need VCB input, once I type c, this palette will popup untimely.
                          • cmeedC Offline
                            cmeed
                            Hi Fredo,
                            I have whole heartly enbraced LOTT! It is exactly what I need to clean up my place of work!
                            The Vinette strip is incredibly fast as you hover over, which is exactly what it needs to be. I wonder possibly if there could a way of spacing out the icons / bigger area to hover over as when in the speed of the moment you can easily brush over the adjacent icon
                            Maybe a separator would work like the pallettes have
                            or
                            Bigger wider version of each icon? (I have small su icons enabled to save valuable space and i think that should still be on - what do you think?)
                            or
                            A Separate icon that act as a Vinette for each pallette you need and you can float or add to tool bar?
                            what do you think?
                            Cheers
                            and Thanks Again
                            • fredo6F Offline
                              You can click on the first 'dotted' button and choose menu (size of Vignettes). You can make them bigger or smaller.
                              • cmeedC Offline
                                cmeed
                                OOOOH!!
                                  AISmebel
                                  Hello fredo. I have broken icons of plugins and scripts for which I used my pictures. Can they be restored somehow? I don't know how it happened ((
                                  I do restore toolbars but does not help. All the pictures that I used are in place.
                                  • H Offline
                                    haymaker
                                    Hey Fredo.
                                    I just brought your bundle and made a donation for all the great work you do. Before I install it I thought I would re arrange some of my LOTT pallets first. I have been using LOTT for a while now and love it, however the new pallets I have created will not disappear after I pick a tool or click outside of the pallet, or even if I press escape.. I have to either double click on the top of the pallet or click the red X to get them to close. Some, but not all of my older pallets continue to work fine and they close by themselves once I have clicked the icon for the tool I want to use. I have scrolled through the 'Default parameters' window but cant see if I am missing something or is this a bug. I have saved settings and closed and restarted SU but that did not help,
                                    Any assistance you can offer would be greatly appreciated, I would like to resolve this issue before I install the bundle encase I have any other issues.
                                    Could this be an issue with libFredo6 as this is the most recent update?
                                    I have attached a screen shot, shortcuts A, B, D and X are the ones that are not working, A B and X are new, D is an old one that is also not working.
                                    SU2022
                                    LOTT v2.2a
                                    Libfredo6 13.2a Last updated on the 16 sep 22
                                    Windows 11
                                    Thanks for your help
                                    Mike
                                    Screenshot
                                    • fredo6F Offline
                                      @haymaker,
                                      Could you open the Ruby Console before trying to close a palette, in case there is an error message displayed.
                                      For shortcuts, I would suggest you do not select letters that are used by Sketchup native tools (such as A, B, D and X).
                                      • H Offline
                                        haymaker
                                        Hey Fredo
                                        I have changed a shortcut key to SHIFT H but problem persists.
                                        I opened the Ruby console and got no message when closing a pallet but I did get the attached message on start up of sketchup.
                                        It means nothing to me, hopefully you can understand it.
                                        Mike
                                        • H Offline
                                          haymaker
                                          I have cleaned out a few unused shortcut keys. There are now just 5 shortcuts for LOTT, and I noticed that the four that are not working properly also don't show up in the 'menu' window as shown by the screen shot. The only pallet that shows up in the orange custom shortcuts and the menu window is "Often used" and that was created a long time ago. the other 4 pallets and shortcuts were created yesterday and are the ones causing issues
                                          Cheers
                                          • fredo6F Offline
                                            1. The warning in the console is for TTLib. It is harmless and not related to LOTT.
                                            2. I cannot reproduce the problem with shortcuts. In my environment, I can just define them and they work.
                                            Do you have the latest version of LibFredo6 and LOTT installed?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 23
                                            • 24
                                            • 12 / 24
