    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 726.0k Views 99 Watching
      menmsis
      Great Tool.
      I only have a problem, since I installed the new version the option to create personal commands from the menu commands does not work.
      Every fredo plugin is update.
      • fredo6F
        By saying "the menu commands does not work", do you mean that
        1. the functionality is not available (i.e. the row with 'Menu' is missing)
        2. or when you click on the Menu label, nothing happens (if so, could you open the Ruby console before clicking and check if there are error messages)
        3. or something else...
          @menmsis said:
          I only have a problem...
          What version of SketchUp are you using? That may have an impact. Please complete your profile.
            menmsis
            1. or when you click on the Menu label, nothing happens (if so, could you open the Ruby console before clicking and check if there are error messages)
            2. or something else...
            [attachment=0:3qwq1hzc]<!-- ia0 -->LOTT perso commands - Menu.png<!-- ia0 -->[/attachment:3qwq1hzc]
            Fredo, what happens is exactly as you mention on option 2. I click the Menu and nothing happens. I got the following erro in the ruby console:
            Error: #<RangeError: invalid codepoint 0xD83D in UTF-8>
            c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5390:in all_menus' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5390:in menu_mapping'
            c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5468:in menu_structured_list' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:1056:in menu_compute_list'
            c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:480:in dialog_format_menu_list' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:411:in dialog_format_properties'
            c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:329:in dialog_prepare_html' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:263:in dialog_load_html'
            c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:175:in dialog_invoke' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:4975:in perso_dialog_invoke'
            c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:4447:in perso_new_command' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:2459:in dialog_callback_exec'
            c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:2316:in dialog_callback' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2427:in call'
            c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2427:in master_callback' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2205:in j_action'
            c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2164:in j_callback' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2150:in block in j_dispatch'
            c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2142:in each' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2142:in j_dispatch'
              menmsis
              Hi Dave.
              I am using 2022.
              I already update my profile
              • fredo6F
                I think this is an issue with one extension which uses diacritic characters in the menu item label.
                Maybe Universal Importer by samuel_t, or one of his other plugins.
                Best is to check in the submenu of the Extensions menu.
                  menmsis
                  Fredo, thank you for your help and all your wonderful plugins.
                  I unistall the universal importer and all worked fine.
                  Best Regards.
                  • alexpacio2013A
                    alexpacio2013
                    Hi I have updated the LortdOfTheToolbars Plugins and from that moment every time I open Sketchup and my menu bars do not go out. To do this I have to launch Master toolbar Manager and they automatically open What can I do?
                      @alexpacio2013 said:
                      Hi I have updated the LortdOfTheToolbars Plugins...
                      What version of SketchUp are you using? Your profile says "pre-2013". Is that correct?
                        rv1974
                        @Dave you should make "What version of SketchUp are you using?" your signature 😄
                        Could it be written in CNC landuage?
                        • alexpacio2013A
                          alexpacio2013
                          After the update of LordOfTheToolbars - v2.2a - 28 Jun 22, now every time I open Sketchup, the menu bars of LordOfTheToolbars are not opened. However, if I open Master Toolbars Manager, the toolbars magically open, see image. What happened?
                          1659777819.050634;top_libfredo6.rbe:171: in `open'
                          DATE / TIME: 2022-08-06 11:23:39 +0200
                          SKETCHUP VERSION: 22.0.354
                          RUBY_PLATFORM: x64-mswin64_140
                          LOG FILE: LibFredo6Trace_22_1659777819048.txt
                          1659777819.0502865;top_libfredo6.rbe:171: in `open'
                          LibFredo6: Starting up Fredo6_!LibFredo6.rb
                          1659777819.0514805;top_libfredo6.rbe:171: in `open'
                          LibFredo6 Root top directory: C:/Users/robo/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins
                          1659777819.0598936;top_libfredo6.rbe:171: in `open'
                          APPDATA Sketchup directory: C:/Users/robo/AppData/Local
                          1659777819.0603428;top_libfredo6.rbe:171: in `open'
                          Temp Files directory: C:/Users/robo/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles
                          1659777819.062464;top_libfredo6.rbe:171: in `open'
                          LibFredo6 Data directory folder: C:/Users/robo/AppData/Local/LIBFREDO6_DATA_Dir
                          1659777819.0628412;top_libfredo6.rbe:171: in `open'
                          Default Parameters folder: C:/Users/robo/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters
                          1659777819.063465;top_libfredo6.rbe:171: in `open'
                          LibFredo6: Beginning of loading Cycle***+
                          1659777819.0766423;top_libfredo6.rbe:171: in `open'
                          LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core successfully loaded
                          1659777819.106217;top_libfredo6.rbe:171: in `open'
                          LibFredo6 12.9a: Effective Load - #0
                          1659777819.297847;top_libfredo6.rbe:171: in `open'
                          LibFredo6 12.9a: Ruby files loaded [189 ms]
                          1659777819.3327165;top_libfredo6.rbe:171: in `open'
                          add Command Seleziona Lingua preferita...
                          1659777819.333846;top_libfredo6.rbe:171: in `open'
                          add Command Controlla aggiornamenti Plugins...
                          1659777819.3347752;top_libfredo6.rbe:171: in `open'
                          add Command Purge Obsolete files...
                          1659777819.3356633;top_libfredo6.rbe:171: in `open'
                          add Command Performances...
                          1659777819.3365421;top_libfredo6.rbe:171: in `open'
                          add Command View Trace log files...
                          1659777819.3375835;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni LibFredo6 v12.9a...
                          1659777819.3420873;top_libfredo6.rbe:171: in `open'
                          add Command Informazione Plugin [Sketchucation]...
                          1659777819.3435683;top_libfredo6.rbe:171: in `open'
                          add Command Modifica parametri di Default...
                          1659777819.3444655;top_libfredo6.rbe:171: in `open'
                          add Command Traduzione Lingue...
                          1659777819.345387;top_libfredo6.rbe:171: in `open'
                          LibFredo6 12.9a: Startup (creating menus and icons) [46 ms]
                          1659777819.35002;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: LordOfTheToolbars
                          1659777819.3885655;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: Animator
                          1659777819.3910367;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: Curviloft
                          1659777819.3933218;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: Curvizard
                          1659777819.3955631;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: FredoCorner
                          1659777819.3977685;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: FredoGuides
                          1659777819.4000278;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: FredoScale
                          1659777819.402219;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: FredoSpline
                          1659777819.404525;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: FredoTools
                          1659777819.4067292;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: HoverSelect
                          1659777819.4090075;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: JointPushPull
                          1659777819.4111617;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: MoveAlignMe
                          1659777819.4133294;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: MrHide
                          1659777819.415562;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: ToolsOnSurface
                          1659777819.4176936;top_libfredo6.rbe:171: in `open'
                          Found valid plugin: VisuHole
                          1659777819.6108224;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [0]: ["LordOfTheToolbars", "!!Fredo6_LordOfTheToolbars"]
                          1659777819.61143;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [1]: ["Animator", "Fredo6_Animator"]
                          1659777819.6119018;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [2]: ["Curviloft", "Fredo6_Curviloft"]
                          1659777819.6123133;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [3]: ["Curvizard", "Fredo6_Curvizard"]
                          1659777819.6127267;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [4]: ["FredoCorner", "Fredo6_FredoCorner"]
                          1659777819.6131077;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [5]: ["FredoGuides", "Fredo6_FredoGuides"]
                          1659777819.613492;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [6]: ["FredoScale", "Fredo6_FredoScale"]
                          1659777819.6138604;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [7]: ["FredoSpline", "Fredo6_FredoSpline"]
                          1659777819.6142204;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [8]: ["FredoTools", "Fredo6_FredoTools"]
                          1659777819.6145978;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [9]: ["HoverSelect", "Fredo6_HoverSelect"]
                          1659777819.6149728;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [10]: ["JointPushPull", "Fredo6_JointPushPull"]
                          1659777819.6153467;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [11]: ["MoveAlignMe", "Fredo6_MoveAlignMe"]
                          1659777819.6157293;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [12]: ["MrHide", "Fredo6_MrHide"]
                          1659777819.6160994;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [13]: ["ToolsOnSurface", "Fredo6_ToolsOnSurface"]
                          1659777819.6164649;top_libfredo6.rbe:171: in `open'
                          Plugin to Load [14]: ["VisuHole", "Fredo6_VisuHole"]
                          1659777819.8602266;top_libfredo6.rbe:171: in `open'
                          LordOfTheToolbars 2.2a: Effective Load - #1
                          1659777819.8711247;top_libfredo6.rbe:171: in `open'
                          LordOfTheToolbars: Seed file created
                          1659777819.87369;top_libfredo6.rbe:171: in `open'
                          LordOfTheToolbars: COPIED SEED C:/ProgramData/SketchUp/SketchUp 2022/SketchUp/Plugins/!LordOfTheToolbars_seed.rb exist = true
                          1659777819.874354;top_libfredo6.rbe:171: in `open'
                          LordOfTheToolbars 2.2a: Bootstrap Ruby files loaded [13 ms]
                          1659777819.8949528;top_libfredo6.rbe:171: in `open'
                          add Command Master Toolbar Manager
                          1659777819.897017;top_libfredo6.rbe:171: in `open'
                          add Command Favorite Manager
                          1659777819.8990428;top_libfredo6.rbe:171: in `open'
                          add Command History Palette
                          1659777819.9010985;top_libfredo6.rbe:171: in `open'
                          add Command Navigate History
                          1659777819.9030466;top_libfredo6.rbe:171: in `open'
                          add Command Last command
                          1659777819.9049275;top_libfredo6.rbe:171: in `open'
                          add Command Toggle visibility of the Vignette stripe
                          1659777819.9073923;top_libfredo6.rbe:171: in `open'
                          add Command Reset the Vignette Stripe position
                          1659777819.909998;top_libfredo6.rbe:171: in `open'
                          add Command Pop up the Vignette Stripe
                          1659777819.912691;top_libfredo6.rbe:171: in `open'
                          add Command Cycle through Palettes
                          1659777819.9152055;top_libfredo6.rbe:171: in `open'
                          add Command Quick Command Finder
                          1659777819.9175193;top_libfredo6.rbe:171: in `open'
                          add Command Backup LOTT Config
                          1659777819.9199433;top_libfredo6.rbe:171: in `open'
                          add Command Import LOTT Config
                          1659777819.9222531;top_libfredo6.rbe:171: in `open'
                          add Command Export LOTT Config
                          1659777819.9246366;top_libfredo6.rbe:171: in `open'
                          add Command Reset All
                          1659777819.9270604;top_libfredo6.rbe:171: in `open'
                          add Command Reset History
                          1659777819.9294598;top_libfredo6.rbe:171: in `open'
                          add Command Toggle CleanScreen mode
                          1659777819.9318085;top_libfredo6.rbe:171: in `open'
                          add Command CleanScreen Configuration
                          1659777819.9341626;top_libfredo6.rbe:171: in `open'
                          add Command List of all shortuts
                          1659777819.9364662;top_libfredo6.rbe:171: in `open'
                          add Command Exclude VRay
                          1659777819.9388504;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni LordOfTheToolbars v2.2a...
                          1659777819.9445026;top_libfredo6.rbe:171: in `open'
                          1659777819.945423;top_libfredo6.rbe:171: in `open'
                          1659777819.9468265;top_libfredo6.rbe:171: in `open'
                          1659777819.9477277;top_libfredo6.rbe:171: in `open'
                          1659777819.9810462;top_libfredo6.rbe:171: in `open'
                          LordOfTheToolbars 2.2a: Startup (creating menus and icons) [106 ms]
                          1659777820.384493;top_libfredo6.rbe:171: in `open'
                          Animator 3.7a: Effective Load - #2
                          1659777820.3904972;top_libfredo6.rbe:171: in `open'
                          Animator 3.7a: Bootstrap Ruby files loaded [5 ms]
                          1659777820.3949382;top_libfredo6.rbe:171: in `open'
                          Lib6Theme: Loading body code from body_Lib6Theme [3 ms]
                          1659777820.4038517;top_libfredo6.rbe:171: in `open'
                          add Command Clip Editor
                          1659777820.405462;top_libfredo6.rbe:171: in `open'
                          add Command Clip Player
                          1659777820.4067729;top_libfredo6.rbe:171: in `open'
                          add Command Visit Controller
                          1659777820.4081466;top_libfredo6.rbe:171: in `open'
                          add Command Positioner
                          1659777820.4096053;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni Animator v3.7a...
                          1659777820.4207933;top_libfredo6.rbe:171: in `open'
                          1659777820.4217577;top_libfredo6.rbe:171: in `open'
                          1659777820.4231699;top_libfredo6.rbe:171: in `open'
                          1659777820.4240642;top_libfredo6.rbe:171: in `open'
                          1659777820.4625092;top_libfredo6.rbe:171: in `open'
                          Animator 3.7a: Startup (creating menus and icons) [71 ms]
                          1659777820.471187;top_libfredo6.rbe:171: in `open'
                          Curviloft 1.9a: Effective Load - #3
                          1659777820.4753973;top_libfredo6.rbe:171: in `open'
                          Curviloft 1.9a: Bootstrap Ruby files loaded [3 ms]
                          1659777820.4819002;top_libfredo6.rbe:171: in `open'
                          add Command Loft by Spline
                          1659777820.4835315;top_libfredo6.rbe:171: in `open'
                          add Command Loft along path
                          1659777820.4849508;top_libfredo6.rbe:171: in `open'
                          add Command Skin Contours
                          1659777820.486353;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni Curviloft v1.9a...
                          1659777820.487222;top_libfredo6.rbe:171: in `open'
                          add Command License...
                          1659777820.4880924;top_libfredo6.rbe:171: in `open'
                          add Command Trial Period Expiration...
                          1659777820.4938774;top_libfredo6.rbe:171: in `open'
                          1659777820.494852;top_libfredo6.rbe:171: in `open'
                          1659777820.4963236;top_libfredo6.rbe:171: in `open'
                          1659777820.4973097;top_libfredo6.rbe:171: in `open'
                          1659777820.5164933;top_libfredo6.rbe:171: in `open'
                          Curviloft 1.9a: Startup (creating menus and icons) [40 ms]
                          1659777820.5256727;top_libfredo6.rbe:171: in `open'
                          Curvizard 2.4b: Effective Load - #4
                          1659777820.5323317;top_libfredo6.rbe:171: in `open'
                          Curvizard 2.4b: Bootstrap Ruby files loaded [5 ms]
                          1659777820.541005;top_libfredo6.rbe:171: in `open'
                          add Command Quick Launcher...
                          1659777820.5426147;top_libfredo6.rbe:171: in `open'
                          add Command Make Curves (weld)
                          1659777820.5440307;top_libfredo6.rbe:171: in `open'
                          add Command Explode Curves
                          1659777820.545435;top_libfredo6.rbe:171: in `open'
                          add Command Cleanup Contours
                          1659777820.5468512;top_libfredo6.rbe:171: in `open'
                          add Command Simplify Contours
                          1659777820.5482337;top_libfredo6.rbe:171: in `open'
                          add Command Smooth Contours
                          1659777820.5496497;top_libfredo6.rbe:171: in `open'
                          add Command Edge Properties
                          1659777820.5510848;top_libfredo6.rbe:171: in `open'
                          add Command Convert Edges to Guides
                          1659777820.5525348;top_libfredo6.rbe:171: in `open'
                          add Command Convert to Arc / Circle
                          1659777820.553985;top_libfredo6.rbe:171: in `open'
                          add Command Convert to Polygon
                          1659777820.555427;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni Curvizard v2.4b...
                          1659777820.5563304;top_libfredo6.rbe:171: in `open'
                          1659777820.5576882;top_libfredo6.rbe:171: in `open'
                          1659777820.563914;top_libfredo6.rbe:171: in `open'
                          1659777820.5650506;top_libfredo6.rbe:171: in `open'
                          1659777820.5668058;top_libfredo6.rbe:171: in `open'
                          1659777820.5678856;top_libfredo6.rbe:171: in `open'
                          1659777820.6217778;top_libfredo6.rbe:171: in `open'
                          Curvizard 2.4b: Startup (creating menus and icons) [88 ms]
                          1659777820.6301749;top_libfredo6.rbe:171: in `open'
                          FredoCorner 2.5a: Effective Load - #5
                          1659777820.6354005;top_libfredo6.rbe:171: in `open'
                          FredoCorner 2.5a: Bootstrap Ruby files loaded [4 ms]
                          1659777820.6419108;top_libfredo6.rbe:171: in `open'
                          add Command Round
                          1659777820.6434898;top_libfredo6.rbe:171: in `open'
                          add Command Bevel
                          1659777820.6449006;top_libfredo6.rbe:171: in `open'
                          add Command SubDivision
                          1659777820.6463234;top_libfredo6.rbe:171: in `open'
                          add Command Chop Corner
                          1659777820.6476603;top_libfredo6.rbe:171: in `open'
                          add Command Repair
                          1659777820.64898;top_libfredo6.rbe:171: in `open'
                          add Command Purge all data
                          1659777820.6499054;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni Fredo Corner v2.5a...
                          1659777820.650826;top_libfredo6.rbe:171: in `open'
                          1659777820.6517062;top_libfredo6.rbe:171: in `open'
                          1659777820.6563776;top_libfredo6.rbe:171: in `open'
                          1659777820.6572852;top_libfredo6.rbe:171: in `open'
                          1659777820.6587155;top_libfredo6.rbe:171: in `open'
                          1659777820.6596198;top_libfredo6.rbe:171: in `open'
                          1659777820.6959202;top_libfredo6.rbe:171: in `open'
                          FredoCorner 2.5a: Startup (creating menus and icons) [60 ms]
                          1659777820.7102923;top_libfredo6.rbe:171: in `open'
                          FredoScale 3.5a: Effective Load - #6
                          1659777820.717813;top_libfredo6.rbe:171: in `open'
                          FredoScale 3.5a: Bootstrap Ruby files loaded [6 ms]
                          1659777820.7442555;top_libfredo6.rbe:171: in `open'
                          1659777820.7465575;top_libfredo6.rbe:171: in `open'
                          add Command Box Scalatura
                          1659777820.7489302;top_libfredo6.rbe:171: in `open'
                          add Command Box Scalatura verso Destinazione
                          1659777820.7512124;top_libfredo6.rbe:171: in `open'
                          add Command Box Inclinatura
                          1659777820.753441;top_libfredo6.rbe:171: in `open'
                          add Command Box Inclinatura verso Destinazione
                          1659777820.7556183;top_libfredo6.rbe:171: in `open'
                          add Command Box Shearing Planare
                          1659777820.757817;top_libfredo6.rbe:171: in `open'
                          add Command Box Shearing Planare verso Destinazione
                          1659777820.7599664;top_libfredo6.rbe:171: in `open'
                          add Command Shearing Planare (Libero)
                          1659777820.7621584;top_libfredo6.rbe:171: in `open'
                          add Command Box Stretching
                          1659777820.764318;top_libfredo6.rbe:171: in `open'
                          add Command Box Stretching verso Destinazione
                          1659777820.7677734;top_libfredo6.rbe:171: in `open'
                          add Command Box Twisting
                          1659777820.7698052;top_libfredo6.rbe:171: in `open'
                          add Command Box Rotazione
                          1659777820.7717674;top_libfredo6.rbe:171: in `open'
                          add Command Rotazione (Libero)
                          1659777820.7737472;top_libfredo6.rbe:171: in `open'
                          add Command Bending Radiale (Libero)
                          1659777820.7757032;top_libfredo6.rbe:171: in `open'
                          add Command Rendi Unico
                          1659777820.778194;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni FredoScale v3.5a...
                          1659777820.7792869;top_libfredo6.rbe:171: in `open'
                          1659777820.780257;top_libfredo6.rbe:171: in `open'
                          1659777820.7861962;top_libfredo6.rbe:171: in `open'
                          1659777820.7871573;top_libfredo6.rbe:171: in `open'
                          1659777820.788678;top_libfredo6.rbe:171: in `open'
                          1659777820.7896168;top_libfredo6.rbe:171: in `open'
                          1659777820.8383808;top_libfredo6.rbe:171: in `open'
                          FredoScale 3.5a: Startup (creating menus and icons) [120 ms]
                          1659777820.8477514;top_libfredo6.rbe:171: in `open'
                          FredoSpline 2.3a: Effective Load - #7
                          1659777820.8552005;top_libfredo6.rbe:171: in `open'
                          FredoSpline 2.3a: Bootstrap Ruby files loaded [6 ms]
                          1659777820.8683937;top_libfredo6.rbe:171: in `open'
                          1659777820.8703284;top_libfredo6.rbe:171: in `open'
                          add Command Create Curves
                          1659777820.8719673;top_libfredo6.rbe:171: in `open'
                          add Command Edit Curves
                          1659777820.8735292;top_libfredo6.rbe:171: in `open'
                          add Command Swap Curves
                          1659777820.875027;top_libfredo6.rbe:171: in `open'
                          add Command Convert Curves
                          1659777820.8765285;top_libfredo6.rbe:171: in `open'
                          add Command Purge data
                          1659777820.8779967;top_libfredo6.rbe:171: in `open'
                          add Command Purge All data
                          1659777820.8795464;top_libfredo6.rbe:171: in `open'
                          add Command Bezier Classic
                          1659777820.8810525;top_libfredo6.rbe:171: in `open'
                          add Command Bezier Nurbs
                          1659777820.882643;top_libfredo6.rbe:171: in `open'
                          add Command Local Fit Spline
                          1659777820.8841708;top_libfredo6.rbe:171: in `open'
                          add Command Global Fit Spline
                          1659777820.8857195;top_libfredo6.rbe:171: in `open'
                          add Command Polyline
                          1659777820.88723;top_libfredo6.rbe:171: in `open'
                          add Command Polyline Divider
                          1659777820.8888128;top_libfredo6.rbe:171: in `open'
                          add Command Polyline Segmentor
                          1659777820.8903725;top_libfredo6.rbe:171: in `open'
                          add Command Polycorner Generic
                          1659777820.8918214;top_libfredo6.rbe:171: in `open'
                          add Command Polycorner Arc
                          1659777820.8934803;top_libfredo6.rbe:171: in `open'
                          add Command Polycorner Squircle
                          1659777820.894999;top_libfredo6.rbe:171: in `open'
                          add Command Polycorner Bezier
                          1659777820.8965273;top_libfredo6.rbe:171: in `open'
                          add Command Polycorner Chamfer
                          1659777820.898061;top_libfredo6.rbe:171: in `open'
                          add Command Polycorner Dog-Bone
                          1659777820.8996205;top_libfredo6.rbe:171: in `open'
                          add Command Polycorner T-Bone
                          1659777820.9011447;top_libfredo6.rbe:171: in `open'
                          add Command Courbette
                          1659777820.9026604;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni FredoSpline v2.3a...
                          1659777820.9036179;top_libfredo6.rbe:171: in `open'
                          1659777820.9045167;top_libfredo6.rbe:171: in `open'
                          1659777820.908837;top_libfredo6.rbe:171: in `open'
                          1659777820.909901;top_libfredo6.rbe:171: in `open'
                          1659777820.9114738;top_libfredo6.rbe:171: in `open'
                          1659777820.9123995;top_libfredo6.rbe:171: in `open'
                          1659777820.9920552;top_libfredo6.rbe:171: in `open'
                          FredoSpline 2.3a: Startup (creating menus and icons) [136 ms]
                          1659777821.0018177;top_libfredo6.rbe:171: in `open'
                          FredoTools 4.3a: Effective Load - #8
                          1659777821.0720754;top_libfredo6.rbe:171: in `open'
                          FredoTools 4.3a: Ruby files loaded [68 ms]
                          1659777821.0804183;top_libfredo6.rbe:171: in `open'
                          Lib6Material: Loading body code from body_Lib6Material [4 ms]
                          1659777821.1087255;top_libfredo6.rbe:171: in `open'
                          add Command >> FredoTools Launcher...
                          1659777821.1106596;top_libfredo6.rbe:171: in `open'
                          add Command Angle Inspector
                          1659777821.1128163;top_libfredo6.rbe:171: in `open'
                          add Command AutoReverseFaces
                          1659777821.1148922;top_libfredo6.rbe:171: in `open'
                          add Command Color by Altitude
                          1659777821.1164553;top_libfredo6.rbe:171: in `open'
                          add Command Color by Slope
                          1659777821.1181555;top_libfredo6.rbe:171: in `open'
                          add Command Color Flat Mode
                          1659777821.119647;top_libfredo6.rbe:171: in `open'
                          add Command Color Paint
                          1659777821.1212366;top_libfredo6.rbe:171: in `open'
                          add Command Construct Face Normals
                          1659777821.1233282;top_libfredo6.rbe:171: in `open'
                          add Command Convexify
                          1659777821.1256363;top_libfredo6.rbe:171: in `open'
                          add Command Count Faces by Sides
                          1659777821.1277225;top_libfredo6.rbe:171: in `open'
                          add Command CurviShear
                          1659777821.12977;top_libfredo6.rbe:171: in `open'
                          add Command Divide Edges
                          1659777821.1318834;top_libfredo6.rbe:171: in `open'
                          add Command Draw Along
                          1659777821.1340015;top_libfredo6.rbe:171: in `open'
                          add Command Edge Inspector
                          1659777821.1360934;top_libfredo6.rbe:171: in `open'
                          add Command Element Stats
                          1659777821.138192;top_libfredo6.rbe:171: in `open'
                          add Command FaceTriangulator
                          1659777821.1404064;top_libfredo6.rbe:171: in `open'
                          add Command Mark Vertices
                          1659777821.1425476;top_libfredo6.rbe:171: in `open'
                          add Command Move Along
                          1659777821.1447155;top_libfredo6.rbe:171: in `open'
                          add Command Remove Lonely Vertices
                          1659777821.1468349;top_libfredo6.rbe:171: in `open'
                          add Command Report on Areas
                          1659777821.1483846;top_libfredo6.rbe:171: in `open'
                          add Command Label with Areas
                          1659777821.1504822;top_libfredo6.rbe:171: in `open'
                          add Command ReverseOrientFaces
                          1659777821.1522555;top_libfredo6.rbe:171: in `open'
                          add Command Revert Curves
                          1659777821.1544452;top_libfredo6.rbe:171: in `open'
                          add Command Solid Volume
                          1659777821.1567695;top_libfredo6.rbe:171: in `open'
                          add Command ThruPaint
                          1659777821.1585371;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni Fredo Tools v4.3a...
                          1659777821.1728668;top_libfredo6.rbe:171: in `open'
                          1659777821.1740627;top_libfredo6.rbe:171: in `open'
                          1659777821.1757603;top_libfredo6.rbe:171: in `open'
                          1659777821.1768177;top_libfredo6.rbe:171: in `open'
                          1659777821.263448;top_libfredo6.rbe:171: in `open'
                          FredoTools 4.3a: Startup (creating menus and icons) [190 ms]
                          1659777821.2722695;top_libfredo6.rbe:171: in `open'
                          HoverSelect 1.5a: Effective Load - #9
                          1659777821.2924924;top_libfredo6.rbe:171: in `open'
                          HoverSelect 1.5a: Ruby files loaded [18 ms]
                          1659777821.297239;top_libfredo6.rbe:171: in `open'
                          add Command Hover Select Edges
                          1659777821.2992785;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni HoverSelect v1.5a...
                          1659777821.3032396;top_libfredo6.rbe:171: in `open'
                          1659777821.3041375;top_libfredo6.rbe:171: in `open'
                          1659777821.3055997;top_libfredo6.rbe:171: in `open'
                          1659777821.3064806;top_libfredo6.rbe:171: in `open'
                          1659777821.3119593;top_libfredo6.rbe:171: in `open'
                          HoverSelect 1.5a: Startup (creating menus and icons) [18 ms]
                          1659777821.3206584;top_libfredo6.rbe:171: in `open'
                          JointPushPull 4.4e: Effective Load - #10
                          1659777821.3262935;top_libfredo6.rbe:171: in `open'
                          JointPushPull 4.4e: Bootstrap Ruby files loaded [4 ms]
                          1659777821.335673;top_libfredo6.rbe:171: in `open'
                          1659777821.3376372;top_libfredo6.rbe:171: in `open'
                          add Command Thickener
                          1659777821.3393734;top_libfredo6.rbe:171: in `open'
                          add Command Joint Push Pull
                          1659777821.341129;top_libfredo6.rbe:171: in `open'
                          add Command Round Push Pull
                          1659777821.342861;top_libfredo6.rbe:171: in `open'
                          add Command Vector Push Pull
                          1659777821.344577;top_libfredo6.rbe:171: in `open'
                          add Command Normal Push Pull
                          1659777821.3462873;top_libfredo6.rbe:171: in `open'
                          add Command Extrude Push Pull
                          1659777821.3480852;top_libfredo6.rbe:171: in `open'
                          add Command Follow Push Pull
                          1659777821.3498316;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni JointPushPull v4.4e...
                          1659777821.3507373;top_libfredo6.rbe:171: in `open'
                          1659777821.3516152;top_libfredo6.rbe:171: in `open'
                          1659777821.357344;top_libfredo6.rbe:171: in `open'
                          1659777821.3597226;top_libfredo6.rbe:171: in `open'
                          1659777821.3611848;top_libfredo6.rbe:171: in `open'
                          1659777821.362069;top_libfredo6.rbe:171: in `open'
                          1659777821.413224;top_libfredo6.rbe:171: in `open'
                          JointPushPull 4.4e: Startup (creating menus and icons) [86 ms]
                          1659777821.421949;top_libfredo6.rbe:171: in `open'
                          MoveAlignMe 1.2a: Effective Load - #11
                          1659777821.426346;top_libfredo6.rbe:171: in `open'
                          MoveAlignMe 1.2a: Bootstrap Ruby files loaded [3 ms]
                          1659777821.4303312;top_libfredo6.rbe:171: in `open'
                          add Command Move - Pivot - Straighten
                          1659777821.432269;top_libfredo6.rbe:171: in `open'
                          add Command Move and Glue
                          1659777821.4339776;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni MoveAlignMe v1.2a...
                          1659777821.4389012;top_libfredo6.rbe:171: in `open'
                          1659777821.439845;top_libfredo6.rbe:171: in `open'
                          1659777821.4413064;top_libfredo6.rbe:171: in `open'
                          1659777821.4421935;top_libfredo6.rbe:171: in `open'
                          1659777821.4644544;top_libfredo6.rbe:171: in `open'
                          MoveAlignMe 1.2a: Startup (creating menus and icons) [37 ms]
                          1659777821.4756064;top_libfredo6.rbe:171: in `open'
                          MrHide 1.6a: Effective Load - #12
                          1659777821.4834373;top_libfredo6.rbe:171: in `open'
                          MrHide 1.6a: Bootstrap Ruby files loaded [7 ms]
                          1659777821.4958718;top_libfredo6.rbe:171: in `open'
                          1659777821.4974673;top_libfredo6.rbe:171: in `open'
                          add Command View Hidden Geometry
                          1659777821.4989045;top_libfredo6.rbe:171: in `open'
                          add Command View Hidden Objects
                          1659777821.500291;top_libfredo6.rbe:171: in `open'
                          add Command Draw Back Edges
                          1659777821.501683;top_libfredo6.rbe:171: in `open'
                          add Command View Axes
                          1659777821.5035517;top_libfredo6.rbe:171: in `open'
                          add Command View Component Axes
                          1659777821.5050678;top_libfredo6.rbe:171: in `open'
                          add Command View Guides
                          1659777821.506527;top_libfredo6.rbe:171: in `open'
                          add Command View Dimensions
                          1659777821.5080168;top_libfredo6.rbe:171: in `open'
                          add Command View Text Labels
                          1659777821.5095255;top_libfredo6.rbe:171: in `open'
                          add Command Display Shadows
                          1659777821.5110574;top_libfredo6.rbe:171: in `open'
                          add Command Display Sun shading
                          1659777821.5125182;top_libfredo6.rbe:171: in `open'
                          add Command View Fog
                          1659777821.5139978;top_libfredo6.rbe:171: in `open'
                          add Command View Ground
                          1659777821.5154166;top_libfredo6.rbe:171: in `open'
                          add Command View Sky
                          1659777821.5169723;top_libfredo6.rbe:171: in `open'
                          add Command Color by Tag
                          1659777821.5185745;top_libfredo6.rbe:171: in `open'
                          add Command Edge Visibility
                          1659777821.5200028;top_libfredo6.rbe:171: in `open'
                          add Command Edge Profiles
                          1659777821.521416;top_libfredo6.rbe:171: in `open'
                          add Command Draw Endpoints
                          1659777821.522842;top_libfredo6.rbe:171: in `open'
                          add Command Edge Color By Material
                          1659777821.524244;top_libfredo6.rbe:171: in `open'
                          add Command Edge Color By Axis
                          1659777821.5256379;top_libfredo6.rbe:171: in `open'
                          add Command Hide similar instances
                          1659777821.5270412;top_libfredo6.rbe:171: in `open'
                          add Command Hide Rest of the model
                          1659777821.528457;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni MrHide v1.6a...
                          1659777821.5332236;top_libfredo6.rbe:171: in `open'
                          1659777821.5342171;top_libfredo6.rbe:171: in `open'
                          1659777821.5356562;top_libfredo6.rbe:171: in `open'
                          1659777821.5366085;top_libfredo6.rbe:171: in `open'
                          1659777821.652451;top_libfredo6.rbe:171: in `open'
                          MrHide 1.6a: Startup (creating menus and icons) [168 ms]
                          1659777821.6611593;top_libfredo6.rbe:171: in `open'
                          ToolsOnSurface 2.5a: Effective Load - #13
                          1659777821.6690829;top_libfredo6.rbe:171: in `open'
                          ToolsOnSurface 2.5a: Bootstrap Ruby files loaded [7 ms]
                          1659777821.6850967;top_libfredo6.rbe:171: in `open'
                          1659777821.687485;top_libfredo6.rbe:171: in `open'
                          add Command Generic Tools on Surface
                          1659777821.6888132;top_libfredo6.rbe:171: in `open'
                          add Command Line on Surface
                          1659777821.6902533;top_libfredo6.rbe:171: in `open'
                          add Command Rectangle
                          1659777821.6918726;top_libfredo6.rbe:171: in `open'
                          add Command Circle
                          1659777821.6935656;top_libfredo6.rbe:171: in `open'
                          add Command Polygon
                          1659777821.6957371;top_libfredo6.rbe:171: in `open'
                          add Command Ellipse
                          1659777821.6975596;top_libfredo6.rbe:171: in `open'
                          add Command Parallelogram
                          1659777821.6994553;top_libfredo6.rbe:171: in `open'
                          add Command Arc
                          1659777821.7012951;top_libfredo6.rbe:171: in `open'
                          add Command Circle (3 Points)
                          1659777821.7031078;top_libfredo6.rbe:171: in `open'
                          add Command Sector (Pie)
                          1659777821.7049463;top_libfredo6.rbe:171: in `open'
                          add Command Offset on Surface
                          1659777821.7067401;top_libfredo6.rbe:171: in `open'
                          add Command Free Hand on Surface
                          1659777821.7086666;top_libfredo6.rbe:171: in `open'
                          add Command Edit Contours on Surface
                          1659777821.7103713;top_libfredo6.rbe:171: in `open'
                          add Command Eraser on Surface
                          1659777821.7118523;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni Tools on Surface v2.5a...
                          1659777821.712737;top_libfredo6.rbe:171: in `open'
                          1659777821.7136042;top_libfredo6.rbe:171: in `open'
                          1659777821.7186472;top_libfredo6.rbe:171: in `open'
                          1659777821.7195928;top_libfredo6.rbe:171: in `open'
                          1659777821.721014;top_libfredo6.rbe:171: in `open'
                          1659777821.7218785;top_libfredo6.rbe:171: in `open'
                          1659777821.8156009;top_libfredo6.rbe:171: in `open'
                          ToolsOnSurface 2.5a: Startup (creating menus and icons) [146 ms]
                          1659777821.8244748;top_libfredo6.rbe:171: in `open'
                          VisuHole 1.4b: Effective Load - #14
                          1659777821.8285341;top_libfredo6.rbe:171: in `open'
                          VisuHole 1.4b: Bootstrap Ruby files loaded [3 ms]
                          1659777821.8331802;top_libfredo6.rbe:171: in `open'
                          add Command VisuHole: Stencil
                          1659777821.8352547;top_libfredo6.rbe:171: in `open'
                          add Command Informazioni VisuHole v1.4b...
                          1659777821.836168;top_libfredo6.rbe:171: in `open'
                          1659777821.8370469;top_libfredo6.rbe:171: in `open'
                          1659777821.8414953;top_libfredo6.rbe:171: in `open'
                          1659777821.8425024;top_libfredo6.rbe:171: in `open'
                          1659777821.8439815;top_libfredo6.rbe:171: in `open'
                          1659777821.8448694;top_libfredo6.rbe:171: in `open'
                          1659777821.856961;top_libfredo6.rbe:171: in `open'
                          VisuHole 1.4b: Startup (creating menus and icons) [27 ms]
                          1659777848.5419104;top_libfredo6.rbe:171: in `open'
                          LibFredo6: End of loading Cycle***-
                          1659777848.655718;top_libfredo6.rbe:171: in `open'
                          Lib6ColorSpecDialog: Loading body code from body_Lib6ColorSpecDialog [8 ms] status = true
                          1659777848.6649866;top_libfredo6.rbe:171: in `open'
                          Lib6Onglets: Loading body code from body_Lib6Onglets [8 ms] status = true
                          1659777848.666665;top_libfredo6.rbe:171: in `open'
                          Lib6ColorScale: Loading body code from body_Lib6ColorScale [29 ms] status = true
                          1659777848.7103868;top_libfredo6.rbe:171: in `open'
                          LordOfTheToolbars 2.2a: Ruby files loaded [165 ms]
                          1659777848.7280338;top_libfredo6.rbe:171: in `open'
                          Lib6_txtmsg: Loading body code from body_Lib6_txtmsg [16 ms] status = true
                          1659777848.7825856;top_libfredo6.rbe:171: in `open'
                          Lib6G6: Loading body code from body_Lib6G6 [53 ms] status = true
                          1659777848.7919383;top_libfredo6.rbe:171: in `open'
                          LibFredo6: Loaded Binary C:/Users/robo/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU22/bin_body_Lib6G6.so
                          1659777848.8168008;top_libfredo6.rbe:171: in `open'
                          Lib6Tool: Loading body code from body_Lib6Tool [16 ms] status = true
                          1659777848.8180127;top_libfredo6.rbe:171: in `open'
                          Lib6Translate: Loading body code from body_Lib6Translate [25 ms] status = true
                          1659777848.8472762;top_libfredo6.rbe:171: in `open'
                          Lib6RoundingProfiler: Loading body code from body_Lib6RoundingProfiler [15 ms] status = true
                          1659777848.8485556;top_libfredo6.rbe:171: in `open'
                          Lib6Spline: Loading body code from body_Lib6Spline [29 ms] status = true
                          1659777848.859474;top_libfredo6.rbe:171: in `open'
                          Lib6WebHtml: Loading body code from body_Lib6WebHtml [10 ms] status = true
                          1659777848.8691103;top_libfredo6.rbe:171: in `open'
                          Lib6Algo: Loading body code from body_Lib6Algo [8 ms] status = true
                          1659777848.8792436;top_libfredo6.rbe:171: in `open'
                          Lib6Contour: Loading body code from body_Lib6Contour [9 ms] status = true
                          1659777848.8860703;top_libfredo6.rbe:171: in `open'
                          Lib6Offset3d: Loading body code from body_Lib6Offset3d [5 ms] status = true
                          1659777848.8964381;top_libfredo6.rbe:171: in `open'
                          Lib6Transform: Loading body code from body_Lib6Transform [9 ms] status = true
                          1659777848.9045694;top_libfredo6.rbe:171: in `open'
                          Lib6Mark: Loading body code from body_Lib6Mark [7 ms] status = true
                          1659777848.9104576;top_libfredo6.rbe:171: in `open'
                          Lib6Vault: Loading body code from body_Lib6Vault [5 ms]
                          1659777848.916615;top_libfredo6.rbe:171: in `open'
                          Lib6Marshall: Loading body code from body_Lib6Marshall [5 ms]
                          1659777848.9322221;top_libfredo6.rbe:171: in `open'
                          Lib6CompManager: Loading body code from body_Lib6CompManager [15 ms]
                          1659777848.9460337;top_libfredo6.rbe:171: in `open'
                          Lib6PathManager: Loading body code from body_Lib6PathManager [13 ms]
                          1659777848.9552493;top_libfredo6.rbe:171: in `open'
                          Lib6Shortcuts: Loading body code from body_Lib6Shortcuts [7 ms]
                          1659777848.9626634;top_libfredo6.rbe:171: in `open'
                          Lib6MonoFactory: Loading body code from body_Lib6MonoFactory [6 ms]
                          1659777850.701963;top_libfredo6.rbe:171: in `open'
                          Lib6NativeManager: Loading body code from body_Lib6NativeManager [13 ms]
                          1659777916.0953088;top_libfredo6.rbe:171: in `open'
                          Lib6ChromiumJS: Loading body code from body_Lib6ChromiumJS [4 ms]
                          1659777916.1139123;top_libfredo6.rbe:171: in `open'
                          Lib6ChromiumWdlg: Loading body code from body_Lib6ChromiumWdlg [17 ms]
                          1659779297.9428368;top_libfredo6.rbe:171: in `open'
                          Lib6Variator: Loading body code from body_Lib6Variator [6 ms] status = true
                          1659779298.0459197;top_libfredo6.rbe:171: in `open'
                          FredoSpline 2.3a: Ruby files loaded [120 ms]
                          1659779348.9734035;top_libfredo6.rbe:171: in `open'
                          Lib6PluginDialogs: Loading body code from body_Lib6PluginDialogs [10 ms]
                          1659779348.9823189;top_libfredo6.rbe:171: in `open'
                          Lib6WebXTable: Loading body code from body_Lib6WebXTable [7 ms]
                          • fredo6F
                            By chance, do you have Universal Importer installed or any other plugins by samuel_t?
                            If so, there is an incompatibility with LOTT, I am afraid, until Samuel updates his plugins.
                            • alexpacio2013A
                              alexpacio2013
                              Thanks, I solved it by uninstalling Universal Importer. Always punctual and precise. Without Fredo6 I would not be able to use Sketchup. 🤣
                              • samuel_tS
                                samuel_t
                                Hello there, Universal Importer plugin v1.1.8 is compatible with Lord Of The Toolbars plugin v2.2a 😉
                                • L
                                  lionk
                                  Hello fredo. Found an issue. If I set a palette shortcut to c, for example, when some plugins need VCB input, once I type c, this palette will popup untimely.
                                  • cmeedC
                                    cmeed
                                    Hi Fredo,
                                    I have whole heartly enbraced LOTT! It is exactly what I need to clean up my place of work!
                                    The Vinette strip is incredibly fast as you hover over, which is exactly what it needs to be. I wonder possibly if there could a way of spacing out the icons / bigger area to hover over as when in the speed of the moment you can easily brush over the adjacent icon
                                    Maybe a separator would work like the pallettes have
                                    or
                                    Bigger wider version of each icon? (I have small su icons enabled to save valuable space and i think that should still be on - what do you think?)
                                    or
                                    A Separate icon that act as a Vinette for each pallette you need and you can float or add to tool bar?
                                    what do you think?
                                    Cheers
                                    and Thanks Again
                                    • fredo6F
                                      You can click on the first 'dotted' button and choose menu (size of Vignettes). You can make them bigger or smaller.
                                      • cmeedC
                                        cmeed
                                        OOOOH!!
                                          AISmebel
                                          Hello fredo. I have broken icons of plugins and scripts for which I used my pictures. Can they be restored somehow? I don't know how it happened ((
                                          I do restore toolbars but does not help. All the pictures that I used are in place.
                                          • H
                                            haymaker
                                            Hey Fredo.
                                            I just brought your bundle and made a donation for all the great work you do. Before I install it I thought I would re arrange some of my LOTT pallets first. I have been using LOTT for a while now and love it, however the new pallets I have created will not disappear after I pick a tool or click outside of the pallet, or even if I press escape.. I have to either double click on the top of the pallet or click the red X to get them to close. Some, but not all of my older pallets continue to work fine and they close by themselves once I have clicked the icon for the tool I want to use. I have scrolled through the 'Default parameters' window but cant see if I am missing something or is this a bug. I have saved settings and closed and restarted SU but that did not help,
                                            Any assistance you can offer would be greatly appreciated, I would like to resolve this issue before I install the bundle encase I have any other issues.
                                            Could this be an issue with libFredo6 as this is the most recent update?
                                            I have attached a screen shot, shortcuts A, B, D and X are the ones that are not working, A B and X are new, D is an old one that is also not working.
                                            SU2022
                                            LOTT v2.2a
                                            Libfredo6 13.2a Last updated on the 16 sep 22
                                            Windows 11
                                            Thanks for your help
                                            Mike
                                            Screenshot
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 27
                                            • 28
                                            • 12 / 28
