    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    549 Posts 101 Posters 609.9k Views 99 Watching
      menmsis
      @fredo6 said:
      I think this is an issue with one extension which uses diacritic characters in the menu item label.
      Maybe Universal Importer by samuel_t, or one of his other plugins.
      Best is to check in the submenu of the Extensions menu.
      Fredo, thank you for your help and all your wonderful plugins.
      I unistall the universal importer and all worked fine.
      Best Regards.
      • alexpacio2013A
        alexpacio2013
        Hi I have updated the LortdOfTheToolbars Plugins and from that moment every time I open Sketchup and my menu bars do not go out. To do this I have to launch Master toolbar Manager and they automatically open What can I do?
          @alexpacio2013 said:
          Hi I have updated the LortdOfTheToolbars Plugins...
          What version of SketchUp are you using? Your profile says "pre-2013". Is that correct?
            rv1974
            @Dave you should make "What version of SketchUp are you using?" your signature πŸ˜„
            Could it be written in CNC landuage?
            • alexpacio2013A
              alexpacio2013
              After the update of LordOfTheToolbars - v2.2a - 28 Jun 22, now every time I open Sketchup, the menu bars of LordOfTheToolbars are not opened. However, if I open Master Toolbars Manager, the toolbars magically open, see image. What happened?
              1659777819.050634;top_libfredo6.rbe:171: in `open'
              DATE / TIME: 2022-08-06 11:23:39 +0200
              SKETCHUP VERSION: 22.0.354
              RUBY_PLATFORM: x64-mswin64_140
              LOG FILE: LibFredo6Trace_22_1659777819048.txt
              1659777819.0502865;top_libfredo6.rbe:171: in `open'
              LibFredo6: Starting up Fredo6_!LibFredo6.rb
              1659777819.0514805;top_libfredo6.rbe:171: in `open'
              LibFredo6 Root top directory: C:/Users/robo/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins
              1659777819.0598936;top_libfredo6.rbe:171: in `open'
              APPDATA Sketchup directory: C:/Users/robo/AppData/Local
              1659777819.0603428;top_libfredo6.rbe:171: in `open'
              Temp Files directory: C:/Users/robo/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles
              1659777819.062464;top_libfredo6.rbe:171: in `open'
              LibFredo6 Data directory folder: C:/Users/robo/AppData/Local/LIBFREDO6_DATA_Dir
              1659777819.0628412;top_libfredo6.rbe:171: in `open'
              Default Parameters folder: C:/Users/robo/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters
              1659777819.063465;top_libfredo6.rbe:171: in `open'
              LibFredo6: Beginning of loading Cycle***+
              1659777819.0766423;top_libfredo6.rbe:171: in `open'
              LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core successfully loaded
              1659777819.106217;top_libfredo6.rbe:171: in `open'
              LibFredo6 12.9a: Effective Load - #0
              1659777819.297847;top_libfredo6.rbe:171: in `open'
              LibFredo6 12.9a: Ruby files loaded [189 ms]
              1659777819.3327165;top_libfredo6.rbe:171: in `open'
              add Command Seleziona Lingua preferita...
              1659777819.333846;top_libfredo6.rbe:171: in `open'
              add Command Controlla aggiornamenti Plugins...
              1659777819.3347752;top_libfredo6.rbe:171: in `open'
              add Command Purge Obsolete files...
              1659777819.3356633;top_libfredo6.rbe:171: in `open'
              add Command Performances...
              1659777819.3365421;top_libfredo6.rbe:171: in `open'
              add Command View Trace log files...
              1659777819.3375835;top_libfredo6.rbe:171: in `open'
              add Command Informazioni LibFredo6 v12.9a...
              1659777819.3420873;top_libfredo6.rbe:171: in `open'
              add Command Informazione Plugin [Sketchucation]...
              1659777819.3435683;top_libfredo6.rbe:171: in `open'
              add Command Modifica parametri di Default...
              1659777819.3444655;top_libfredo6.rbe:171: in `open'
              add Command Traduzione Lingue...
              1659777819.345387;top_libfredo6.rbe:171: in `open'
              LibFredo6 12.9a: Startup (creating menus and icons) [46 ms]
              1659777819.35002;top_libfredo6.rbe:171: in `open'
              Found valid plugin: LordOfTheToolbars
              1659777819.3885655;top_libfredo6.rbe:171: in `open'
              Found valid plugin: Animator
              1659777819.3910367;top_libfredo6.rbe:171: in `open'
              Found valid plugin: Curviloft
              1659777819.3933218;top_libfredo6.rbe:171: in `open'
              Found valid plugin: Curvizard
              1659777819.3955631;top_libfredo6.rbe:171: in `open'
              Found valid plugin: FredoCorner
              1659777819.3977685;top_libfredo6.rbe:171: in `open'
              Found valid plugin: FredoGuides
              1659777819.4000278;top_libfredo6.rbe:171: in `open'
              Found valid plugin: FredoScale
              1659777819.402219;top_libfredo6.rbe:171: in `open'
              Found valid plugin: FredoSpline
              1659777819.404525;top_libfredo6.rbe:171: in `open'
              Found valid plugin: FredoTools
              1659777819.4067292;top_libfredo6.rbe:171: in `open'
              Found valid plugin: HoverSelect
              1659777819.4090075;top_libfredo6.rbe:171: in `open'
              Found valid plugin: JointPushPull
              1659777819.4111617;top_libfredo6.rbe:171: in `open'
              Found valid plugin: MoveAlignMe
              1659777819.4133294;top_libfredo6.rbe:171: in `open'
              Found valid plugin: MrHide
              1659777819.415562;top_libfredo6.rbe:171: in `open'
              Found valid plugin: ToolsOnSurface
              1659777819.4176936;top_libfredo6.rbe:171: in `open'
              Found valid plugin: VisuHole
              1659777819.6108224;top_libfredo6.rbe:171: in `open'
              Plugin to Load [0]: ["LordOfTheToolbars", "!!Fredo6_LordOfTheToolbars"]
              1659777819.61143;top_libfredo6.rbe:171: in `open'
              Plugin to Load [1]: ["Animator", "Fredo6_Animator"]
              1659777819.6119018;top_libfredo6.rbe:171: in `open'
              Plugin to Load [2]: ["Curviloft", "Fredo6_Curviloft"]
              1659777819.6123133;top_libfredo6.rbe:171: in `open'
              Plugin to Load [3]: ["Curvizard", "Fredo6_Curvizard"]
              1659777819.6127267;top_libfredo6.rbe:171: in `open'
              Plugin to Load [4]: ["FredoCorner", "Fredo6_FredoCorner"]
              1659777819.6131077;top_libfredo6.rbe:171: in `open'
              Plugin to Load [5]: ["FredoGuides", "Fredo6_FredoGuides"]
              1659777819.613492;top_libfredo6.rbe:171: in `open'
              Plugin to Load [6]: ["FredoScale", "Fredo6_FredoScale"]
              1659777819.6138604;top_libfredo6.rbe:171: in `open'
              Plugin to Load [7]: ["FredoSpline", "Fredo6_FredoSpline"]
              1659777819.6142204;top_libfredo6.rbe:171: in `open'
              Plugin to Load [8]: ["FredoTools", "Fredo6_FredoTools"]
              1659777819.6145978;top_libfredo6.rbe:171: in `open'
              Plugin to Load [9]: ["HoverSelect", "Fredo6_HoverSelect"]
              1659777819.6149728;top_libfredo6.rbe:171: in `open'
              Plugin to Load [10]: ["JointPushPull", "Fredo6_JointPushPull"]
              1659777819.6153467;top_libfredo6.rbe:171: in `open'
              Plugin to Load [11]: ["MoveAlignMe", "Fredo6_MoveAlignMe"]
              1659777819.6157293;top_libfredo6.rbe:171: in `open'
              Plugin to Load [12]: ["MrHide", "Fredo6_MrHide"]
              1659777819.6160994;top_libfredo6.rbe:171: in `open'
              Plugin to Load [13]: ["ToolsOnSurface", "Fredo6_ToolsOnSurface"]
              1659777819.6164649;top_libfredo6.rbe:171: in `open'
              Plugin to Load [14]: ["VisuHole", "Fredo6_VisuHole"]
              1659777819.8602266;top_libfredo6.rbe:171: in `open'
              LordOfTheToolbars 2.2a: Effective Load - #1
              1659777819.8711247;top_libfredo6.rbe:171: in `open'
              LordOfTheToolbars: Seed file created
              1659777819.87369;top_libfredo6.rbe:171: in `open'
              LordOfTheToolbars: COPIED SEED C:/ProgramData/SketchUp/SketchUp 2022/SketchUp/Plugins/!LordOfTheToolbars_seed.rb exist = true
              1659777819.874354;top_libfredo6.rbe:171: in `open'
              LordOfTheToolbars 2.2a: Bootstrap Ruby files loaded [13 ms]
              1659777819.8949528;top_libfredo6.rbe:171: in `open'
              add Command Master Toolbar Manager
              1659777819.897017;top_libfredo6.rbe:171: in `open'
              add Command Favorite Manager
              1659777819.8990428;top_libfredo6.rbe:171: in `open'
              add Command History Palette
              1659777819.9010985;top_libfredo6.rbe:171: in `open'
              add Command Navigate History
              1659777819.9030466;top_libfredo6.rbe:171: in `open'
              add Command Last command
              1659777819.9049275;top_libfredo6.rbe:171: in `open'
              add Command Toggle visibility of the Vignette stripe
              1659777819.9073923;top_libfredo6.rbe:171: in `open'
              add Command Reset the Vignette Stripe position
              1659777819.909998;top_libfredo6.rbe:171: in `open'
              add Command Pop up the Vignette Stripe
              1659777819.912691;top_libfredo6.rbe:171: in `open'
              add Command Cycle through Palettes
              1659777819.9152055;top_libfredo6.rbe:171: in `open'
              add Command Quick Command Finder
              1659777819.9175193;top_libfredo6.rbe:171: in `open'
              add Command Backup LOTT Config
              1659777819.9199433;top_libfredo6.rbe:171: in `open'
              add Command Import LOTT Config
              1659777819.9222531;top_libfredo6.rbe:171: in `open'
              add Command Export LOTT Config
              1659777819.9246366;top_libfredo6.rbe:171: in `open'
              add Command Reset All
              1659777819.9270604;top_libfredo6.rbe:171: in `open'
              add Command Reset History
              1659777819.9294598;top_libfredo6.rbe:171: in `open'
              add Command Toggle CleanScreen mode
              1659777819.9318085;top_libfredo6.rbe:171: in `open'
              add Command CleanScreen Configuration
              1659777819.9341626;top_libfredo6.rbe:171: in `open'
              add Command List of all shortuts
              1659777819.9364662;top_libfredo6.rbe:171: in `open'
              add Command Exclude VRay
              1659777819.9388504;top_libfredo6.rbe:171: in `open'
              add Command Informazioni LordOfTheToolbars v2.2a...
              1659777819.9445026;top_libfredo6.rbe:171: in `open'
              1659777819.945423;top_libfredo6.rbe:171: in `open'
              1659777819.9468265;top_libfredo6.rbe:171: in `open'
              1659777819.9477277;top_libfredo6.rbe:171: in `open'
              1659777819.9810462;top_libfredo6.rbe:171: in `open'
              LordOfTheToolbars 2.2a: Startup (creating menus and icons) [106 ms]
              1659777820.384493;top_libfredo6.rbe:171: in `open'
              Animator 3.7a: Effective Load - #2
              1659777820.3904972;top_libfredo6.rbe:171: in `open'
              Animator 3.7a: Bootstrap Ruby files loaded [5 ms]
              1659777820.3949382;top_libfredo6.rbe:171: in `open'
              Lib6Theme: Loading body code from body_Lib6Theme [3 ms]
              1659777820.4038517;top_libfredo6.rbe:171: in `open'
              add Command Clip Editor
              1659777820.405462;top_libfredo6.rbe:171: in `open'
              add Command Clip Player
              1659777820.4067729;top_libfredo6.rbe:171: in `open'
              add Command Visit Controller
              1659777820.4081466;top_libfredo6.rbe:171: in `open'
              add Command Positioner
              1659777820.4096053;top_libfredo6.rbe:171: in `open'
              add Command Informazioni Animator v3.7a...
              1659777820.4207933;top_libfredo6.rbe:171: in `open'
              1659777820.4217577;top_libfredo6.rbe:171: in `open'
              1659777820.4231699;top_libfredo6.rbe:171: in `open'
              1659777820.4240642;top_libfredo6.rbe:171: in `open'
              1659777820.4625092;top_libfredo6.rbe:171: in `open'
              Animator 3.7a: Startup (creating menus and icons) [71 ms]
              1659777820.471187;top_libfredo6.rbe:171: in `open'
              Curviloft 1.9a: Effective Load - #3
              1659777820.4753973;top_libfredo6.rbe:171: in `open'
              Curviloft 1.9a: Bootstrap Ruby files loaded [3 ms]
              1659777820.4819002;top_libfredo6.rbe:171: in `open'
              add Command Loft by Spline
              1659777820.4835315;top_libfredo6.rbe:171: in `open'
              add Command Loft along path
              1659777820.4849508;top_libfredo6.rbe:171: in `open'
              add Command Skin Contours
              1659777820.486353;top_libfredo6.rbe:171: in `open'
              add Command Informazioni Curviloft v1.9a...
              1659777820.487222;top_libfredo6.rbe:171: in `open'
              add Command License...
              1659777820.4880924;top_libfredo6.rbe:171: in `open'
              add Command Trial Period Expiration...
              1659777820.4938774;top_libfredo6.rbe:171: in `open'
              1659777820.494852;top_libfredo6.rbe:171: in `open'
              1659777820.4963236;top_libfredo6.rbe:171: in `open'
              1659777820.4973097;top_libfredo6.rbe:171: in `open'
              1659777820.5164933;top_libfredo6.rbe:171: in `open'
              Curviloft 1.9a: Startup (creating menus and icons) [40 ms]
              1659777820.5256727;top_libfredo6.rbe:171: in `open'
              Curvizard 2.4b: Effective Load - #4
              1659777820.5323317;top_libfredo6.rbe:171: in `open'
              Curvizard 2.4b: Bootstrap Ruby files loaded [5 ms]
              1659777820.541005;top_libfredo6.rbe:171: in `open'
              add Command Quick Launcher...
              1659777820.5426147;top_libfredo6.rbe:171: in `open'
              add Command Make Curves (weld)
              1659777820.5440307;top_libfredo6.rbe:171: in `open'
              add Command Explode Curves
              1659777820.545435;top_libfredo6.rbe:171: in `open'
              add Command Cleanup Contours
              1659777820.5468512;top_libfredo6.rbe:171: in `open'
              add Command Simplify Contours
              1659777820.5482337;top_libfredo6.rbe:171: in `open'
              add Command Smooth Contours
              1659777820.5496497;top_libfredo6.rbe:171: in `open'
              add Command Edge Properties
              1659777820.5510848;top_libfredo6.rbe:171: in `open'
              add Command Convert Edges to Guides
              1659777820.5525348;top_libfredo6.rbe:171: in `open'
              add Command Convert to Arc / Circle
              1659777820.553985;top_libfredo6.rbe:171: in `open'
              add Command Convert to Polygon
              1659777820.555427;top_libfredo6.rbe:171: in `open'
              add Command Informazioni Curvizard v2.4b...
              1659777820.5563304;top_libfredo6.rbe:171: in `open'
              1659777820.5576882;top_libfredo6.rbe:171: in `open'
              1659777820.563914;top_libfredo6.rbe:171: in `open'
              1659777820.5650506;top_libfredo6.rbe:171: in `open'
              1659777820.5668058;top_libfredo6.rbe:171: in `open'
              1659777820.5678856;top_libfredo6.rbe:171: in `open'
              1659777820.6217778;top_libfredo6.rbe:171: in `open'
              Curvizard 2.4b: Startup (creating menus and icons) [88 ms]
              1659777820.6301749;top_libfredo6.rbe:171: in `open'
              FredoCorner 2.5a: Effective Load - #5
              1659777820.6354005;top_libfredo6.rbe:171: in `open'
              FredoCorner 2.5a: Bootstrap Ruby files loaded [4 ms]
              1659777820.6419108;top_libfredo6.rbe:171: in `open'
              add Command Round
              1659777820.6434898;top_libfredo6.rbe:171: in `open'
              add Command Bevel
              1659777820.6449006;top_libfredo6.rbe:171: in `open'
              add Command SubDivision
              1659777820.6463234;top_libfredo6.rbe:171: in `open'
              add Command Chop Corner
              1659777820.6476603;top_libfredo6.rbe:171: in `open'
              add Command Repair
              1659777820.64898;top_libfredo6.rbe:171: in `open'
              add Command Purge all data
              1659777820.6499054;top_libfredo6.rbe:171: in `open'
              add Command Informazioni Fredo Corner v2.5a...
              1659777820.650826;top_libfredo6.rbe:171: in `open'
              1659777820.6517062;top_libfredo6.rbe:171: in `open'
              1659777820.6563776;top_libfredo6.rbe:171: in `open'
              1659777820.6572852;top_libfredo6.rbe:171: in `open'
              1659777820.6587155;top_libfredo6.rbe:171: in `open'
              1659777820.6596198;top_libfredo6.rbe:171: in `open'
              1659777820.6959202;top_libfredo6.rbe:171: in `open'
              FredoCorner 2.5a: Startup (creating menus and icons) [60 ms]
              1659777820.7102923;top_libfredo6.rbe:171: in `open'
              FredoScale 3.5a: Effective Load - #6
              1659777820.717813;top_libfredo6.rbe:171: in `open'
              FredoScale 3.5a: Bootstrap Ruby files loaded [6 ms]
              1659777820.7442555;top_libfredo6.rbe:171: in `open'
              1659777820.7465575;top_libfredo6.rbe:171: in `open'
              add Command Box Scalatura
              1659777820.7489302;top_libfredo6.rbe:171: in `open'
              add Command Box Scalatura verso Destinazione
              1659777820.7512124;top_libfredo6.rbe:171: in `open'
              add Command Box Inclinatura
              1659777820.753441;top_libfredo6.rbe:171: in `open'
              add Command Box Inclinatura verso Destinazione
              1659777820.7556183;top_libfredo6.rbe:171: in `open'
              add Command Box Shearing Planare
              1659777820.757817;top_libfredo6.rbe:171: in `open'
              add Command Box Shearing Planare verso Destinazione
              1659777820.7599664;top_libfredo6.rbe:171: in `open'
              add Command Shearing Planare (Libero)
              1659777820.7621584;top_libfredo6.rbe:171: in `open'
              add Command Box Stretching
              1659777820.764318;top_libfredo6.rbe:171: in `open'
              add Command Box Stretching verso Destinazione
              1659777820.7677734;top_libfredo6.rbe:171: in `open'
              add Command Box Twisting
              1659777820.7698052;top_libfredo6.rbe:171: in `open'
              add Command Box Rotazione
              1659777820.7717674;top_libfredo6.rbe:171: in `open'
              add Command Rotazione (Libero)
              1659777820.7737472;top_libfredo6.rbe:171: in `open'
              add Command Bending Radiale (Libero)
              1659777820.7757032;top_libfredo6.rbe:171: in `open'
              add Command Rendi Unico
              1659777820.778194;top_libfredo6.rbe:171: in `open'
              add Command Informazioni FredoScale v3.5a...
              1659777820.7792869;top_libfredo6.rbe:171: in `open'
              1659777820.780257;top_libfredo6.rbe:171: in `open'
              1659777820.7861962;top_libfredo6.rbe:171: in `open'
              1659777820.7871573;top_libfredo6.rbe:171: in `open'
              1659777820.788678;top_libfredo6.rbe:171: in `open'
              1659777820.7896168;top_libfredo6.rbe:171: in `open'
              1659777820.8383808;top_libfredo6.rbe:171: in `open'
              FredoScale 3.5a: Startup (creating menus and icons) [120 ms]
              1659777820.8477514;top_libfredo6.rbe:171: in `open'
              FredoSpline 2.3a: Effective Load - #7
              1659777820.8552005;top_libfredo6.rbe:171: in `open'
              FredoSpline 2.3a: Bootstrap Ruby files loaded [6 ms]
              1659777820.8683937;top_libfredo6.rbe:171: in `open'
              1659777820.8703284;top_libfredo6.rbe:171: in `open'
              add Command Create Curves
              1659777820.8719673;top_libfredo6.rbe:171: in `open'
              add Command Edit Curves
              1659777820.8735292;top_libfredo6.rbe:171: in `open'
              add Command Swap Curves
              1659777820.875027;top_libfredo6.rbe:171: in `open'
              add Command Convert Curves
              1659777820.8765285;top_libfredo6.rbe:171: in `open'
              add Command Purge data
              1659777820.8779967;top_libfredo6.rbe:171: in `open'
              add Command Purge All data
              1659777820.8795464;top_libfredo6.rbe:171: in `open'
              add Command Bezier Classic
              1659777820.8810525;top_libfredo6.rbe:171: in `open'
              add Command Bezier Nurbs
              1659777820.882643;top_libfredo6.rbe:171: in `open'
              add Command Local Fit Spline
              1659777820.8841708;top_libfredo6.rbe:171: in `open'
              add Command Global Fit Spline
              1659777820.8857195;top_libfredo6.rbe:171: in `open'
              add Command Polyline
              1659777820.88723;top_libfredo6.rbe:171: in `open'
              add Command Polyline Divider
              1659777820.8888128;top_libfredo6.rbe:171: in `open'
              add Command Polyline Segmentor
              1659777820.8903725;top_libfredo6.rbe:171: in `open'
              add Command Polycorner Generic
              1659777820.8918214;top_libfredo6.rbe:171: in `open'
              add Command Polycorner Arc
              1659777820.8934803;top_libfredo6.rbe:171: in `open'
              add Command Polycorner Squircle
              1659777820.894999;top_libfredo6.rbe:171: in `open'
              add Command Polycorner Bezier
              1659777820.8965273;top_libfredo6.rbe:171: in `open'
              add Command Polycorner Chamfer
              1659777820.898061;top_libfredo6.rbe:171: in `open'
              add Command Polycorner Dog-Bone
              1659777820.8996205;top_libfredo6.rbe:171: in `open'
              add Command Polycorner T-Bone
              1659777820.9011447;top_libfredo6.rbe:171: in `open'
              add Command Courbette
              1659777820.9026604;top_libfredo6.rbe:171: in `open'
              add Command Informazioni FredoSpline v2.3a...
              1659777820.9036179;top_libfredo6.rbe:171: in `open'
              1659777820.9045167;top_libfredo6.rbe:171: in `open'
              1659777820.908837;top_libfredo6.rbe:171: in `open'
              1659777820.909901;top_libfredo6.rbe:171: in `open'
              1659777820.9114738;top_libfredo6.rbe:171: in `open'
              1659777820.9123995;top_libfredo6.rbe:171: in `open'
              1659777820.9920552;top_libfredo6.rbe:171: in `open'
              FredoSpline 2.3a: Startup (creating menus and icons) [136 ms]
              1659777821.0018177;top_libfredo6.rbe:171: in `open'
              FredoTools 4.3a: Effective Load - #8
              1659777821.0720754;top_libfredo6.rbe:171: in `open'
              FredoTools 4.3a: Ruby files loaded [68 ms]
              1659777821.0804183;top_libfredo6.rbe:171: in `open'
              Lib6Material: Loading body code from body_Lib6Material [4 ms]
              1659777821.1087255;top_libfredo6.rbe:171: in `open'
              add Command >> FredoTools Launcher...
              1659777821.1106596;top_libfredo6.rbe:171: in `open'
              add Command Angle Inspector
              1659777821.1128163;top_libfredo6.rbe:171: in `open'
              add Command AutoReverseFaces
              1659777821.1148922;top_libfredo6.rbe:171: in `open'
              add Command Color by Altitude
              1659777821.1164553;top_libfredo6.rbe:171: in `open'
              add Command Color by Slope
              1659777821.1181555;top_libfredo6.rbe:171: in `open'
              add Command Color Flat Mode
              1659777821.119647;top_libfredo6.rbe:171: in `open'
              add Command Color Paint
              1659777821.1212366;top_libfredo6.rbe:171: in `open'
              add Command Construct Face Normals
              1659777821.1233282;top_libfredo6.rbe:171: in `open'
              add Command Convexify
              1659777821.1256363;top_libfredo6.rbe:171: in `open'
              add Command Count Faces by Sides
              1659777821.1277225;top_libfredo6.rbe:171: in `open'
              add Command CurviShear
              1659777821.12977;top_libfredo6.rbe:171: in `open'
              add Command Divide Edges
              1659777821.1318834;top_libfredo6.rbe:171: in `open'
              add Command Draw Along
              1659777821.1340015;top_libfredo6.rbe:171: in `open'
              add Command Edge Inspector
              1659777821.1360934;top_libfredo6.rbe:171: in `open'
              add Command Element Stats
              1659777821.138192;top_libfredo6.rbe:171: in `open'
              add Command FaceTriangulator
              1659777821.1404064;top_libfredo6.rbe:171: in `open'
              add Command Mark Vertices
              1659777821.1425476;top_libfredo6.rbe:171: in `open'
              add Command Move Along
              1659777821.1447155;top_libfredo6.rbe:171: in `open'
              add Command Remove Lonely Vertices
              1659777821.1468349;top_libfredo6.rbe:171: in `open'
              add Command Report on Areas
              1659777821.1483846;top_libfredo6.rbe:171: in `open'
              add Command Label with Areas
              1659777821.1504822;top_libfredo6.rbe:171: in `open'
              add Command ReverseOrientFaces
              1659777821.1522555;top_libfredo6.rbe:171: in `open'
              add Command Revert Curves
              1659777821.1544452;top_libfredo6.rbe:171: in `open'
              add Command Solid Volume
              1659777821.1567695;top_libfredo6.rbe:171: in `open'
              add Command ThruPaint
              1659777821.1585371;top_libfredo6.rbe:171: in `open'
              add Command Informazioni Fredo Tools v4.3a...
              1659777821.1728668;top_libfredo6.rbe:171: in `open'
              1659777821.1740627;top_libfredo6.rbe:171: in `open'
              1659777821.1757603;top_libfredo6.rbe:171: in `open'
              1659777821.1768177;top_libfredo6.rbe:171: in `open'
              1659777821.263448;top_libfredo6.rbe:171: in `open'
              FredoTools 4.3a: Startup (creating menus and icons) [190 ms]
              1659777821.2722695;top_libfredo6.rbe:171: in `open'
              HoverSelect 1.5a: Effective Load - #9
              1659777821.2924924;top_libfredo6.rbe:171: in `open'
              HoverSelect 1.5a: Ruby files loaded [18 ms]
              1659777821.297239;top_libfredo6.rbe:171: in `open'
              add Command Hover Select Edges
              1659777821.2992785;top_libfredo6.rbe:171: in `open'
              add Command Informazioni HoverSelect v1.5a...
              1659777821.3032396;top_libfredo6.rbe:171: in `open'
              1659777821.3041375;top_libfredo6.rbe:171: in `open'
              1659777821.3055997;top_libfredo6.rbe:171: in `open'
              1659777821.3064806;top_libfredo6.rbe:171: in `open'
              1659777821.3119593;top_libfredo6.rbe:171: in `open'
              HoverSelect 1.5a: Startup (creating menus and icons) [18 ms]
              1659777821.3206584;top_libfredo6.rbe:171: in `open'
              JointPushPull 4.4e: Effective Load - #10
              1659777821.3262935;top_libfredo6.rbe:171: in `open'
              JointPushPull 4.4e: Bootstrap Ruby files loaded [4 ms]
              1659777821.335673;top_libfredo6.rbe:171: in `open'
              1659777821.3376372;top_libfredo6.rbe:171: in `open'
              add Command Thickener
              1659777821.3393734;top_libfredo6.rbe:171: in `open'
              add Command Joint Push Pull
              1659777821.341129;top_libfredo6.rbe:171: in `open'
              add Command Round Push Pull
              1659777821.342861;top_libfredo6.rbe:171: in `open'
              add Command Vector Push Pull
              1659777821.344577;top_libfredo6.rbe:171: in `open'
              add Command Normal Push Pull
              1659777821.3462873;top_libfredo6.rbe:171: in `open'
              add Command Extrude Push Pull
              1659777821.3480852;top_libfredo6.rbe:171: in `open'
              add Command Follow Push Pull
              1659777821.3498316;top_libfredo6.rbe:171: in `open'
              add Command Informazioni JointPushPull v4.4e...
              1659777821.3507373;top_libfredo6.rbe:171: in `open'
              1659777821.3516152;top_libfredo6.rbe:171: in `open'
              1659777821.357344;top_libfredo6.rbe:171: in `open'
              1659777821.3597226;top_libfredo6.rbe:171: in `open'
              1659777821.3611848;top_libfredo6.rbe:171: in `open'
              1659777821.362069;top_libfredo6.rbe:171: in `open'
              1659777821.413224;top_libfredo6.rbe:171: in `open'
              JointPushPull 4.4e: Startup (creating menus and icons) [86 ms]
              1659777821.421949;top_libfredo6.rbe:171: in `open'
              MoveAlignMe 1.2a: Effective Load - #11
              1659777821.426346;top_libfredo6.rbe:171: in `open'
              MoveAlignMe 1.2a: Bootstrap Ruby files loaded [3 ms]
              1659777821.4303312;top_libfredo6.rbe:171: in `open'
              add Command Move - Pivot - Straighten
              1659777821.432269;top_libfredo6.rbe:171: in `open'
              add Command Move and Glue
              1659777821.4339776;top_libfredo6.rbe:171: in `open'
              add Command Informazioni MoveAlignMe v1.2a...
              1659777821.4389012;top_libfredo6.rbe:171: in `open'
              1659777821.439845;top_libfredo6.rbe:171: in `open'
              1659777821.4413064;top_libfredo6.rbe:171: in `open'
              1659777821.4421935;top_libfredo6.rbe:171: in `open'
              1659777821.4644544;top_libfredo6.rbe:171: in `open'
              MoveAlignMe 1.2a: Startup (creating menus and icons) [37 ms]
              1659777821.4756064;top_libfredo6.rbe:171: in `open'
              MrHide 1.6a: Effective Load - #12
              1659777821.4834373;top_libfredo6.rbe:171: in `open'
              MrHide 1.6a: Bootstrap Ruby files loaded [7 ms]
              1659777821.4958718;top_libfredo6.rbe:171: in `open'
              1659777821.4974673;top_libfredo6.rbe:171: in `open'
              add Command View Hidden Geometry
              1659777821.4989045;top_libfredo6.rbe:171: in `open'
              add Command View Hidden Objects
              1659777821.500291;top_libfredo6.rbe:171: in `open'
              add Command Draw Back Edges
              1659777821.501683;top_libfredo6.rbe:171: in `open'
              add Command View Axes
              1659777821.5035517;top_libfredo6.rbe:171: in `open'
              add Command View Component Axes
              1659777821.5050678;top_libfredo6.rbe:171: in `open'
              add Command View Guides
              1659777821.506527;top_libfredo6.rbe:171: in `open'
              add Command View Dimensions
              1659777821.5080168;top_libfredo6.rbe:171: in `open'
              add Command View Text Labels
              1659777821.5095255;top_libfredo6.rbe:171: in `open'
              add Command Display Shadows
              1659777821.5110574;top_libfredo6.rbe:171: in `open'
              add Command Display Sun shading
              1659777821.5125182;top_libfredo6.rbe:171: in `open'
              add Command View Fog
              1659777821.5139978;top_libfredo6.rbe:171: in `open'
              add Command View Ground
              1659777821.5154166;top_libfredo6.rbe:171: in `open'
              add Command View Sky
              1659777821.5169723;top_libfredo6.rbe:171: in `open'
              add Command Color by Tag
              1659777821.5185745;top_libfredo6.rbe:171: in `open'
              add Command Edge Visibility
              1659777821.5200028;top_libfredo6.rbe:171: in `open'
              add Command Edge Profiles
              1659777821.521416;top_libfredo6.rbe:171: in `open'
              add Command Draw Endpoints
              1659777821.522842;top_libfredo6.rbe:171: in `open'
              add Command Edge Color By Material
              1659777821.524244;top_libfredo6.rbe:171: in `open'
              add Command Edge Color By Axis
              1659777821.5256379;top_libfredo6.rbe:171: in `open'
              add Command Hide similar instances
              1659777821.5270412;top_libfredo6.rbe:171: in `open'
              add Command Hide Rest of the model
              1659777821.528457;top_libfredo6.rbe:171: in `open'
              add Command Informazioni MrHide v1.6a...
              1659777821.5332236;top_libfredo6.rbe:171: in `open'
              1659777821.5342171;top_libfredo6.rbe:171: in `open'
              1659777821.5356562;top_libfredo6.rbe:171: in `open'
              1659777821.5366085;top_libfredo6.rbe:171: in `open'
              1659777821.652451;top_libfredo6.rbe:171: in `open'
              MrHide 1.6a: Startup (creating menus and icons) [168 ms]
              1659777821.6611593;top_libfredo6.rbe:171: in `open'
              ToolsOnSurface 2.5a: Effective Load - #13
              1659777821.6690829;top_libfredo6.rbe:171: in `open'
              ToolsOnSurface 2.5a: Bootstrap Ruby files loaded [7 ms]
              1659777821.6850967;top_libfredo6.rbe:171: in `open'
              1659777821.687485;top_libfredo6.rbe:171: in `open'
              add Command Generic Tools on Surface
              1659777821.6888132;top_libfredo6.rbe:171: in `open'
              add Command Line on Surface
              1659777821.6902533;top_libfredo6.rbe:171: in `open'
              add Command Rectangle
              1659777821.6918726;top_libfredo6.rbe:171: in `open'
              add Command Circle
              1659777821.6935656;top_libfredo6.rbe:171: in `open'
              add Command Polygon
              1659777821.6957371;top_libfredo6.rbe:171: in `open'
              add Command Ellipse
              1659777821.6975596;top_libfredo6.rbe:171: in `open'
              add Command Parallelogram
              1659777821.6994553;top_libfredo6.rbe:171: in `open'
              add Command Arc
              1659777821.7012951;top_libfredo6.rbe:171: in `open'
              add Command Circle (3 Points)
              1659777821.7031078;top_libfredo6.rbe:171: in `open'
              add Command Sector (Pie)
              1659777821.7049463;top_libfredo6.rbe:171: in `open'
              add Command Offset on Surface
              1659777821.7067401;top_libfredo6.rbe:171: in `open'
              add Command Free Hand on Surface
              1659777821.7086666;top_libfredo6.rbe:171: in `open'
              add Command Edit Contours on Surface
              1659777821.7103713;top_libfredo6.rbe:171: in `open'
              add Command Eraser on Surface
              1659777821.7118523;top_libfredo6.rbe:171: in `open'
              add Command Informazioni Tools on Surface v2.5a...
              1659777821.712737;top_libfredo6.rbe:171: in `open'
              1659777821.7136042;top_libfredo6.rbe:171: in `open'
              1659777821.7186472;top_libfredo6.rbe:171: in `open'
              1659777821.7195928;top_libfredo6.rbe:171: in `open'
              1659777821.721014;top_libfredo6.rbe:171: in `open'
              1659777821.7218785;top_libfredo6.rbe:171: in `open'
              1659777821.8156009;top_libfredo6.rbe:171: in `open'
              ToolsOnSurface 2.5a: Startup (creating menus and icons) [146 ms]
              1659777821.8244748;top_libfredo6.rbe:171: in `open'
              VisuHole 1.4b: Effective Load - #14
              1659777821.8285341;top_libfredo6.rbe:171: in `open'
              VisuHole 1.4b: Bootstrap Ruby files loaded [3 ms]
              1659777821.8331802;top_libfredo6.rbe:171: in `open'
              add Command VisuHole: Stencil
              1659777821.8352547;top_libfredo6.rbe:171: in `open'
              add Command Informazioni VisuHole v1.4b...
              1659777821.836168;top_libfredo6.rbe:171: in `open'
              1659777821.8370469;top_libfredo6.rbe:171: in `open'
              1659777821.8414953;top_libfredo6.rbe:171: in `open'
              1659777821.8425024;top_libfredo6.rbe:171: in `open'
              1659777821.8439815;top_libfredo6.rbe:171: in `open'
              1659777821.8448694;top_libfredo6.rbe:171: in `open'
              1659777821.856961;top_libfredo6.rbe:171: in `open'
              VisuHole 1.4b: Startup (creating menus and icons) [27 ms]
              1659777848.5419104;top_libfredo6.rbe:171: in `open'
              LibFredo6: End of loading Cycle***-
              1659777848.655718;top_libfredo6.rbe:171: in `open'
              Lib6ColorSpecDialog: Loading body code from body_Lib6ColorSpecDialog [8 ms] status = true
              1659777848.6649866;top_libfredo6.rbe:171: in `open'
              Lib6Onglets: Loading body code from body_Lib6Onglets [8 ms] status = true
              1659777848.666665;top_libfredo6.rbe:171: in `open'
              Lib6ColorScale: Loading body code from body_Lib6ColorScale [29 ms] status = true
              1659777848.7103868;top_libfredo6.rbe:171: in `open'
              LordOfTheToolbars 2.2a: Ruby files loaded [165 ms]
              1659777848.7280338;top_libfredo6.rbe:171: in `open'
              Lib6_txtmsg: Loading body code from body_Lib6_txtmsg [16 ms] status = true
              1659777848.7825856;top_libfredo6.rbe:171: in `open'
              Lib6G6: Loading body code from body_Lib6G6 [53 ms] status = true
              1659777848.7919383;top_libfredo6.rbe:171: in `open'
              LibFredo6: Loaded Binary C:/Users/robo/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU22/bin_body_Lib6G6.so
              1659777848.8168008;top_libfredo6.rbe:171: in `open'
              Lib6Tool: Loading body code from body_Lib6Tool [16 ms] status = true
              1659777848.8180127;top_libfredo6.rbe:171: in `open'
              Lib6Translate: Loading body code from body_Lib6Translate [25 ms] status = true
              1659777848.8472762;top_libfredo6.rbe:171: in `open'
              Lib6RoundingProfiler: Loading body code from body_Lib6RoundingProfiler [15 ms] status = true
              1659777848.8485556;top_libfredo6.rbe:171: in `open'
              Lib6Spline: Loading body code from body_Lib6Spline [29 ms] status = true
              1659777848.859474;top_libfredo6.rbe:171: in `open'
              Lib6WebHtml: Loading body code from body_Lib6WebHtml [10 ms] status = true
              1659777848.8691103;top_libfredo6.rbe:171: in `open'
              Lib6Algo: Loading body code from body_Lib6Algo [8 ms] status = true
              1659777848.8792436;top_libfredo6.rbe:171: in `open'
              Lib6Contour: Loading body code from body_Lib6Contour [9 ms] status = true
              1659777848.8860703;top_libfredo6.rbe:171: in `open'
              Lib6Offset3d: Loading body code from body_Lib6Offset3d [5 ms] status = true
              1659777848.8964381;top_libfredo6.rbe:171: in `open'
              Lib6Transform: Loading body code from body_Lib6Transform [9 ms] status = true
              1659777848.9045694;top_libfredo6.rbe:171: in `open'
              Lib6Mark: Loading body code from body_Lib6Mark [7 ms] status = true
              1659777848.9104576;top_libfredo6.rbe:171: in `open'
              Lib6Vault: Loading body code from body_Lib6Vault [5 ms]
              1659777848.916615;top_libfredo6.rbe:171: in `open'
              Lib6Marshall: Loading body code from body_Lib6Marshall [5 ms]
              1659777848.9322221;top_libfredo6.rbe:171: in `open'
              Lib6CompManager: Loading body code from body_Lib6CompManager [15 ms]
              1659777848.9460337;top_libfredo6.rbe:171: in `open'
              Lib6PathManager: Loading body code from body_Lib6PathManager [13 ms]
              1659777848.9552493;top_libfredo6.rbe:171: in `open'
              Lib6Shortcuts: Loading body code from body_Lib6Shortcuts [7 ms]
              1659777848.9626634;top_libfredo6.rbe:171: in `open'
              Lib6MonoFactory: Loading body code from body_Lib6MonoFactory [6 ms]
              1659777850.701963;top_libfredo6.rbe:171: in `open'
              Lib6NativeManager: Loading body code from body_Lib6NativeManager [13 ms]
              1659777916.0953088;top_libfredo6.rbe:171: in `open'
              Lib6ChromiumJS: Loading body code from body_Lib6ChromiumJS [4 ms]
              1659777916.1139123;top_libfredo6.rbe:171: in `open'
              Lib6ChromiumWdlg: Loading body code from body_Lib6ChromiumWdlg [17 ms]
              1659779297.9428368;top_libfredo6.rbe:171: in `open'
              Lib6Variator: Loading body code from body_Lib6Variator [6 ms] status = true
              1659779298.0459197;top_libfredo6.rbe:171: in `open'
              FredoSpline 2.3a: Ruby files loaded [120 ms]
              1659779348.9734035;top_libfredo6.rbe:171: in `open'
              Lib6PluginDialogs: Loading body code from body_Lib6PluginDialogs [10 ms]
              1659779348.9823189;top_libfredo6.rbe:171: in `open'
              Lib6WebXTable: Loading body code from body_Lib6WebXTable [7 ms]
              • fredo6F
                By chance, do you have Universal Importer installed or any other plugins by samuel_t?
                If so, there is an incompatibility with LOTT, I am afraid, until Samuel updates his plugins.
                • alexpacio2013A
                  alexpacio2013
                  Thanks, I solved it by uninstalling Universal Importer. Always punctual and precise. Without Fredo6 I would not be able to use Sketchup. 🀣
                  • samuel_tS
                    samuel_t
                    Hello there, Universal Importer plugin v1.1.8 is compatible with Lord Of The Toolbars plugin v2.2a πŸ˜‰
                    • L
                      lionk
                      Hello fredo. Found an issue. If I set a palette shortcut to c, for example, when some plugins need VCB input, once I type c, this palette will popup untimely.
                      • cmeedC
                        cmeed
                        Hi Fredo,
                        I have whole heartly enbraced LOTT! It is exactly what I need to clean up my place of work!
                        The Vinette strip is incredibly fast as you hover over, which is exactly what it needs to be. I wonder possibly if there could a way of spacing out the icons / bigger area to hover over as when in the speed of the moment you can easily brush over the adjacent icon
                        Maybe a separator would work like the pallettes have
                        or
                        Bigger wider version of each icon? (I have small su icons enabled to save valuable space and i think that should still be on - what do you think?)
                        or
                        A Separate icon that act as a Vinette for each pallette you need and you can float or add to tool bar?
                        what do you think?
                        Cheers
                        and Thanks Again
                        • fredo6F
                          You can click on the first 'dotted' button and choose menu (size of Vignettes). You can make them bigger or smaller.
                          • cmeedC
                            cmeed
                            OOOOH!!
                              AISmebel
                              Hello fredo. I have broken icons of plugins and scripts for which I used my pictures. Can they be restored somehow? I don't know how it happened ((
                              I do restore toolbars but does not help. All the pictures that I used are in place.
                              • H
                                haymaker
                                Hey Fredo.
                                I just brought your bundle and made a donation for all the great work you do. Before I install it I thought I would re arrange some of my LOTT pallets first. I have been using LOTT for a while now and love it, however the new pallets I have created will not disappear after I pick a tool or click outside of the pallet, or even if I press escape.. I have to either double click on the top of the pallet or click the red X to get them to close. Some, but not all of my older pallets continue to work fine and they close by themselves once I have clicked the icon for the tool I want to use. I have scrolled through the 'Default parameters' window but cant see if I am missing something or is this a bug. I have saved settings and closed and restarted SU but that did not help,
                                Any assistance you can offer would be greatly appreciated, I would like to resolve this issue before I install the bundle encase I have any other issues.
                                Could this be an issue with libFredo6 as this is the most recent update?
                                I have attached a screen shot, shortcuts A, B, D and X are the ones that are not working, A B and X are new, D is an old one that is also not working.
                                SU2022
                                LOTT v2.2a
                                Libfredo6 13.2a Last updated on the 16 sep 22
                                Windows 11
                                Thanks for your help
                                Mike
                                Screenshot
                                • fredo6F
                                  @haymaker,
                                  Could you open the Ruby Console before trying to close a palette, in case there is an error message displayed.
                                  For shortcuts, I would suggest you do not select letters that are used by Sketchup native tools (such as A, B, D and X).
                                  • H
                                    haymaker
                                    Hey Fredo
                                    I have changed a shortcut key to SHIFT H but problem persists.
                                    I opened the Ruby console and got no message when closing a pallet but I did get the attached message on start up of sketchup.
                                    It means nothing to me, hopefully you can understand it.
                                    Mike
                                    • H
                                      haymaker
                                      I have cleaned out a few unused shortcut keys. There are now just 5 shortcuts for LOTT, and I noticed that the four that are not working properly also don't show up in the 'menu' window as shown by the screen shot. The only pallet that shows up in the orange custom shortcuts and the menu window is "Often used" and that was created a long time ago. the other 4 pallets and shortcuts were created yesterday and are the ones causing issues
                                      Cheers
                                      • fredo6F
                                        1. The warning in the console is for TTLib. It is harmless and not related to LOTT.
                                        2. I cannot reproduce the problem with shortcuts. In my environment, I can just define them and they work.
                                        Do you have the latest version of LibFredo6 and LOTT installed?
                                        • H
                                          haymaker
                                          I have version 13.2a and 2.2a installed and when I check using your 'check for updates everything is green and up to date. I will uninstall both Library and LOTT and reinstall them. see if that works.
                                          Will let you know. Thanks
                                            How are you checking? The current version of LibFredo6 is 13.4a.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 27
                                            • 28
                                            • 12 / 28
