    Curviloft and sketchup 2024 problem
    42 Posts 7 Posters 3.4k Views 6 Watching
    • fredo6F Offline
      fredo6 @alexpacio2013
      @alexpacio2013
      There seems to be a problem with VRay, which prevents Curviloft to perform its task. Actually, the problem is not in VRay itself, but in VRay and your model or your model state.
      Could you temporarily disable VRay and see if it improves.
      BoxB alexpacio2013A 2 Replies Last reply Reply Quote 0
      • BoxB Offline
        Box @fredo6
        @fredo6
        I get the same issue, no vray and nothing showing in the console.
        alexpacio2013A 1 Reply Last reply Reply Quote 0
        • alexpacio2013A Offline
          alexpacio2013 @fredo6
          @fredo6 I tried to disable I would say. But it doesn't work anyway. I also tried on my notebook, where there is no vray, with Su 2024. Same problem?
            alexpacio2013 @Box
            @Box said in Curviloft and sketchup 2024 problem:
            @fredo6
            So it's not just happening to me.
            fredo6F 1 Reply Last reply Reply Quote 0
            • fredo6F Offline
              @alexpacio2013
              Can you post the model.
              fredo6F alexpacio2013A 2 Replies Last reply Reply Quote 0
              • fredo6F Offline
                fredo6 @fredo6
                @fredo6
                By the way, what happens if you change the method
                  @fredo6
                  It doesn't work with this other method either, however I reiterate that the same file opened with sketchup 2022 works perfectly
                    @fredo6 said in Curviloft and sketchup 2024 problem:
                    @alexpacio2013
                    [link text](https://drive.google.com/file/d/1cbnbdHsSEJ4AlkYzZvHRbdpX_B4wBMjf/view?usp=Try my test file with 2 examples.)
                      @fredo6
                      I did a new test in my notebook and deleted the sketchup plugin folder. When I restarted sketchup recreated the empty plugin folder, I reinstalled the fredolib and curviloft libraries without installing any other plugins and the problem remains. It is not a conflict with other plugins
                      • fredo6F Offline
                        @alexpacio2013
                        Do not waste time to resinstall.
                        This seems to be a problem in Curviloft, which very strangely is prsent in SU2023 and SU2024 and was never signaled.
                        I have to investigate....
                          @fredo6
                          I don't want to alarm you but I'm telling you that there is also a problem with Fredo corner which in the 2024 version behaves in a very strange way, look at the differences between 2022 and 2024.
                          Those at Trimble definitely don't give you a hand but without your plugins I can't work with sketchupSketchUp_SmWdeB0kCV.jpg
                          • fredo6F Offline
                            @alexpacio2013
                            Many thanks for signaling these problems.
                            Definitely, SU2023 / SU2024 have introduced a change that is impacting some algorithms.
                            Would you mind to send me the model for FredoCorner.
                              @fredo6
                              do you have a private email to give me, or can I put the files on googledrive for you?
                              My email is roberto. bolletta[@]gmail. com
                                alexpacio2013
                                This post is deleted!
                                  alexpacio2013
                                  files skp
                                    alexpacio2013
                                    link files
                                    • alexpacio2013A alexpacio2013 deleted this topic on
                                    • alexpacio2013A alexpacio2013 restored this topic on
                                    • fredo6F Offline
                                      The issue should be fixed with LibFredo6 v14.4a, just published.
                                      alexpacio2013A 4 Replies Last reply Reply Quote 0
                                        @fredo6
                                        Now there is no longer the error that prevented us from moving forward but the result is wrong look at the result 2024 is deformed, it is not correct, while with 2022 the object is perfectly formed
                                          alexpacio2013 @alexpacio2013
                                            @fredo6
                                            For information I tried to insert the squares perpendicular to each node manually and then instead of using the follow me I used And as you can see the finished shape is correct so it is an axis problem at each node. Always with su 2024 and the library you updated
                                            • 1 / 3
