    Curviloft and sketchup 2024 problem
    42 Posts 7 Posters 5.5k Views 6 Watching
    • alexpacio2013A
      alexpacio2013 @fredo6
      @fredo6
      In the images you see what happens with sketchup 2024. The same file inserted on sketchup 2022 works perfectly, with the same version of curviloft and Lib.2024-05-08 14-27-hd.jpg 2024-05-08 14-27-hd2.jpg 2024-05-08 14-27-hd3.jpg 2024-05-08 14-27-hd4.jpg
      • fredo6F
        fredo6 @alexpacio2013
        @alexpacio2013
        There seems to be a problem with VRay, which prevents Curviloft to perform its task. Actually, the problem is not in VRay itself, but in VRay and your model or your model state.
        Could you temporarily disable VRay and see if it improves.
        BoxB alexpacio2013A 2 Replies Last reply
        • BoxB
          Box @fredo6
          @fredo6
          I get the same issue, no vray and nothing showing in the console.
          alexpacio2013A 1 Reply Last reply
          • alexpacio2013A
            @fredo6 I tried to disable I would say. But it doesn't work anyway. I also tried on my notebook, where there is no vray, with Su 2024. Same problem?
            • alexpacio2013A
              alexpacio2013 @Box
              @Box said in Curviloft and sketchup 2024 problem:
              @fredo6
              So it's not just happening to me.
              fredo6F 1 Reply Last reply
              • fredo6F
                @alexpacio2013
                Can you post the model.
                fredo6F alexpacio2013A 2 Replies Last reply
                • fredo6F
                  fredo6 @fredo6
                  @fredo6
                  By the way, what happens if you change the method
                  • alexpacio2013A
                    @fredo6
                    It doesn't work with this other method either, however I reiterate that the same file opened with sketchup 2022 works perfectly
                    • alexpacio2013A
                      @fredo6 said in Curviloft and sketchup 2024 problem:
                      @alexpacio2013
                      [link text](https://drive.google.com/file/d/1cbnbdHsSEJ4AlkYzZvHRbdpX_B4wBMjf/view?usp=Try my test file with 2 examples.)
                      • alexpacio2013A
                        @fredo6
                        I did a new test in my notebook and deleted the sketchup plugin folder. When I restarted sketchup recreated the empty plugin folder, I reinstalled the fredolib and curviloft libraries without installing any other plugins and the problem remains. It is not a conflict with other plugins
                        • fredo6F
                          @alexpacio2013
                          Do not waste time to resinstall.
                          This seems to be a problem in Curviloft, which very strangely is prsent in SU2023 and SU2024 and was never signaled.
                          I have to investigate....
                          • alexpacio2013A
                            @fredo6
                            I don't want to alarm you but I'm telling you that there is also a problem with Fredo corner which in the 2024 version behaves in a very strange way, look at the differences between 2022 and 2024.
                            Those at Trimble definitely don't give you a hand but without your plugins I can't work with sketchupSketchUp_SmWdeB0kCV.jpg
                            • fredo6F
                              @alexpacio2013
                              Many thanks for signaling these problems.
                              Definitely, SU2023 / SU2024 have introduced a change that is impacting some algorithms.
                              Would you mind to send me the model for FredoCorner.
                              • alexpacio2013A
                                @fredo6
                                do you have a private email to give me, or can I put the files on googledrive for you?
                                My email is roberto. bolletta[@]gmail. com
                                • alexpacio2013A
                                  alexpacio2013
                                  This post is deleted!
                                  • alexpacio2013A
                                    alexpacio2013
                                    files skp
                                    • alexpacio2013A
                                      alexpacio2013
                                      link files
                                      • alexpacio2013A alexpacio2013 deleted this topic on
                                      • alexpacio2013A alexpacio2013 restored this topic on
                                      • fredo6F
                                        The issue should be fixed with LibFredo6 v14.4a, just published.
                                        alexpacio2013A 4 Replies Last reply
                                        • alexpacio2013A
                                          @fredo6
                                          Now there is no longer the error that prevented us from moving forward but the result is wrong look at the result 2024 is deformed, it is not correct, while with 2022 the object is perfectly formed
                                          • alexpacio2013A
                                            alexpacio2013 @alexpacio2013
                                            • 1 / 3
