    Curviloft and sketchup 2024 problem
    42 Posts 7 Posters 6.7k Views 6 Watching
      Dave R @alexpacio2013
      @alexpacio2013 I don't know why Curviloft is behaving differently with that but I wouldn't have thought to use Curviloft. The native Follow Me would handle that just fine.
      alexpacio2013A 1 Reply Last reply
      • fredo6F
        fredo6 @alexpacio2013
        @alexpacio2013
        Can you open the Ruby Console before launching Curviloft to check if there are errors.
        alexpacio2013A 2 Replies Last reply
        • alexpacio2013A
          alexpacio2013 @fredo6
          @fredo6
          Content.
          Error: #<TypeError: reference to deleted ComponentDefinition>
          C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/observers/definition_observer.rbc:8:in instances' C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/observers/definition_observer.rbc:8:in initialize'
          C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/observers/definitions_observer.rbc:20:in new' C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/observers/definitions_observer.rbc:20:in onComponentAdded'
          c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:197:in abort_operation' c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:197:in abort_operation'
          c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:353:in `deactivate'
          fredo6F 1 Reply Last reply
          • alexpacio2013A
            alexpacio2013 @Dave R
            @Dave-R said in Curviloft and sketchup 2024 problem:
            To work correctly with subd, the native sketchup followme command is not functional, you necessarily need the exceptional Fredo Curviloft.
            • alexpacio2013A
              @fredo6
              In the images you see what happens with sketchup 2024. The same file inserted on sketchup 2022 works perfectly, with the same version of curviloft and Lib.2024-05-08 14-27-hd.jpg 2024-05-08 14-27-hd2.jpg 2024-05-08 14-27-hd3.jpg 2024-05-08 14-27-hd4.jpg
              • fredo6F
                @alexpacio2013
                There seems to be a problem with VRay, which prevents Curviloft to perform its task. Actually, the problem is not in VRay itself, but in VRay and your model or your model state.
                Could you temporarily disable VRay and see if it improves.
                BoxB alexpacio2013A 2 Replies Last reply
                • BoxB
                  Box @fredo6
                  @fredo6
                  I get the same issue, no vray and nothing showing in the console.
                  • alexpacio2013A
                    @fredo6 I tried to disable I would say. But it doesn't work anyway. I also tried on my notebook, where there is no vray, with Su 2024. Same problem?
                    • alexpacio2013A
                      alexpacio2013 @Box
                      @Box said in Curviloft and sketchup 2024 problem:
                      @fredo6
                      So it's not just happening to me.
                      • fredo6F
                        @alexpacio2013
                        Can you post the model.
                        fredo6F alexpacio2013A 2 Replies Last reply
                        • fredo6F
                          fredo6 @fredo6
                          @fredo6
                          By the way, what happens if you change the method
                          • alexpacio2013A
                            @fredo6
                            It doesn't work with this other method either, however I reiterate that the same file opened with sketchup 2022 works perfectly
                            • alexpacio2013A
                              @fredo6 said in Curviloft and sketchup 2024 problem:
                              @alexpacio2013
                              [link text](https://drive.google.com/file/d/1cbnbdHsSEJ4AlkYzZvHRbdpX_B4wBMjf/view?usp=Try my test file with 2 examples.)
                              • alexpacio2013A
                                @fredo6
                                I did a new test in my notebook and deleted the sketchup plugin folder. When I restarted sketchup recreated the empty plugin folder, I reinstalled the fredolib and curviloft libraries without installing any other plugins and the problem remains. It is not a conflict with other plugins
                                • fredo6F
                                  @alexpacio2013
                                  Do not waste time to resinstall.
                                  This seems to be a problem in Curviloft, which very strangely is prsent in SU2023 and SU2024 and was never signaled.
                                  I have to investigate....
                                  • alexpacio2013A
                                    @fredo6
                                    I don't want to alarm you but I'm telling you that there is also a problem with Fredo corner which in the 2024 version behaves in a very strange way, look at the differences between 2022 and 2024.
                                    Those at Trimble definitely don't give you a hand but without your plugins I can't work with sketchupSketchUp_SmWdeB0kCV.jpg
                                    • fredo6F
                                      @alexpacio2013
                                      Many thanks for signaling these problems.
                                      Definitely, SU2023 / SU2024 have introduced a change that is impacting some algorithms.
                                      Would you mind to send me the model for FredoCorner.
                                      • alexpacio2013A
                                        @fredo6
                                        do you have a private email to give me, or can I put the files on googledrive for you?
                                        My email is roberto. bolletta[@]gmail. com
                                        • alexpacio2013A
                                          alexpacio2013
                                          This post is deleted!
                                          • alexpacio2013A
                                            alexpacio2013
                                            files skp
                                            • 1 / 3
