Sketchucation Tools 4.4.1
Thank you. I have the plugins ive downloaded working. when i read the activation instructions before i didnt see that there was more than one page as I can see on your link. Thats probably me!!!!
Im still getting a blank page on the red button inside the Extension store Window in Skecthup. Not causing me a problem but before I updated to V4.4 i had a list of plugins showing.
@ricky2468 said in Sketchucation Tools 4.4.0:
That's could be a cache issue. If you clear your Microsoft Edge Cookies does it load?
@Rich-O-Brien
With an HtmlDialog SketchUp caches its 'chromium' stuff somewhere like here:
C:\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2024\WebCache-112.0.5615.165
I don't know what's in it or how to clear it ! -
I cleared the cookies and reloaded sketchup but still nothing showing
@TIG Ive
I found this. Im using skecthup 2018 but it has dolders for verions of skecthup from 2017 to 2023. I expect 2017 was the first vesion I used on this pc.
Looking in the 2018 folder there are three other folders inside WebCache. They are Cache, Dictionaries and GPUCache. Plus some some other files, Cookies 7KB; Cookies - journal 0KB; debug.log 568KB txt doc and visited links 128KB. -
I am trying to understand the managing of sets. If I have the steps right:
Start store extension
Use the blue button
disable extensions
select the sets menu
provide name
click the add button
At this point I expect the name I added to populate the list box
Any Ideas???
Thx Dave -
@RLGL It looks to be broken in 4.4 but I need to test further to see how broken. Thanks for heads up.
Hi everyone,
I'm running into a similar situation where the plugin store extension is properly installed but when I click on the extensionstore, the dialogue box opens but nothing shows up.
Ruby Console doesn't show anything when I open the extension as well. I have tried the full access adjustment, restarting sketchup, etc. and nothing helps.Is there a site that I'm supposed to unblock with my organization? I do see a sonic wall error when I open the plugin manager. Extensions manager works fine and shows all installed extensions with no errors.
I'm running 2024 SketchUP.
@sungeric said in Sketchucation Tools 4.4.0:
I think you've found the source of the issue with the Sonic Wall software.
You need to get
*.sketchucation.com
whitelisted -
v4.4.1 - Plugin/Extension Manager bugfixes
Extension Manager Load Temp functionality has been removed as Extension's Manager Temp-load is 'blocked' by the sketchup API
Greetings,
I have a strange issue with this extension.
Simply cannot activate via the extension via this one.
Skin extension returns itself to the right part of the Sketchucation Tools window (as Disabled - see attached image)Thank you in advance for any piece of advice!
I'm getting an error on a dozen plus plugins when trying to install in SU 2024 on my 2016 Macbook Pro saying that the file could not be unzipped. Didn't have this problem on 2023 with this machine, or with 2024 on a new M1 Max Macbook Pro. Any ideas?
If you try and load it using the native Extension Manager [and restart] what happens ?
@TIG Looks like my mistake. Without checking carefully, I thought the last version I had downloaded was current, but apparently, it was 4.3.1 and that was causing the problem. Now that 4.4.1 is installed it's working OK.
I must say, the new version seems laggy. We'll see.
download page still says 'Latest is 4.4.0 '
@Rich-O-Brien
Hi Rich,
minor thing; the download page still says Latest is 4.4.0 -
@mariocha said in Sketchucation Tools 4.4.1:
@Rich-O-Brien
Hi Rich,
minor thing; the download page still says Latest is 4.4.0Sorted now...good find
