    Upgraded PC but now can't export
    17 Posts 3 Posters 1.3k Views 3 Watching
      TIG Moderator @grizzler
      @grizzler You can download a suitable installer, up to 3 versions backwards, for your Computer from here...
      https://help.sketchup.com/en/downloading-sketchup
      If you are running an even older version then there are some sites with archived downloads that we could point you to...
      You don't need to uninstall SketchUp - just Repair it...
      grizzlerG 1 Reply Last reply Reply Quote 0
      • grizzlerG Offline
        grizzler @TIG
        @TIG said in Upgraded PC but now can't export:
        I've done as you suggested, run the 'repair' as an admin and then restarted my PC. Firstly I opened an old project that I migrated from my previous PC and that exported - it was very slow considering my new PC is 10 times better than my old one, but it did it. Then I tried on the new project created entirely on my new PC and the same issue came up as before. Does that give you any clues as to what it might be?
        TIGT 1 Reply Last reply Reply Quote 0
          @grizzler Have you also tried adjusting the Layout settings as @Dave-R Dave suggested ?
          • grizzlerG Offline
            grizzler @TIG
            Output Override was already unchecked by default
            • grizzlerG Offline
              grizzler @grizzler
              @grizzler There's another issue I've just realised too, if I open a layout file from my old PC to save as a revised version of a project, it won't let me relink to the newer file version. I'm having a bit of a nightmare with this 🫀
              • grizzlerG Offline
                grizzler @grizzler
                @grizzler Could any of this be caused by my programs being located on one SSD and my project files being on another? I can't imagine that's the problem but I'm desperately clutching at straws now.
                  @grizzler Let's get @Dave-R [re]involved, he's better at Layout than me...
                  • grizzlerG Offline
                    grizzler @TIG
                    Consider the buck passed 🀣, unlucky @Dave-R , Tig has drawn the short straw for you 😁
                      Dave R @grizzler
                      @grizzler where are you trying to export the file, to?
                      @grizzler said in Upgraded PC but now can't export:
                      Not likely. All of my LayOut files are kept on the second drive in my computer while the applications are on the πŸ˜„ drive.
                      Perhaps sharing the LO file would show us something.
                      Can you start a new LO file using one of the supplied templates. Just open it and immediately export a PDF. Does that work?
                      • grizzlerG Offline
                        grizzler @Dave R
                        @Dave-R I don't want to get too carried away with excitement, but I might have inadvertently fixed it (one trial pdf so far and it was fine), all I did was set Sketchup to use my Nvidia GPU rather than 'let windows decide' which seems to choose the weedy little native Intel GPU by default for some daft reason.
                          @grizzler Doh!
                          SketchUp should always be set to use your best Graphics Card - NVIDIA is regarded as one of the best !
                          At least we got a solution !
                          • grizzlerG Offline
                            grizzler @TIG
                            @TIG Thanks for your collective wisdom folks, your efforts are appreciated.
