    Upgraded PC but now can't export
    17 Posts 3 Posters 958 Views 3 Watching
    • TIGT Online
      TIG Moderator @grizzler
      @grizzler When you [re]installed SketchUp/Layout did you do it properly.
      If not then you can repair it without affecting anything you've got set up.
      Close SketchUp/Layout.
      Find the SketchUp installer's exe file - usually in your Downloads folder.
      Select the exe file's icon, right-click > context-menu > "Run as administrator"
      When prompted choose "Repair".
      When it completes restart your computer and see is SketchUp/Layout now works as you expect...
      Running a complex app's installer's exe file by double-clicking it to 'Run' it is not the same thing, even if you have admin powers.
      grizzlerG 1 Reply Last reply Reply Quote 1
      • grizzlerG Offline
        grizzler @Dave R
        @Dave-R said in Upgraded PC but now can't export:
        @grizzler what version of SketchUp/LayOut are you using? If it's 2023 try unticking the Override box in Document Setup>Rendering and then export.
        Where are you exporting the file to? Is it a cloud location?
        Yes I'm on the latest version and the box was already unticked by default
        • grizzlerG Offline
          grizzler @TIG
          @TIG said in Upgraded PC but now can't export:
          Argh! In a bid to keep my PC as fast and efficient as possible, I delete all unnecessary files so I no longer have the installation file. I've just tried to 'repair' in the control panel of windows but it's not an option and there doesn't seem to be the option to repair or re-download the file if I log into my account online either. Any suggestions please? I really don't want to have to re-install Sketchup too as it's a real pain setting it back up exactly as I like it.
          TIGT 1 Reply Last reply Reply Quote 0
          • TIGT Online
            @grizzler You can download a suitable installer, up to 3 versions backwards, for your Computer from here...
            https://help.sketchup.com/en/downloading-sketchup
            If you are running an even older version then there are some sites with archived downloads that we could point you to...
            You don't need to uninstall SketchUp - just Repair it...
            grizzlerG 1 Reply Last reply Reply Quote 0
            • grizzlerG Offline
              grizzler @TIG
              I've done as you suggested, run the 'repair' as an admin and then restarted my PC. Firstly I opened an old project that I migrated from my previous PC and that exported - it was very slow considering my new PC is 10 times better than my old one, but it did it. Then I tried on the new project created entirely on my new PC and the same issue came up as before. Does that give you any clues as to what it might be?
              • TIGT Online
                @grizzler Have you also tried adjusting the Layout settings as @Dave-R Dave suggested ?
                • grizzlerG Offline
                  grizzler @TIG
                  Output Override was already unchecked by default
                  • grizzlerG Offline
                    grizzler @grizzler
                    @grizzler There's another issue I've just realised too, if I open a layout file from my old PC to save as a revised version of a project, it won't let me relink to the newer file version. I'm having a bit of a nightmare with this 🫀
                    • grizzlerG Offline
                      grizzler @grizzler
                      @grizzler Could any of this be caused by my programs being located on one SSD and my project files being on another? I can't imagine that's the problem but I'm desperately clutching at straws now.
                      • TIGT Online
                        @grizzler Let's get @Dave-R [re]involved, he's better at Layout than me...
                        • grizzlerG Offline
                          grizzler @TIG
                          Consider the buck passed 🀣, unlucky @Dave-R , Tig has drawn the short straw for you 😁
                            Dave R @grizzler
                            @grizzler where are you trying to export the file, to?
                            @grizzler said in Upgraded PC but now can't export:
                            Not likely. All of my LayOut files are kept on the second drive in my computer while the applications are on the πŸ˜„ drive.
                            Perhaps sharing the LO file would show us something.
                            Can you start a new LO file using one of the supplied templates. Just open it and immediately export a PDF. Does that work?
                            • grizzlerG Offline
                              grizzler @Dave R
                              @Dave-R I don't want to get too carried away with excitement, but I might have inadvertently fixed it (one trial pdf so far and it was fine), all I did was set Sketchup to use my Nvidia GPU rather than 'let windows decide' which seems to choose the weedy little native Intel GPU by default for some daft reason.
                              • TIGT Online
                                @grizzler Doh!
                                SketchUp should always be set to use your best Graphics Card - NVIDIA is regarded as one of the best !
                                At least we got a solution !
                                • grizzlerG Offline
                                  grizzler @TIG
                                  @TIG Thanks for your collective wisdom folks, your efforts are appreciated.
