    RayScaper
    rayscaper
    86 Posts 9 Posters 17.6k Views 8 Watching
      Rich O Brien Moderator @pixelcruncher
      @pixelcruncher The issue without still have the plane in SketchUp would be it blocking your view.
      Your point and directional components are great because they are not intrusive. So a similar setup to that would be perfect....
      • pixelcruncherP
        pixelcruncher Extension Creator @Rich O Brien
        Thanks for explaining, will put it on my features list.
        majidM 1 Reply Last reply
        • majidM
          majid @pixelcruncher
          The other day I was plating with "Plastic" shader and here are some of the images.
          The engine material settings seem promising as even in very dark hues you can see the color.
          ntxdaveN majidM 2 Replies Last reply
          • ntxdaveN
            ntxdave @majid
            @majid πŸ‘ πŸ‘
            That looks good. Wish I could do some testing as well.
            Press F1...thank me later
            • majidM
              majid @majid
              @ntxdave Do you mind checking if this link works, please?
              https://3dwarehouse.sketchup.com/model/70a9083d-d1d9-464c-aea8-69895402c4ef/RayScraper-material-test-scene-Unofficial
              ntxdaveN 2 Replies Last reply
              • ntxdaveN
                ntxdave @majid
                @majid
                I meant, wish I could try RayScaper. 😞
                • ntxdaveN
                  ntxdave @majid
                  @majid
                  I meant, I wish I could try RayScaper. I am running SU 2020 😞
                  Reply Quote -1
                  • pixelcruncherP
                    @majid Thanks for sharing those material experiments. They look very realistic.
                    I'm making the Rayscaper material editor more intuitive and less nested so that users won't be daunted by all the material settings. @Rich-O-Brien gave me some great feedback on this. This update should land this week.
                    Cheers,
                    Thomas
                    • majidM
                      majid @ntxdave
                      @ntxdave So, RS does not work on prior versions?
                      @pixelcruncher Good news and progress!
                      • pixelcruncherP
                        pixelcruncher Extension Creator @majid
                        @majid
                        Right now, Rayscaper requires SketchUp 2021 or higher.
                        • majidM
                          majid
                          This is rather an old model... Yet I liked the result.
                          pixelcruncherP tuna1957T 2 Replies Last reply
                          Reply Quote 4
                          • pixelcruncherP
                            @majid
                            Superb render, Majid! I like the result as well.
                            This scene is a classic in computer graphics. It's the atrium of the Sponza Palace, which exists in Dubrovnik, Croatia (wiki). If you are a Game of Thrones fan, Dubrovnik is also where they filmed all the scenes in King's Landing.
                            • G
                              gerdfa
                              We get an error when we start sketchup 2024
                              SCFLicense is install
                              SketchUp: 24.0.483
                              OS: Ventura
                              Ruby: 3.2.2
                              Erweiterung: Rayscaper (0.9.10 Beta)
                              Fehler: LoadError (cannot load such file -- /users/XXX/library/application support/sketchup 2024/sketchup/plugins/rayscaper/installed/Mac/3.2.2/0.9.10 Beta/resources/SUEX_Rayscaper_SetDllDirectory)
                              <internal:/Applications/SketchUp 2024/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/3.2.2/lib/ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:/Applications/SketchUp 2024/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/3.2.2/lib/ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:85:in require'
                              /users/XXX/library/application support/sketchup 2024/sketchup/plugins/rayscaper/main.rbe:94:in <module:Rayscaper>' /users/XXX/library/application support/sketchup 2024/sketchup/plugins/rayscaper/main.rbe:5:in <main>'
                              /Applications/SketchUp 2024/SketchUp.app/Contents/Resources/Tools/extensions.rb:197:in eval' /Applications/SketchUp 2024/SketchUp.app/Contents/Resources/Tools/extensions.rb:197:in require'
                              /Applications/SketchUp 2024/SketchUp.app/Contents/Resources/Tools/extensions.rb:197:in load' /Users/XXX/Library/Application Support/SketchUp 2024/SketchUp/Plugins/rayscaper.rb:18:in register_extension'
                              /Users/XXX/Library/Application Support/SketchUp 2024/SketchUp/Plugins/rayscaper.rb:18:in <module:Rayscaper>' /Users/XXX/Library/Application Support/SketchUp 2024/SketchUp/Plugins/rayscaper.rb:6:in <top (required)>'
                              • tuna1957T
                                tuna1957 @majid
                                @majid Superb modeling and rendering. πŸ‘
                                • pixelcruncherP
                                  pixelcruncher Extension Creator @gerdfa
                                  @gerdfa
                                  It looks like you are trying Rayscaper on a Mac. Rayscaper is not yet lauched for Mac, that release is a couple of weeks out, sorry!
                                  Cheers,
                                  Thomas
                                  • majidM
                                    majid @tuna1957
                                    @tuna1957 The model is not mine, I have adjusted the model, added some details, and adjusted the textures based on an image I had from the real place...
                                    Thanks for the compliment.
                                    tuna1957T 1 Reply Last reply
                                    • tuna1957T
                                      tuna1957 @majid
                                      @majid Still a great job whether the model was yours or not. πŸ‘
                                      • majidM
                                        majid @tuna1957
                                        @tuna1957 This is another shot. I reduced the environment power so that we can see it is blue, then added another blue color directional light to compensate for it. this is an experiment yet not final.
                                        ntxdaveN tuna1957T Mike AmosM 3 Replies Last reply
                                        Reply Quote 2
                                        • ntxdaveN
                                          ntxdave @majid
                                          @majid Looks great Majid. πŸ‘ πŸ‘
                                          • Bryan KB
                                            All quite nice!
                                            • 3 / 5
