An A04 error means it can't decode the signature file.
Have you tried deleting that file and redoing it again ?
Do you have any non-ASCII characters in your computer's user-name ?In case it's a permissions issue have you installed SketchUp properly ?
You can 'Repair' it thus...
Log out of SketchUp.
Find the installer's exe file - usually in your Downloads folder.
Select the exe file's icon, right-click > context-menu > Run as administrator.
When prompted choose 'Repair'.
Reboot your computer and retry SketchUp.
Installing a complex app by double-clicking its icon is not the same - even if you are an admin.
Doing that can lead to all kinds of unpredictable issues - often relating to reading/writing files... -
@TIG Thank you for your help!
My problem solved because my computer's name have non-ASCII characters.
thank you! -
Hello. I changed the name of my computer and now I can't use the paid plugins. And the problem is that I no longer remember the original name of the PC. How should I proceed?
The best is to go to your My Licenses on Sketchucation page (just sign in) and release the licenses.
If the release seat button is not available, then tell me.
This post is deleted! -
I just bought it, why isn't it working?
You need to help us a bit more than this...
You just bought what ?
Let's assume it's a Fredo6 extension ??
Have you downloaded/installed 'it' ?
Have you downloaded/installed the latest LibFredo6, which it also needs ?
Have you installed the SketchUcation Tools which will work the licensing code ?
Have you restarted your computer to sync everything ?
Have you read and understood the guidance for buying and saving your license file[s] onto your computer ?
Have you tried to validate that license for the extension in it's submenu item under the Tools menu ?There's a lot you haven't told us...
Please help us to help you... -
@Gus-R said in SCFLicense: Extension Licensing on Sketchucation:
this morn
hello , how can i get fredo ?
Fredo what ?
Help us to help you.
You can download Fredo's extensions from our PluginStore [Ruby icon in the top bar]
Most of them will also need his FredoLib6 installing to work properly.
After the installation of the downloaded RBZ files [using the native Extension Installer] you need to restart SketchUp to sync things.
BUT you will also need the SketchUcation Toolset from the PluginStore installing to manage the licensing.
As a beneficial side effect of having the SketchUcation Toolset installed, you can then use its ExtensionStore³ dialog to Auto-Install extensions without the download of the RBZ file...
This has additional benefits, such as Update reminders and Plugin Management dialogs... -
Hi cold today I have this problem with the ThruPaint license. I tried to reinstall the license but it gives me an error that it has expired and in my panel I can't find the TruPaint license. It seemed to me I seemed to have a validated Unlimited license. What should I do, thank you
@alexpacio2013 Are you sure you are trying to activate a valid ThruPaint licence? I can not see any ThruPaint licences purchased by your user.
You can buy a valid ThruPaint licence Here
