    Many projects
    344 Posts 19 Posters 114.5k Views 17 Watching
    • jo-keJ Offline
      jo-ke
      new propject:
      Pano:
      (doerr.bplaced.net)
      http://www.zz7.de
      • jo-keJ Offline
        jo-ke
        @l i am said:
        @jo-ke said:
        new propject:
        Pano:
        (doerr.bplaced.net)
        Very nice work mate. Did you put together the mood board?
        yes, these are the materials, I used in the render. The picture on the wall is made with Midjourney.
        http://www.zz7.de
        • jo-keJ Offline
          jo-ke
          another small project:
          http://www.zz7.de
            @jo-ke said:
            new propject:
            Pano:
            (doerr.bplaced.net)
            • Mike AmosM Online
              Right up there as you do consistently mate. πŸ‘ πŸ‘
              • jo-keJ Offline
                jo-ke
                quick test in rayscaper.
                I modelled the typical fassade of a former german departmentstore.
                Looks nice. But I am still struggeling with materialsettings in rayscaper
                renderresult looks great. I hope for the beta update
                second one ist twilightrender
                third one is twinmotion
                and a sketchup diffusion
                http://www.zz7.de
                  Nice render! Can you elaborate on your struggles with Rayscaper or how we can improve the material settings? Is it a documentation thing or something that's not working out for you?
                  Thanks,
                  Thomas
                  • jo-keJ Offline
                    jo-ke
                    when I try to use the materialsettings it is continously rendering and slowing down my machine.
                    http://www.zz7.de
                      Gotcha, so it's a matter of interactivity. I'm not sure what your computer's specs are, but here are a couple of things you can try:
                      You can decrease the number of render threads in the global settings. This will ensure Rayscaper is putting less load on your CPU. The downside is that this results in slower render times. You can configure the number of render threads in the application settings.
                      You can disable material previews. Rendering the material previews also takes up CPU resources. Material previews are also configured via the application settings.
                      Rayscaper application settings
                      If you have a capable GPU, switch to GPU rendering. Then Rayscaper won't use your CPU at all. Switching to GPU rendering is done via the render settings.
                      Switch between CPU/GPU
                      • jo-keJ Offline
                        jo-ke
                        I will try that.
                        In this case I merged the rayscaper and the sketchup diffusion in Photoshop and got that nice weathered result:
                        http://www.zz7.de
                        • jo-keJ Offline
                          jo-ke
                          rayscaper and sketchupdiffusion merging in Photoshop is a nice combination.
                          weathering and organic forms are really the best in AI rendering.
                          http://www.zz7.de
                            Very nice render, I like the gloomy look.
                            Just thinking out loud, but it might be a good feature for Rayscaper to be able to do this out-of-the-box. Send the render to a diffusion model to create another image, then composite it with the original.
                            As a side note, the HDRI looks pixelated. If you are using the ones that are available in Rayscaper you might want to increase the default resolution. Disclaimer, this will result in longer download times and a longer time to prep your scene for Rayscaper.
                            PolyHaven configuration settings.
                            • jo-keJ Offline
                              jo-ke
                              a new panoset:
                              (doerr.bplaced.net)
                              http://www.zz7.de
                                pixelcruncher Extension Creator @jo-ke
                                @jo-ke Very cool, I always like the VR walkthroughs, seems like Pano2VR is a great investment.
                                  Someone loves handbags in that apartment!
                                  What resolution are these panos? They take time to render?
                                  • jo-keJ Offline
                                    jo-ke
                                    the panos have 8000x4000 resolution. they took about 10 Minutes in Twinmotion with path tracer
                                    http://www.zz7.de
                                    • jo-keJ Offline
                                      jo-ke
                                      and an easter leasure time project:
                                      I took an idea of midjourney of a nice villa and remodelled it.
                                      started yesterday night to model, and rendered today in twinmotion, some development in AI and photoshop...
                                      http://www.zz7.de
                                      • jo-keJ Offline
                                        jo-ke
                                        and a video:
                                        http://www.zz7.de
                                        majidM tuna1957T 2 Replies Last reply Reply Quote 1
                                        • majidM Offline
                                          majid @jo-ke
                                          @jo-ke Besides your modeling skills it shows the importance of assets in bringing the model to life.
                                          • tuna1957T Offline
                                            tuna1957 @jo-ke
                                            @jo-ke As always… excellent work and presentation πŸ‘
                                            jo-keJ 1 Reply Last reply Reply Quote 0
                                            • 17
                                            • 18
                                            • 7 / 18
